TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Apr 3, 2018 at 1:45 PM
    #7101
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Vtech yo
    Roostfactor and TacoLeeSD like this.
  2. Apr 3, 2018 at 2:06 PM
    #7102
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ride alongs only :burnrubber:
    I didn't record it. Nothing to be impressed about.
  3. Apr 3, 2018 at 7:46 PM
    #7103
    Torspd
    Tor
    The Great America!
    Header is nearing completion. :woot:
    A few more tac's, then back-purge and weld.
  4. Apr 3, 2018 at 8:17 PM
    #7104
    inwood customs
    Dave
    Biscuits and Torspd[QUOTED][OP] like this.
  5. Apr 4, 2018 at 7:03 AM
    #7105
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    What time does the Carnival open? :turtleride:
  6. Apr 4, 2018 at 7:30 AM
    #7106
    Torspd
    Tor
    The Great America!
    May. After coffee and breakfast.
  7. Apr 4, 2018 at 8:53 AM
    #7107
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    :spy:
    Road trip
  8. Apr 4, 2018 at 8:55 AM
    #7108
    MrCrowntown
    Alyn
    Ky
    This is an NA graph? if so, thats impressive..
    ImplicitlyAlberta likes this.
  9. Apr 4, 2018 at 9:01 AM
    #7109
    Torspd
    Tor
    The Great America!
    That is correct, Naturally Aspirated. 271whp and 332wtq, on a Mustang Dyno. I am pleased with the results of my road tuning. After I finish fabricating the header, I'll go back and comb over the ignition map, referenced to the graph. Might adjust the ACIS operation as well.
    As there will still be some time before the turbo kit is completed in its entirety.
  10. Apr 4, 2018 at 4:00 PM
    #7110
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    <3
  11. Apr 4, 2018 at 4:46 PM
    #7111
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    What is ACIS? Is that just another acronym for VVT-i?
  12. Apr 4, 2018 at 4:50 PM
    #7112
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    it adjusts intake runner length. long runners for low torque improvement at lower rpms then opening up into short runners for higher rpms.
    Roostfactor and Torspd[OP] like this.
  13. Apr 4, 2018 at 4:58 PM
    #7113
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Ahh I've read about that on hypercars.
  14. Apr 4, 2018 at 5:01 PM
    #7114
    Sacrifice
    KS
    DCSB OR 4X4 LT
    its pretty common, its been used for quite a while on Hondas at least. early 90s that i know of.
    05Taco4x4[QUOTED] likes this.
  15. Apr 4, 2018 at 5:44 PM
    #7115
    Torspd
    Tor
    The Great America!
    @HomerTaco , I don't know if I had made a mention of the fact or not, but when you last drove it, that was with the anemic dyno graph, from the OEM ecu controlling the engine.
  16. Apr 4, 2018 at 6:07 PM
    #7116
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Oh, I remember - you made it crystal clear that there was a heck of a lot more power to be had. ;)
    Those memories still put a smile on my face. :D
    Need to come up with a "work" excuse to travel to Houston again... :devil:
  17. Apr 4, 2018 at 9:03 PM
    #7117
    Torspd
    Tor
    The Great America!
    Phew. Look at me looking out for myself. Lol. Bring it on man!
  18. Apr 4, 2018 at 9:04 PM
    #7118
    Torspd
    Tor
    The Great America!
    Just a few more welds to finish up.....
  19. Apr 5, 2018 at 5:18 AM
    #7119
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    "...you gots a purty pipe Mr. Torspd..."
    Hear this in a Deliverance drawl.
  20. Apr 5, 2018 at 7:30 AM
    #7120
    Torspd
    Tor
    The Great America!
