TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jul 23, 2017 at 9:13 AM
    #6541
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mmmm...Radium. Don't browse their site long...you'll want everything. Like when going grocery shopping when you're hungry. Big no-no.
  2. Jul 23, 2017 at 10:11 AM
    #6542
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Ya, I had to force close the site lol
    ChadsPride and TacoLeeSD like this.
  3. Jul 23, 2017 at 11:20 AM
    #6543
    Torspd
    Tor
    The Great America!
  4. Jul 23, 2017 at 3:04 PM
    #6544
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Radium is good shiz.
    ChadsPride, TacoLeeSD and MrCrowntown like this.
  5. Jul 23, 2017 at 3:11 PM
    #6545
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    What pod is that?
    ChadsPride likes this.
  6. Jul 23, 2017 at 3:13 PM
    #6546
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Autometer carbon fiber gauge pod. A universal piece.
    ChadsPride, Brice and Torspd[OP] like this.
  7. Jul 23, 2017 at 3:34 PM
    #6547
    Torspd
    Tor
    The Great America!
    GTR's approve this message.
  8. Jul 24, 2017 at 11:41 AM
    #6548
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Negative. Will be doing a lot of preventive measure upgrades prior to adding boost. Items like Ron Davis radiator w/ twin fans, trans cooler, maybe engine oil cooler (I think oem one might be able to handle), and converting certain fluid lines to AN fittings, and hoses.
  9. Jul 24, 2017 at 12:06 PM
    #6549
    Torspd
    Tor
    The Great America!
    Very nice!
    ChadsPride and SonnyBones like this.
  10. Jul 24, 2017 at 12:14 PM
    #6550
    SonnyBones
    Jeffery
    Btw, are you still utilizing an ATI damper pulley? Looking through one of their catalogs and notice they made for 1GR. I was thinking since I'm gonna be working in the pulleys when I get to installing SC, I might as well upgrade crank pulley to an ATI. Not sure if it would be compatible with SC pulley that's supposed to go on the crank pulley. Thoughts?
  11. Jul 24, 2017 at 1:29 PM
    #6551
    Torspd
    Tor
    The Great America!
    I recently swapped it over from the engine on the stand. So yes, I am.
    I doubt it will work with the ATI pulley, since the s/c pulley recesses into the OEM crank pulley. The ATI pulley is a flush face design, so they wouldn't be able to mate properly.
    SonnyBones and ChadsPride like this.
  12. Jul 24, 2017 at 1:34 PM
    #6552
    SonnyBones
    Jeffery
    I was afraid that was the case. Ohh well, one less thing I can spend money on :)
  13. Jul 24, 2017 at 1:35 PM
    #6553
    Torspd
    Tor
    The Great America!
    Can be reconstituted elswhere. ;)
  14. Jul 24, 2017 at 1:53 PM
    #6554
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    Radium has some really nice products!! Has anyone tried to fit the Radium 2GR-FE fuel rail kit on a 1GR?
  15. Jul 24, 2017 at 2:15 PM
    #6555
    Torspd
    Tor
    The Great America!
    Not I.
  16. Jul 24, 2017 at 4:21 PM
    #6556
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This reminds me. I should install my apr fuel rail...
    TacoLeeSD and ChadsPride like this.
  17. Jul 24, 2017 at 7:25 PM
    #6557
    Torspd
    Tor
    The Great America!
    You have all of the fittings and line, correct?
  18. Jul 24, 2017 at 7:36 PM
    #6558
    TacoLeeSD
    Do you guys know if APR still makes a fuel rail? I didn't see one on their web site, not sure if it's a special order item.
  19. Jul 24, 2017 at 8:03 PM
    #6559
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Nuh uh.
  20. Jul 24, 2017 at 8:04 PM
    #6560
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I don't think so, but could try and ask em.
    TacoLeeSD[QUOTED] and ChadsPride like this.
