TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. May 7, 2019 at 3:36 PM
    #7841
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Moved it here. @Sacrifice
    When is the last time you changed your transmission fluid? I run redline oils D4 ATF.
    If that doesn't help, then you may have some transmission issues.
    Could be something with the throwout bearing. Do you have the spacer on the bearing itself, or between where it mounts to the transmission?
  2. May 7, 2019 at 3:41 PM
    #7842
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Super interested in your testing! Like to hear more once you get them in.
  3. May 7, 2019 at 3:43 PM
    #7843
    Torspd
    Tor
    The Great America!
    I will have to make an effort to get before and after videos.
    Regardless, you will definitely be updated. Intake cam swap is fairly painless.
  4. May 7, 2019 at 4:38 PM
    #7844
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Yeah, you better get those cams figured out. We got a race to plan :boink:
    05Taco4x4 likes this.
  5. May 7, 2019 at 5:42 PM
    #7845
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :notsure: used car. Been debating changing fluid. The other day when it was warm it seemed to shift better. So that will be on my to do list. That redline works well?
    Im betting its still the stock clutch. The shifting problem even with the engine off is what gets me.
  6. May 7, 2019 at 8:46 PM
    #7846
    ThomasMore66
    Dallas/Fort Worth & Durango
    Same!
    Torspd[OP] likes this.
  7. May 7, 2019 at 8:52 PM
    #7847
    Torspd
    Tor
    The Great America!
    Truck has Ohlins coilovers, and a nice clutch feel. :p
    Brice likes this.
  8. May 8, 2019 at 7:21 AM
    #7848
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Thats the problem with the lack of variable timing; you have to decide how to phase your cams for either low end or high end power. From what I can tell, your top end is designed for high flow, high RPM's which will reduce scaveging on the low end and therefore reduce low end power. And your bottom is stroked which should give low end power but you'll be hard pressed to get the RPM's needed to really take advantage of the high flow top end. You also dropped compression right? That will make turbo lag more laggy. I suggest a twin turbo with two small quick spooling turbos but in sequential to get that quick spool and max boost. Just sayin.
    The 5VZ has a similar problem but reverse. With an oversqare design, the bottom end is designed for high RPM's at the expense of torque. However, Toyota tuned the top end exclusively for low end torque hence the red line at 5400 rpms.
    Our engines are not in equilibrium. They are fighting themselves.
    05Taco4x4 and Torspd[QUOTED][OP] like this.
  9. May 8, 2019 at 8:20 AM
    #7849
    Torspd
    Tor
    The Great America!
    Good inputs.
    My big bore Goldylocks block has 9.0:1 compression, but OEM cams. Noticeably more low end torque than a factory engine. Just with a larger bore alone, while having the same intake and exhaust components between it and the factory block.
    With that being about .13 liters larger than OEM, and the stroker being .3xx larger, then it is all in the VVT-I or lack there of.
    Both engine have plenty of power all the way to 6200 and 6500.
    Goldylocks spooled the journal bearing Precision more quickly than the stroker currently does. Sadly. Fun when it kicks in though. :D Will be even more fun soon enough.
  10. May 8, 2019 at 9:22 AM
    #7850
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You would think the stroker would spool faster with the extra gasses produced. Same headers / exhaust? It could be that it doesnt rev fast enough. But I'm also of a similar thought on the VVT-i. I know why some people choose to remove it but I don't agree with it. I wish the 5VZ had variable timing.
    Torspd[QUOTED][OP] likes this.
  11. May 8, 2019 at 1:54 PM
    #7851
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    All of us right now that thought we knew alot because we can swap spark plugs and shit.
  12. May 8, 2019 at 3:24 PM
    #7852
    Torspd
    Tor
    The Great America!
  13. May 28, 2019 at 10:23 PM
    #7853
    Talkingmute
    Talkingmute Active Member
    Alaska
    '10 Taco SR5 4wd 5spd Acc. Cab 2.7L
    3" OME, AFE CAI, URD Header, ARB +Warn M8k
    Well I binge-read 393 pages. So I got that going for me. To be honest I thought I would find out what I wanted for my truck...but now I know that no one knows what they want.
    Turbo or supercharger? I don't know anymore. Maybe after all the other mods I can find a turbo diesel swap and be done... since apparently finding mods for the 2tr is like catching a leprechaun riding a unicorn who craps ice cream.
    That being said I do applaud you for earning the patience of a saint and enticing me to read all those damn pages in a day. However, the whiplash I got from you turning around and testing my patience - only to let me down with no forged boost behemoth was probably the best moral of the story for modding you could have crafted
    I guess we're all just watching packages that are a day late and a dollar short of that next mod.
    t('-'t)
    BassAckwards, gordi, Brice and 2 others like this.
  14. May 28, 2019 at 11:46 PM
    #7854
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    But there is a forged boost behemoth.
  15. May 29, 2019 at 3:44 AM
    #7855
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    2TR mods aren't that hard to come by. Check out @05Taco4x4 and @MrCrowntown's build pages. There are 1-2 other boosted 2TRs on here, but their usernames escape me ar the moment.
  16. May 29, 2019 at 4:22 AM
    #7856
    Torspd
    Tor
    The Great America!
    It isn't done yet my friend. This isn't not a movie that rides off gently into the sunset. Leaving you wishing something greater had happened at the end. Just another pause.
    @loginfailed is correct. If is a crazy behemoth. I am just not satisfied with the current performance of the engine. Strictly due to the lack of low end grunt caused by the locked intake cams.
    Those will be starting the process of change, after this weekend. Got to prep for a track day, and it is going to be a VERY busy wrenching weekend. Once the OEM intake cams are in, then I can figure out what to do the the Kelford intake cams. About regrinding them to reduce the aggressive lift to be able to use the VVT-I actuators with them.
    Then is the transmission. The plan is to swap in a built Magnum. Things have settled. Now it is just time.
  17. May 29, 2019 at 4:24 AM
    #7857
    Torspd
    Tor
    The Great America!
    This right here. ^^^ There is one guy who built his, and uses his truck as a drift truck. He hasn't been active for ages.
  18. May 29, 2019 at 4:26 AM
    #7858
    Torspd
    Tor
    The Great America!
    How did I miss this?! Next few weeks bro! You better get your engine and turbo figured out. :D
  19. May 29, 2019 at 9:18 AM
    #7859
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Do you remember the username? I don't think I've ever seen that build.
  20. May 29, 2019 at 10:20 AM
    #7860
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :popcorn: I'd like to see a drifting 2TR too
