TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jul 10, 2017 at 1:57 PM
    #6481
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    In due time...
    Til then, im trying to get replacement tuning software for my MAF calibrator from URD. I wanna start fudging around with it
  2. Jul 10, 2017 at 2:01 PM
    #6482
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Interesting. Just to have fun with the MAF cal, or other?
  3. Jul 10, 2017 at 2:07 PM
    #6483
    MrCrowntown
    Alyn
    Ky
    Just fun with the MAF cal.
    I need to have some fun while LCE has all my other fun stuff
  4. Jul 10, 2017 at 2:14 PM
    #6484
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  5. Jul 10, 2017 at 3:04 PM
    #6485
    Torspd
    Tor
    The Great America!
    The part which created the scavenger hunt on track day. LOL
  6. Jul 15, 2017 at 10:43 AM
    #6486
    MrCrowntown
    Alyn
    Ky
    Hey, have you figured out a performance coil option?
  7. Jul 15, 2017 at 11:16 AM
    #6487
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Isn't Accel the only 1GR coil game in town?
  8. Jul 15, 2017 at 12:58 PM
    #6488
    Torspd
    Tor
    The Great America!
    Could go aftermarket, which would need to be adapted. That is the best that I can figure.
  9. Jul 15, 2017 at 1:07 PM
    #6489
    MrCrowntown
    Alyn
    Ky
    If shit gets too crazy, I could always mount coils and run wires, but a clean option would be rad. Accel any good?
    Have you found the stock coils to be lacking at all?
  10. Jul 15, 2017 at 1:52 PM
    #6490
    Torspd
    Tor
    The Great America!
    Honestly, we haven't. We'd have to cross reference the specs of what our coils put out, versus other engines and their aftermarket upgrade coils to see if there would be an improvement to be gained.
  11. Jul 15, 2017 at 1:54 PM
    #6491
    MrCrowntown
    Alyn
    Ky
    I don't see them really being a problem until im trying to make BIG BOOST at hig rpms. Like 8k and up maybe
  12. Jul 15, 2017 at 4:42 PM
    #6492
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I would be terrified of a 1GR at 8k... it already sounds like it's over revving at 5.5.k
    gersus likes this.
  13. Jul 15, 2017 at 6:20 PM
    #6493
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Ive seen 1grs at 6500 and sit there for awhile and then still live, although hiw much longer or any other details im not sure about. All part of those Arabian games. My engine is set at 6200 rpm.
  14. Jul 15, 2017 at 6:25 PM
    #6494
    MrCrowntown
    Alyn
    Ky
    2TR life tho
    :cool:
    They use the same coils. I'm just thinking ahead. WAY ahead.:burnrubber:
  15. Jul 15, 2017 at 6:27 PM
    #6495
    BadBrains
    AL
    I hate to even speculate on things like this without any data to back it up, however I can't imagine the factory system not putting out enough spark. Honda B-series can spin to 8k+ on a conventional distributor, and we have two more cylinders, so it's firing slower.
  16. Jul 15, 2017 at 6:32 PM
    #6496
    MrCrowntown
    Alyn
    Ky
    i'm running the 4cyl, but they use the same coils
    It's not about the speed of the spark. It's the power of the spark at that speed. Something that outputs 15% more at normal conditions may be able to keep up better at the top end
    This is all worrisome speculation really. It will be a while til i max out any of these coils. Healthy debate can be fun though!:bikewhoops:
  17. Jul 15, 2017 at 6:53 PM
    #6497
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I saw a coil once. It was awesome.
    Torspd[OP] likes this.
  18. Jul 15, 2017 at 6:54 PM
    #6498
    Torspd
    Tor
    The Great America!
    tC uses the same but shorter coil packs. Teams have built race cars with that engine/car. Need to find out if they upgraded the coil packs, and what to.
  19. Jul 15, 2017 at 6:56 PM
    #6499
    VolcomTacoma
    Jeff
    NorCal
    Wasn't there an alternate brand you were promoting or at least gave a slight affirmative nod of your head towards a while back? They were yellow IIRC @Torspd
  20. Jul 15, 2017 at 7:06 PM
    #6500
    MrCrowntown
    Alyn
    Ky
