TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 16, 2017 at 11:23 AM
    #6061
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    :bowdown: thank you. needed something like this for a while now.
  2. Mar 16, 2017 at 11:41 AM
    #6062
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Ooohhhhhhhhhhhhhhhhhh why you be reading my mind. :spy:
  3. Mar 16, 2017 at 11:41 AM
    #6063
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    In pending price, and then probably still in. If its fully bolt up, thatd be great. Curious how itll work. Cowl included I hope!
  4. Mar 16, 2017 at 11:42 AM
    #6064
    MrCrowntown
    Alyn
    Ky
    I would want to be able to use my flexalite still too...
  5. Mar 16, 2017 at 11:52 AM
    #6065
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mine specifically will have the ability to use the dual SPAL fans that my old radiator had. Or a size very similar.
    They are keen on as much air flow as possible, since they know the heat best. Being in Glendale, AZ.
    They are using the OEM shroud for fitment and mock-up.
    Due to the fact that they can make custom one-off radiators, there will be room for adjustment to the nuances of a buyer's request. :D
    The purpose, is for direct bolt-in. :thumbsup: :thumbsup:
    mach1man001 likes this.
  6. Mar 16, 2017 at 11:52 AM
    #6066
    Torspd
    Tor
    The Great America!
    And as I typed that last message, my radiator was delivered to them.
  7. Mar 16, 2017 at 11:54 AM
    #6067
    VolcomTacoma
    Jeff
    NorCal
    Awesome sauce. Looking forward to it!
  8. Mar 16, 2017 at 12:03 PM
    #6068
    Torspd
    Tor
    The Great America!
    Oh yeah. I sent them an auto transmission radiator. So they can build one for both. :thumbsup:
    RedLantern and nfs257 like this.
  9. Mar 16, 2017 at 12:06 PM
    #6069
    MrCrowntown
    Alyn
    Ky
    I am in Glendale :anonymous:
  10. Mar 16, 2017 at 12:11 PM
    #6070
    Torspd
    Tor
    The Great America!
    Dooo hwaaaaat? Then this will be a perfect mod. As long as yours is the same as ours? That I do not know. Take some pictures and post up please.
    MrCrowntown likes this.
  11. Mar 16, 2017 at 12:15 PM
    #6071
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    can you request nice beefy mounts please? years of bouncing around and frame/body flexing has claimed at least one of my stock tabs.
    I Love You...
  12. Mar 16, 2017 at 12:17 PM
    #6072
    MrCrowntown
    Alyn
    Ky
    It's the same! The core supports and front stuffs are all the same ! Much excite! And if they are making provisions for the shroud, then the flexalites will fit too. Yay!
    Torspd[QUOTED][OP] likes this.
  13. Mar 16, 2017 at 12:20 PM
    #6073
    Torspd
    Tor
    The Great America!
    I will add that to the next email. I feel that the dune hoppers will need the most reinforcement.
    nfs257, colinb17 and MrCrowntown like this.
  14. Mar 16, 2017 at 12:22 PM
    #6074
    MrCrowntown
    Alyn
    Ky
    Dont forget puddle jumpers
    colinb17 likes this.
  15. Mar 16, 2017 at 12:26 PM
    #6075
    Torspd
    Tor
    The Great America!
    And puddle jumpers.
    MrCrowntown and colinb17 like this.
  16. Mar 16, 2017 at 12:36 PM
    #6076
    VolcomTacoma
    Jeff
    NorCal
    You got that right. Already have the poly body mounts and cab mounts. I'm not quite ready to engine cage, so any sort of upgraded radiator bushing they can make would rock
  17. Mar 16, 2017 at 2:09 PM
    #6077
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    need to send two. lol
  18. Mar 16, 2017 at 3:12 PM
    #6078
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Shut up and take my money.....
    Torspd[OP] and MrCrowntown like this.
  19. Mar 16, 2017 at 4:08 PM
    #6079
    Torspd
    Tor
    The Great America!
    Alright Fry. ;)
  20. Mar 16, 2017 at 4:14 PM
    #6080
    Torspd
    Tor
    The Great America!
    @XPOTRPR
    MrCrowntown and XPOTRPR like this.
