TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 4, 2017 at 9:48 AM
    #6001
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you're going through the trouble, get oversized valves. Inconel. Titanium, however awesome, is too much a princess. Must be coated. Longevity with inconel will be better suited to DD miles.
    Next, is which other engine have the same valves which make for a quicker turn around time.
    Then there comes the head gasket. Easiest to stick with OEM, but you could upgrade to Cometic or JE, but then there is that turnaround for new ones to be made.
    How much time do you have, and what is your budget?
    I am not going to tell anyone not to forge a path. That'd be against my mantra. Just lay out your plan and time frames.
    MrCrowntown likes this.
  2. Mar 4, 2017 at 9:51 AM
    #6002
    Torspd
    Tor
    The Great America!
    I have two spares. :D o_O
    Xionation, RedLantern and MrCrowntown like this.
  3. Mar 4, 2017 at 10:05 AM
    #6003
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    A good yin and yang of approaches haha
  4. Mar 4, 2017 at 2:26 PM
    #6004
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Im sure you have a third one in line somewhere... That's just the torspd way :bananadance:
  5. Mar 4, 2017 at 2:42 PM
    #6005
    Torspd
    Tor
    The Great America!
    Two built and one stock. :cookiemonster::broccoli:
    Xionation and MrCrowntown like this.
  6. Mar 4, 2017 at 8:33 PM
    #6006
    skyking3
    skyking3 Well-Known Member
    Tom
    2025 Tacoma TRD Sport Hybrid
    TTD billet oil cap, Weathertech tonneau cover ---All following mods were for my 3rd gen --TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Thanks for your response. I am retired so time is not an issue as it is just one of my hobbies. The budget is also not an issue since I paid cash for my truck and my wife's suv last year. My house and condo on the ocean are both paid for also. The problem is my wife. We have an agreement that if either one of us buys something that the other thinks is a waste then the other gets to spend the same amount on what they want and she is a pack rat that saves everything. Since the number one cause of divorce is money, this is why we have stayed married for 41 years and that is my marriage counseling lesson for the day.
    Now back to what I was asking. Where did you get your head work done? What other mods did you have done on your 2 built engines? How much difference did you notice with your aluminum drive shaft?
    Torspd[QUOTED][OP] likes this.
  7. Mar 4, 2017 at 9:11 PM
    #6007
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    2025 Underground DCLB Sold 21 Ram TRX Sold 2015 White DCSB Offroad
    Stock for now
    So after 12 hours of installing URD Headers I'm never doing that shit again
    But the results are so worth it
  8. Mar 4, 2017 at 9:51 PM
    #6008
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Haha it's fun though! Glad ya got em in. I think they're worth it too.
  9. Mar 4, 2017 at 9:54 PM
    #6009
    TacoJova
    Central Oregon
    Stock for now
    Yeah they are! Trucks acting a little weird but should go away once the ecu learns
  10. Mar 5, 2017 at 6:39 AM
    #6010
    Torspd
    Tor
    The Great America!
    www.lceperformance.com, did my head work. They've all the years experience and tools. Toyota only.
    The mods for the two engine......all of them.
    The aluminum D.S. was due to strength requirements. As it is a thicker tubing than the steel one that I had. It is also lighter, so I am sure that there was a "noticeable" difference. However, I had also installed a T56 transmission at the same time.
  11. Mar 5, 2017 at 6:56 AM
    #6011
    Torspd
    Tor
    The Great America!
    But aren't you so proud now?!
    TacoJova[QUOTED] likes this.
  12. Mar 5, 2017 at 7:07 AM
    #6012
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Sounds like installing a rear bbk.
  13. Mar 5, 2017 at 7:10 AM
    #6013
    Torspd
    Tor
    The Great America!
    Ha
    Lucario Runner likes this.
  14. Mar 5, 2017 at 8:21 AM
    #6014
    MrCrowntown
    Alyn
    Ky
    @Torspd I didn't know you had your heads done by LCE
  15. Mar 5, 2017 at 10:07 AM
    #6015
    Torspd
    Tor
    The Great America!
    The set that is on, yes. Except when I delivered the engine to Justice Racing Engines, the did the work to install the oversized valves.
    They are no longer in business though, hence why I did not mention them.
    H Squared Racing engines also has done some head work for me. They are in Houston. They also repaired and assembled the 4.3L short block, which I have in there now.
  16. Mar 5, 2017 at 10:25 AM
    #6016
    MrCrowntown
    Alyn
    Ky
    How was the work? What did they do for you? Any pics of the work? You know.. recon purposes and such
    :anonymous:
  17. Mar 5, 2017 at 10:26 AM
    #6017
    Torspd
    Tor
    The Great America!
    Of the heads or the engine rebuild?
    Who specifically?
  18. Mar 5, 2017 at 10:28 AM
    #6018
    MrCrowntown
    Alyn
    Ky
    The heads, i'm considering letting them R&D on a spare head of mine
  19. Mar 5, 2017 at 10:28 AM
    #6019
    Torspd
    Tor
    The Great America!
    Definitely. Especially since they are in your backyard.
  20. Mar 5, 2017 at 10:32 AM
    #6020
    Torspd
    Tor
    The Great America!
    LCE did the porting job. Had I had the money at the time, I'd have had them do the oversized valves as well. They did install new dual springswith Ti retainers.
    If you are building yours to handle towards 1k hp, ask them if the feel that the head studs diameter should be increased.
