TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Oct 10, 2019 at 1:28 PM
    #8061
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Going to post this one in a few places. Since I feel this is a pretty decent sound clip. Better than just trying to describe it.
    https://youtu.be/uBjbz9Kah00
  2. Oct 10, 2019 at 1:30 PM
    #8062
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I have my stock one. Dont know if I want to destroy it but a fun test with an explosive ending sounds like fun in this particular subject.
  3. Oct 10, 2019 at 1:32 PM
    #8063
    Torspd
    Tor
    The Great America!
    I have one spare with a broken port.
  4. Oct 10, 2019 at 1:36 PM
    #8064
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  5. Oct 10, 2019 at 1:36 PM
    #8065
    Torspd
    Tor
    The Great America!
    All of this build up today has worked me up quite the appetite. :sandwich:
    Sleipnir and Roostfactor like this.
  6. Oct 10, 2019 at 1:46 PM
    #8066
    Roostfactor
    TX panhandle
    If we fixed the one port or isolated it from the rest of the system then testing should be pretty simple.
    Seal off intake runners with plate
    Seal all vacuum ports
    Build plate with air nipple for tb seal.
    Apply pressure with gauge slowly until failure.
    May want to hold your desired peak boost for quite a while ensuring long term integrity, then slowly increase until failure to see what max pressure capability is.
  7. Oct 10, 2019 at 1:47 PM
    #8067
    Roostfactor
    TX panhandle
    The calming of nerves is driving the hunger!
    But how can you be so patient not to drive it?
  8. Oct 10, 2019 at 1:49 PM
    #8068
    Roostfactor
    TX panhandle
    Question Tor, why the new cams and what are the differences besides vvti ability?
    You can pm or not say if its top secret.
  9. Oct 10, 2019 at 1:50 PM
    #8069
    Torspd
    Tor
    The Great America!
    Needs an oil change big time. That stuff was already @4k miles, plus now all of that assembly lube. Probably helps out the old oil. Lol.
    Roostfactor likes this.
  10. Oct 10, 2019 at 1:54 PM
    #8070
    Torspd
    Tor
    The Great America!
    The old camshafts weren't properly broken in. They were showing wear. Needed some new ones. Long story, that's just the quickest description. There are no differences. The builder just wasn't thorough enough to determine that VVTi was still possible to retain. With my particular build. Did a lot of testing in my garage, then on the engine, to put a conclusion to that unknown.
    Roostfactor[QUOTED] likes this.
  11. Oct 10, 2019 at 1:56 PM
    #8071
    Roostfactor
    TX panhandle
    Well of course you did :thumbsup:
    Torspd[QUOTED][OP] likes this.
  12. Oct 10, 2019 at 2:12 PM
    #8072
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Wow that sounds nasty. I love it.
    Torspd[OP] likes this.
  13. Oct 10, 2019 at 2:48 PM
    #8073
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Pants are tight.
  14. Oct 10, 2019 at 3:12 PM
    #8074
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Dang I miss the 1gr
  15. Oct 10, 2019 at 3:25 PM
    #8075
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  16. Oct 10, 2019 at 3:53 PM
    #8076
    Torspd
    Tor
    The Great America!
    You'll have twins in no time.
  17. Oct 10, 2019 at 3:54 PM
    #8077
    Torspd
    Tor
    The Great America!
    :smokertransformer:
    yota243[QUOTED] likes this.
  18. Oct 10, 2019 at 3:58 PM
    #8078
    Torspd
    Tor
    The Great America!
    It actually sounds a little different from the static phasers. Quite curious to see how it is once I drive it.
    When a V6 touches the periphery of a V8, it'll do that.
  19. Oct 10, 2019 at 4:41 PM
    #8079
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    lol, get ready for the season of the bow tie powered mustang!
  20. Oct 10, 2019 at 5:00 PM
    #8080
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I want some 0-90 pulls stat :D
    12TRDTacoma and yota243 like this.
