TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Mar 16, 2017 at 5:19 PM
    #6081
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yessssss! New radiator with a E fan is in my future!!
    MrCrowntown and nfs257 like this.
  2. Mar 16, 2017 at 6:11 PM
    #6082
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I should have done this years ago, instead of being stingy with my other one. :smack:
    MrCrowntown likes this.
  3. Mar 16, 2017 at 6:57 PM
    #6083
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    That's damn good news!!
  4. Mar 16, 2017 at 7:09 PM
    #6084
    Torspd
    Tor
    The Great America!
    I have been waiting a few weeks to share. Had to make sure the plan was in full effect. :spy:
    nfs257, RedLantern and MrCrowntown like this.
  5. Mar 16, 2017 at 7:11 PM
    #6085
    RedLantern
    Honolulu, Hi
    I'll definitely buy. Heat is the enemy and this will help greatly.
  6. Mar 16, 2017 at 7:13 PM
    #6086
    Torspd
    Tor
    The Great America!
    Especially with sleeves, and this thick ass intercooler being more of a door than a screen.....
    colinb17 and nfs257 like this.
  7. Mar 16, 2017 at 7:14 PM
    #6087
    RedLantern
    Honolulu, Hi
    I could use some sleeves....too bad it's so dang expensive
  8. Mar 16, 2017 at 11:16 PM
    #6088
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I could use some sleeves too.... for my muscle shirt :drevil:
  9. Mar 17, 2017 at 4:20 AM
    #6089
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i have a ron davis in my truck also. i bought one that was thicker and had the outlets same as the factory one. i made my own mounts. i modified to work with the ls swap also. such a amazing radiator.
    XPOTRPR likes this.
  10. Mar 17, 2017 at 4:33 AM
    #6090
    Torspd
    Tor
    The Great America!
    :muscleflexing::curls:
    MrCrowntown[QUOTED] likes this.
  11. Mar 17, 2017 at 4:53 AM
    #6091
    Torspd
    Tor
    The Great America!
    My last one was as well. Except that I purchased one for a Trophy Truck. Which means it was meant for a rigid chassis.
    Had I known better, I would have gotten one for a vehicle that flexes, as they construct them differently.
    colinb17 likes this.
  12. Mar 17, 2017 at 4:55 AM
    #6092
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    true. everyone will thank you once they get that ron davis in there
  13. Mar 17, 2017 at 9:16 AM
    #6093
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    All aluminum ron davis with spal electric fans would be noice!
    XPOTRPR likes this.
  14. Mar 17, 2017 at 10:56 AM
    #6094
    Torspd
    Tor
    The Great America!
    100* ambient temps, and running between 168* to 174*. With that dual SPAL setup. Loved it!
  15. Mar 17, 2017 at 11:58 AM
    #6095
    Torspd
    Tor
    The Great America!
    Corresponding with my friend at Toyota, the radiator and shroud are the same across the year models of 2005-2015.
    However, he mentioned that the radiator is not the same from the 2TR models.
  16. Mar 17, 2017 at 12:36 PM
    #6096
    MrCrowntown
    Alyn
    Ky
    How is it different?
  17. Mar 17, 2017 at 12:37 PM
    #6097
    MrCrowntown
    Alyn
    Ky
  18. Mar 17, 2017 at 12:59 PM
    #6098
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @Torspd is there a difference if we want to run dual fans? Have been considering that setup. I know whipper naysayed it alot, but did we ever conclude whether dual electric fans has more parasitic loss than engine fan? I would think not, but I dont know what kind of load they put on the alternator.
  19. Mar 17, 2017 at 1:24 PM
    #6099
    Torspd
    Tor
    The Great America!
    Man, that parasitic crap is a bunch of foolishness. That be like saying don't run all of your aftermarket lights and accessories because the drain on the alternator will cause a horse power loss. Really?!?!o_O
    No. The fan and clutch are the loss. They create the reciprocating drag resistance.
    Just don't have a 17lb batter and dual SPAL fans. They will kill it. :bananadead:
    Besides, the electric fans can flow soooooo much more air than the mechanical one. Where cooling is necessary, that is what you want.
    And I don't want to hear any debate about electrical fans failing because their is no damn belt. Otherwise OEM's would never use them, nor would race car teams on low to high end cars. Get a damn good fan, and the shit will last. Get a chinese fan, and go F yourself because you enjoy single player more than multiplayer. :laugh:
    Xionation, timothom, Brice and 4 others like this.
  20. Mar 17, 2017 at 1:27 PM
    #6100
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
