TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Apr 2, 2018 at 5:39 AM
    #7081
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    Dude! Looking awesome!
    Torspd[QUOTED][OP] likes this.
  2. Apr 2, 2018 at 5:41 AM
    #7082
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    We have big expectations for those fabbed primaries. You better be able to fill 'em up! :D
    MrCrowntown likes this.
  3. Apr 2, 2018 at 6:23 AM
    #7083
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Weld it, coat it, tune it, race it.
    SMKYTXN, HomerTaco and yota243 like this.
  4. Apr 2, 2018 at 6:36 AM
    #7084
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Thank you sir. :hattip:
    I know how to fill a hole. :cool:
    FIFY. :cheers::burnrubber:
    TacoLeeSD, HomerTaco and yota243 like this.
  5. Apr 2, 2018 at 6:37 AM
    #7085
    cory02taco
    Cory
    Maine
    Isn't that a daft punk song?
  6. Apr 2, 2018 at 6:38 AM
    #7086
    Torspd
    Tor
    The Great America!
    It's not?!
    Lucario Runner likes this.
  7. Apr 2, 2018 at 6:52 AM
    #7087
    cory02taco
    Cory
    Maine
  8. Apr 2, 2018 at 8:09 AM
    #7088
    Lucario Runner
    Robert
    06 Toyota 4Runner
    One more time
  9. Apr 2, 2018 at 8:28 AM
    #7089
    Torspd
    Tor
    The Great America!
    Around the world.
  10. Apr 2, 2018 at 10:14 AM
    #7090
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  11. Apr 2, 2018 at 8:17 PM
    #7091
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    That is turning out really good! I have never heard of that flux that you mentioned, I will have to look it up and order some.
    MadTaco461 likes this.
  12. Apr 2, 2018 at 9:28 PM
    #7092
    Torspd
    Tor
    The Great America!
    Harris Solar Flux. Very handy. Saves a ton of argon.
    TacoLeeSD likes this.
  13. Apr 3, 2018 at 11:50 AM
    #7093
    Torspd
    Tor
    The Great America!
    Background. Had a dyno pull session about two years ago, after installing the 4.3L stroker engine.
    Significant mods: custom turbo & engine spec'd camshafts, 9.0:1 compression, ported heads, oversized intake and exhaust valves. 2nd gen Doug Thorley headers, stock y-pipe, 2.5" exhaust, stock-ish intake. All the same as before.
    Just recently finished getting session of dyno pulls done today. Only difference, the addition of the Haltech Elite 2500 standalone running the show. Self tuned.
  14. Apr 3, 2018 at 11:54 AM
    #7094
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    and >or<?
  15. Apr 3, 2018 at 12:19 PM
    #7095
    TacoLeeSD
    Come on :drool: . Don’t leave us hanging like this. What are the numbers?
    yota243 likes this.
  16. Apr 3, 2018 at 12:38 PM
    #7096
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  17. Apr 3, 2018 at 12:54 PM
    #7097
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    let me guess the printer ran out of ink at the dyno.
    yota243 and TacoLeeSD like this.
  18. Apr 3, 2018 at 1:02 PM
    #7098
    TacoLeeSD
    That has got to be what happened :rofl:
    MadTaco461[QUOTED] likes this.
  19. Apr 3, 2018 at 1:09 PM
    #7099
    Torspd
    Tor
    The Great America!
    Been running errands on working on a few things. First dyno graph is the original dyno on the OEM ecu. If you look closely, you'll find three graphs which all vary, towards the middle to end of the RPM range.
    This was due to me wanting to see how significant the changes would be while locking the ACIS valve, (intake runner valve) in either direction, as well as operational.
    The blue is the one from today. What you see at the end of the pull, where the graphs cross, is the HP climbing, and the torque nearly staying flat. That sharp increase in at ~3900 is the operation of the ACIS valve. It is even audible.
  20. Apr 3, 2018 at 1:37 PM
    #7100
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Audible?.....Can WE hear it? :cool::fingerscrossed:
