TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 22, 2019 at 12:39 PM
    #7961
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    and there is the reason im 99% gunna do it. damn 12k is alot of money. I can always make more
  2. Aug 22, 2019 at 12:40 PM
    #7962
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You have that tree in the back yard too, huh?
  3. Aug 22, 2019 at 12:43 PM
    #7963
    GT7
    Grant
    Phoenix
    2013 DCLB
    I do not unfortunately. I live far below my means on everything except this truck. Im thinking though the ipt transmission build cost 3900 or so, If I didnt get the crank I could have both engine and tranny
    DocME likes this.
  4. Aug 22, 2019 at 1:12 PM
    #7964
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With cams and oversized valves, you'll pick up a lot of power. Enough so that warranting a stroker crank might not be necessary. And that way I am still one of the very few to have a stroker crank. :D
  5. Aug 22, 2019 at 1:22 PM
    #7965
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hey we know you are the baller here. Im thinking I should stay stock size to make things easier. Needs that lopey idle. I can also start working towards my new boost maker with that crank money
    Roostfactor likes this.
  6. Aug 22, 2019 at 1:38 PM
    #7966
    Torspd
    Tor
    The Great America!
    There was a Brian Crower special from one the online vendors. Like 15% off all items, or something. I used that to purchase my stroker crank.
    Definitely get the Age625+ rod bolts. Super high tensile strength.
    Then when you order your pistons, get a thick wrist pin. Decreases deflection at higher RPMs.
  7. Aug 22, 2019 at 1:39 PM
    #7967
    Torspd
    Tor
    The Great America!
    Now just waiting on the cams.
  8. Aug 22, 2019 at 1:41 PM
    #7968
    GT7
    Grant
    Phoenix
    2013 DCLB
    Damn son
    HomerTaco and Sleipnir like this.
  9. Aug 22, 2019 at 1:45 PM
    #7969
    Torspd
    Tor
    The Great America!
    And the cams arrived while I was indisposed of. Lol.
    HomerTaco, Roostfactor and Sleipnir like this.
  10. Aug 22, 2019 at 1:46 PM
    #7970
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    Man that trick only works with food for me
    Torspd[QUOTED][OP] likes this.
  11. Aug 22, 2019 at 2:15 PM
    #7971
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    One of those boxes is 4 me right?
    Sleipnir likes this.
  12. Aug 22, 2019 at 4:00 PM
    #7972
    Torspd
    Tor
    The Great America!
    If you mean that an experience to wrench with me is in those boxes, then absolutely.
  13. Aug 23, 2019 at 10:46 AM
    #7973
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    That's what I'm talking about!
  14. Aug 23, 2019 at 10:47 AM
    #7974
    Roostfactor
    TX panhandle
    I come down and wrench with ya!
    Sleipnir and BassAckwards like this.
  15. Aug 23, 2019 at 6:31 PM
    #7975
    Torspd
    Tor
    The Great America!
    We still need to organize a big meet!
  16. Aug 23, 2019 at 8:34 PM
    #7976
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  17. Aug 24, 2019 at 6:57 AM
    #7977
    Torspd
    Tor
    The Great America!
    :wave:
    HomerTaco[QUOTED] likes this.
  18. Aug 24, 2019 at 6:59 AM
    #7978
    Torspd
    Tor
    The Great America!
  19. Aug 24, 2019 at 7:01 AM
    #7979
    Torspd
    Tor
    The Great America!
    Getting some 3M crystalline tint installed on the Bimmer. Fiiiiiiiiinnnnnnaaaallllyyyyy going to have tint on my beater. Err, I mean daily.
    Then back to the garage to mod the day away!
  20. Aug 24, 2019 at 9:03 AM
    #7980
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Only you would get another turbo car for your "daily" as you build you turbo truck :p3. Haha I'm running around in a 99 accord with 200k.
