TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 4, 2017 at 2:18 PM
    #6561
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    @Torspd how is your build going? Are you getting close to Dyno tuning?
    ChadsPride likes this.
  2. Aug 4, 2017 at 2:35 PM
    #6562
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Ya and I remember calling you out for a break in video
    :boink:
    TacoLeeSD, ChadsPride and yota243 like this.
  3. Aug 4, 2017 at 3:13 PM
    #6563
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    On hiatus temporarily. Taking care of a few other things. It is patiently awaiting its number, in the driveway. :pout:
    A few more weeks, and it will be time to start up the process again. :woot:
    Until then, just getting my thrill through the keyboard....:pccoffee:
    Turbo is still in the box. More material still needs to be ordered.
  4. Aug 4, 2017 at 3:18 PM
    #6564
    TacoLeeSD
    Sounds good, looking forward to seeing an update.
  5. Aug 4, 2017 at 6:09 PM
    #6565
    MrCrowntown
    Alyn
    Ky
    Hey, so im installing my FPR this weekend, and it's a 1:1 regulator. DO I need to run the vacuum line to it like the stock one has? I'm not boosting yet, just installing the fuel system. Am I okay to leave it unconnected to vacuum and just set the stock fuel pressure and be done?
  6. Aug 4, 2017 at 11:15 PM
    #6566
    TacoLeeSD
    I would go ahead and connect the vacuum line, and for the time being set your fuel pressure to the stock setting. This will allow everything to operate normal till you change your injectors out for larger ones, and then you can tweak as needed then. With the vacuum/boost reference line attached once you set your fuel pressure at idle under approximately 20inHg of vacuum you should see your fuel pressure rise as the engine transitions out of vacuum to atmospheric pressure (14.7psi). With either a factory or aftermarket regulator you will see the fuel pressure increase like this. I have no idea what the factory Tacoma setting is but let's say the setting is 40psi at idle this means the fuel pressure will increase to approximately 54.7 as you accelerate (it will realistically be less due to various losses but this is the general idea). Add boost and it will go up from there.
  7. Aug 5, 2017 at 6:04 AM
    #6567
    Torspd
    Tor
    The Great America!
    One minor correction to make.
    Set the FPR's base fuel pressure without the vacuum hose attached. Otherwise, you'll be setting it at idle vacuum. You want it set at atmospheric pressure. Which is no vacuum.
    OEM fuel pressure is ~43.5 psi. Set it close to that for OEM operation. Once set, then attach the vacuum hose.
    I have mine set to 50 psi, for the Haltech. Better atomization from higher pressure equals a more thorough combustion.
  8. Aug 5, 2017 at 6:21 AM
    #6568
    Torspd
    Tor
    The Great America!
  9. Aug 5, 2017 at 6:33 AM
    #6569
    Torspd
    Tor
    The Great America!
    ChadsPride, SonnyBones and TacoLeeSD like this.
  10. Aug 5, 2017 at 11:22 AM
    #6570
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    There was a crazy 86 in that one. :drool:
    Dalandser and ChadsPride like this.
  11. Aug 5, 2017 at 12:26 PM
    #6571
    Torspd
    Tor
    The Great America!
    :drool: Yours is next Craig. :D
    ChadsPride and HomerTaco like this.
  12. Aug 14, 2017 at 7:01 PM
    #6572
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Turbo paper weights are the best. Especially machined compressor covers. Ask me how I know lol.
  13. Aug 14, 2017 at 7:54 PM
    #6573
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Solid Trans mounts ordered. Guess I have to install the motor mounts finally >_<
  14. Aug 23, 2017 at 10:30 PM
    #6574
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    You got a Unichip instead of a Ucon? I thought the UCON was a done deal? Where are you gonna get it tuned? I just picked one up but need to get a new PnP harness for '11 and find a tuner.
  15. Aug 23, 2017 at 10:45 PM
    #6575
    VolcomTacoma
    Jeff
    NorCal
    Got no response :(
    Prob get UCON next year when I get my bonus, along with some more supporting mods :D
  16. Aug 24, 2017 at 4:26 AM
    #6576
    Torspd
    Tor
    The Great America!
    Only worth components from Unichip, are their plugs and harness. Those can be used to make a plug n play harness with a better piece of equipment.
    TacoLeeSD likes this.
  17. Aug 24, 2017 at 9:22 AM
    #6577
    VolcomTacoma
    Jeff
    NorCal
    Orly? How so and with what?
  18. Aug 24, 2017 at 10:12 AM
    #6578
    Torspd
    Tor
    The Great America!
    @Hacktacular did this. Since his was an '09+. First bought a Unichip. Tuned it in decently. Needed more capability than what it could offer.
    Talked with Boomslang. Sent the harness to them, and they modified it to work with a Haltech Elite. '09+, with Haltech, all plug n play.
    His turbo build has the pictures.
    Hacktacular and TacoLeeSD like this.
  19. Aug 24, 2017 at 12:56 PM
    #6579
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    I give credit where credit is due. Unichip held its own. I wanted more control so I went with a crazy idea that maybe I could Frankenstein it. It worked...lol. Main reason I dumped Unichip was because they have one guy for support and he was not very helpful with software updates and support. I did buy the 290 dollar software and they still treated me like a bother. So my money went elsewhere. But if anyone needs help tuning the Unichip reach out, I don't mind helping.
  20. Aug 24, 2017 at 3:21 PM
    #6580
    Torspd
    Tor
    The Great America!
    From the man himself.
