TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. May 8, 2017 at 10:05 AM
    #6261
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    130 will be fine. Thats what I run. The Factory upgraded Alternator. 130amps. Your Taco might have it already.
    ooooooooh man.. :popcorn:
    Torspd[QUOTED][OP] likes this.
  2. May 8, 2017 at 10:27 AM
    #6262
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I upgraded to the 130 also. Denso, from Rockauto.
    Then went from a 17lb battery to a 21lb. The system couldn't handle the current draw of the fans being on then the A/C turning on. Or visa versa.
    MrCrowntown likes this.
  3. May 8, 2017 at 10:45 AM
    #6263
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    The 130A handles it fine? Or do you feel like it should be a larger one?
  4. May 8, 2017 at 10:54 AM
    #6264
    Torspd
    Tor
    The Great America!
    The 130 handled them just fine. I'll have them installed by this weekend hopefully. Then get to put this new radiator through it paces. I'll report back for certain.
    deeezy, SonnyBones and MrCrowntown like this.
  5. May 8, 2017 at 11:26 AM
    #6265
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    You bet your ass I'm getting the race version! Haha
    Torspd[OP] likes this.
  6. May 8, 2017 at 11:39 AM
    #6266
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    What would the main difference between the 2 be?
  7. May 8, 2017 at 12:17 PM
    #6267
    Torspd
    Tor
    The Great America!
    Thickness, I know for a fact. Possibly added strength due to the fact that I told them I plan on being between 600 - 800 whp.
  8. May 8, 2017 at 12:37 PM
    #6268
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    not quite as fancy but i received my mishimoto 2 core for my integra! plus i have the fans/shroud setup to boot
  9. May 8, 2017 at 12:53 PM
    #6269
    Torspd
    Tor
    The Great America!
    But does it mean Mas Coolz??? Then still worthy. :cool:
  10. May 8, 2017 at 1:03 PM
    #6270
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  11. May 8, 2017 at 6:56 PM
    #6271
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    @Torspd do they have it online at all or do I need to call? Prices for the upgraded Tacoma radiator? Also will the race one bolt in to stock location? Also, can us 300rwhp peasants use the race application radiator?
  12. May 9, 2017 at 6:04 AM
    #6272
    Torspd
    Tor
    The Great America!
    Any one can use the race version, to my current knowledge. It will bolt up just the same. Simply it should just be a thicker version.
    Best bet is give them a call. Since it isn't yet listed on their website. They is also rumor that they are working on the 4Runner model as well.
  13. May 9, 2017 at 6:09 AM
    #6273
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What kind of psycho sumabitch would race a 4Runner?? :confused::confused:
    :boink:
  14. May 9, 2017 at 6:48 AM
    #6274
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Because racing anything else would be too easy! Lol first time I spied pics of Lucario on track I thought there was gonna be a trailer behind him for his balls.
    Have you had any off track excursions @Lucario Runner and does rolling worry you?
    Lucario Runner and Torspd[OP] like this.
  15. May 9, 2017 at 8:35 AM
    #6275
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I have had one. I was on Torspd's wheels and tires (old nitto invos that were sitting) and was my 2nd ever track day and 1st time going clock wise on at msr. After i was kicked out of novice and went into advanced it started raining and i hit a nice pool of water under power and spun it. Open differential was a factor as was the invos. It wasnt bad, i extracted myself back on to the track and continued. Learned more about throttle control and looking for the areas of track with less water vs going for the line when raining. Rolling over? Im not worried about that as much as others think i should be, you can roll anything. I just need to pay extra attention to the weight transfer compared to others. Nothing will train you better at weight tranfer, under braking or cornering than a 97 rav4 with no rear sway bar, ill tell you what. Still it is nice having a R32 gtr and try to implement how i drive that onto the 4runner.
    SconnieHailer and Torspd[OP] like this.
  16. May 9, 2017 at 8:39 AM
    #6276
    Lucario Runner
    Robert
    06 Toyota 4Runner
  17. May 9, 2017 at 8:45 AM
    #6277
    Torspd
    Tor
    The Great America!
    Look at that flex! :muscleflexing:
  18. May 9, 2017 at 8:52 AM
    #6278
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Carrying that front inside tire! :thumbsup:
    Who needs traction from 4 tires when 3 is more than sufficient.
  19. May 9, 2017 at 10:30 AM
    #6279
    Lucario Runner
    Robert
    06 Toyota 4Runner
  20. May 10, 2017 at 4:43 PM
    #6280
    Torspd
    Tor
    The Great America!
    For those not following the Upgraded Ron Davis thread.
    Hot off the UPS truck!
