TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 7, 2018 at 6:04 AM
    #7681
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Nope
  2. Dec 9, 2018 at 3:09 PM
    #7682
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Major shout out and thank you to my man @Lucario Runner ! Myself at the helm and he at the controls, we played with the tune to refine the coal plant.
    First datalog revealed my suspicions. That it was running too rich, but even more importantly, that I had a large exhaust leak from my 3" flex coupling, post turbo.
    It was making the in cab gauge show a 2 point + leaner AFR than the Haltech.
    At that point, we also learned that max boost was 6 psi. So the boost gauge has a 2psi high discrepancy as well. Time for a new Tanabe-USA boost gauge and 3" flex coupling.
    Boost AFR's were in the 9-10 range. Once cleared up, it it pulled very well! Even for such low boost. All the way to 6200.
    Then a function change I had made some time ago, with the operation of the ACIS system, we were able to confirm against his truck's. Got that dialed in accurately now, for proper activation during the torque band.
    Very successful tuning day!
    Xionation, not_nick, richiep and 11 others like this.
  3. Dec 9, 2018 at 3:11 PM
    #7683
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  4. Dec 9, 2018 at 3:11 PM
    #7684
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Well I guess my original text never made it...
    I wish I was closer you guys have too much fun without me. I was there in spirit!
  5. Dec 9, 2018 at 3:12 PM
    #7685
    Torspd
    Tor
    The Great America!
  6. Dec 9, 2018 at 3:13 PM
    #7686
    Torspd
    Tor
    The Great America!
    Now to make some exhaust videos!
  7. Dec 9, 2018 at 3:17 PM
    #7687
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I'm sure it's Brapptastik
  8. Dec 9, 2018 at 3:21 PM
    #7688
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    There a way to do it live!?
  9. Dec 9, 2018 at 3:22 PM
    #7689
    Torspd
    Tor
    The Great America!
    All of the Braaaaaaapppps!!!!
    I have a feeling there is, but I prefer the stored YouTube method.
    SconnieHailer[QUOTED] likes this.
  10. Dec 9, 2018 at 3:23 PM
    #7690
    Torspd
    Tor
    The Great America!
    Were Florida closer!!!
    skyking3 and Hacktacular[QUOTED] like this.
  11. Dec 9, 2018 at 4:01 PM
    #7691
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You can go live on YouTube.
  12. Dec 9, 2018 at 4:14 PM
    #7692
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Awesome news! So happy things are progressing nicely now!
  13. Dec 9, 2018 at 4:26 PM
    #7693
    Torspd
    Tor
    The Great America!
    Interesting!
    Me too! Now to swap in a trans that hasn't been troublesome since I first got it.... Adding it to the list. :frusty:
  14. Dec 9, 2018 at 4:36 PM
    #7694
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  15. Dec 9, 2018 at 5:51 PM
    #7695
    Roostfactor
    TX panhandle
    You had an idea, developed a plan, overcame multiple setbacks, built and fabricated components, revised concepts, tuned, retuned, revised again, r2'd engines, completely revised concepts with lessons learned, and hopefully now you finally have a solid base from which to build from! The trans is just an ancillary, yes it sucks and is more work but I'm hoping the heavy struggle is behind you and the honing process can begin.
    I admire your perseverence!
  16. Dec 9, 2018 at 5:54 PM
    #7696
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    No one has moar perseverance than @Torspd
    I wish I had half the patience and determination he does.
    :bowdown:
    richiep and Roostfactor[QUOTED] like this.
  17. Dec 9, 2018 at 7:28 PM
    #7697
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Just another day in the office mate.
  18. Dec 9, 2018 at 8:09 PM
    #7698
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    I wish I worked in your office. :p
    Torspd[OP] likes this.
  19. Dec 9, 2018 at 8:47 PM
    #7699
    Torspd
    Tor
    The Great America!
    He sees it.
    He knows it.
    @Torspd lives it. Anything worth striving for, NEVR comes easy.
  20. Dec 9, 2018 at 9:26 PM
    #7700
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    This guy was also perseverant as hell.... All hail WileTor
    Roostfactor and Hacktacular like this.
