TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. May 30, 2018 at 8:26 PM
    #7261
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lol! But you are an artist and enjoyed it!
    We'll see. I'll get a better photo for you tomorrow as well.
    Roostfactor[QUOTED] likes this.
  2. May 30, 2018 at 11:31 PM
    #7262
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Why not make a bracket that points the actuator at the flapper arm? I Reduce the variables?
    If its working now I guess my input isnt needed lol but I thought i'd just drop it in here anyways
    :poking:
  3. May 31, 2018 at 5:06 AM
    #7263
    Torspd
    Tor
    The Great America!
    It worked..... until tested. Lol. :p
    Material on order to go back to external. Le sigh.
  4. May 31, 2018 at 9:30 AM
    #7264
    Jstand
    Jstand Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    If you’re talking about going to an external wastegate I just happen to have one for sale. It might be too small but it’s a TiAL 38mm MVS v-band and all of the springs :D
  5. May 31, 2018 at 9:37 AM
    #7265
    Torspd
    Tor
    The Great America!
    Thank you, but I still have my trusty TiAL V44.
    PapaBear and Jstand like this.
  6. May 31, 2018 at 3:02 PM
    #7266
    MrCrowntown
    Alyn
    Ky
    You can make it work if the axial plane of the rod is pointing towards the mounting point.. The deflection of your current setup is all that is screwing you. The guide idea someone else mentioned would be a work around, but just rotating that actuator towards the flapper arm, will solve your issues..
  7. May 31, 2018 at 5:31 PM
    #7267
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Thank you.
    The actuator originally was in direct line of the flapper arm but he had to move it due to clearance issues. That's why I recommended the guide.
    MrCrowntown[QUOTED] likes this.
  8. May 31, 2018 at 5:33 PM
    #7268
    MrCrowntown
    Alyn
    Ky
    It had popped into my head, but I didnt know how to explain what I meant. Your art was helpful !
  9. May 31, 2018 at 5:34 PM
    #7269
    Roostfactor
    TX panhandle
    I was trying to explain it too then said screw it, let's use the old Microsoft Paint.
    Torspd[OP] and MrCrowntown like this.
  10. May 31, 2018 at 6:33 PM
    #7270
    Torspd
    Tor
    The Great America!
    That is an easy fix however, the with the rod end attached, even on the same plane, the exhaust gases can fairly easily push the gate open. I can try it flat for the sake of you guys.
  11. May 31, 2018 at 7:53 PM
    #7271
    Roostfactor
    TX panhandle
    That was probably due to flex.
    :kona:
  12. May 31, 2018 at 9:03 PM
    #7272
    Torspd
    Tor
    The Great America!
    Mechanical advantage, yes. Deflection, not so much.
    These showed up today though. Was too busy to exercise my photography skills. :/
    In preparation for the external wastegate up-pipe.
  13. May 31, 2018 at 9:44 PM
    #7273
    Roostfactor
    TX panhandle
    Looks tasty!
    Torspd[OP] likes this.
  14. Jun 1, 2018 at 5:53 AM
    #7274
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Tacoma & Ferrari ftw
    05Taco4x4 likes this.
  15. Jun 1, 2018 at 6:10 AM
    #7275
    Torspd
    Tor
    The Great America!
    Can't wait to test out my faster paced skill. :D
    As well as the Turbosmart IWG. ;) That is my Ohlins spanner wrench. A friend had to borrow it to adjust the coilovers on a few Ferraris at his shop.
  16. Jun 2, 2018 at 9:18 AM
    #7276
    Torspd
    Tor
    The Great America!
    Well @Roostfactor and @MrCrowntown I'll tell you how last night went.
    To start off, I adusted the rod end down to be parallel with the rod coming out of the wastegate.
    Finger test at back of rod end = very little pressure needed to overcome the tension of the spring. Even with preload. 1psi max.
    Cut 1" wide bar stock, in prep for me removing the turbo today.
  17. Jun 2, 2018 at 9:23 AM
    #7277
    Torspd
    Tor
    The Great America!
    As of this morning, I pulled the truck into the garage. Started disassembly. Proud of myself for how quickly that turbo can be removed. :D
    Noticed that the charge tube going into the throttle body looked a bit curious. As it was touching the radiator overflow container. Whereas there is normally 1/4" of clearance. Following the tubing to both ends, I quickly realized that the portion going into the TB coupling, was dislodged.
    Baaaaaaaarely hanging out of the end of the coupling. The overflow was preventing it from coming out any further. Means that my previously awkwardly angled setup should be working correctly. Time to test, after I lay a bead on the end of the tubing.
  18. Jun 2, 2018 at 9:27 AM
    #7278
    Torspd
    Tor
    The Great America!
    This was the end which feeds the TB.
    Right here is where there was a 1/16" -1/8" gap.
    Re-aligned the tube so that the difference is more evenly split between the two couplings, marked, and ready to lay a bead roll.
    PapaBear, Crom and 05Taco4x4 like this.
  19. Jun 2, 2018 at 9:52 AM
    #7279
    Jstand
    Irving,Tx
    This sounds like one of my story’s before.:D
    Torspd[QUOTED][OP] likes this.
  20. Jun 2, 2018 at 9:56 AM
    #7280
    Roostfactor
    TX panhandle
    Hope it works for ya. Definitely cant build boost with the inlet popped off but you said before you were at 7 psi then dropped to 4. That doesnt sound like an intake leak.
