TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jul 19, 2023 at 7:57 AM
    #8981
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    Yeah, like how compact it is. Reminds me of an HKS short runner tubular cast manifold
  2. Jul 19, 2023 at 8:51 AM
    #8982
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    In the video that SIKKY posted, their Camaro engine had it the same way. No tensioner. Just Fuggin tight. There are 4 bolts holding the compressor to the bracket.
    I'll take that as a compliment, to be mentioned as such. :D Pretty cool. It already has somewhat of an unequal length sound. I am curious if this design will change that more so?
    TacoLeeSD[QUOTED] likes this.
  3. Jul 19, 2023 at 9:21 AM
    #8983
    TacoLeeSD
    absolutely! It turned out great. Looking forward to seeing the rest.
    I think the unequal sound will likely stay the same due to the length of the crossover pipe from the other bank. I have always wondered if it’s would be possible to package 2 equal length manifolds like you have made and snake tubing around from both in such a way to make them equal length to the turbo inlet flange. I would try to entertain this but I still don’t have an engine in my truck after 7 years.
  4. Jul 19, 2023 at 12:17 PM
    #8984
    Torspd
    Tor
    The Great America!
    It has been "done" with the kit that PowerFab used to make. It was a lot closer to equal length that is. It looked like spaghetti on the passenger side though.
  5. Jul 19, 2023 at 12:31 PM
    #8985
    Torspd
    Tor
    The Great America!
    It'd just be better to make twins. I really need to do that...
  6. Jul 19, 2023 at 12:34 PM
    #8986
    TacoLeeSD
    @Torspd When installing an engine and transmission into a Tacoma which would you install first engine or transmission? If everything works out I will get my engine back in the next few weeks. It’s been so long that I forgot which one I took out first.
  7. Jul 19, 2023 at 12:50 PM
    #8987
    Torspd
    Tor
    The Great America!
    If the transmission is completely out, the engine.
  8. Jul 19, 2023 at 12:56 PM
    #8988
    Torspd
    Tor
    The Great America!
    7 years. Man.....
  9. Jul 19, 2023 at 1:10 PM
    #8989
    TacoLeeSD
    haha, I know……it’s been rough. Finally realized life is going to continue getting in the way of me putting it together so I took it to Motoiq back in February to be built. Read glad I did. It will be nice to have my truck back up and running by the end of next month.
    Torspd[QUOTED][OP] likes this.
  10. Jul 19, 2023 at 8:11 PM
    #8990
    Torspd
    Tor
    The Great America!
    Wooow. Now that is actually quite cool! Did they do a piece on it?
  11. Jul 20, 2023 at 5:02 AM
    #8991
    Torspd
    Tor
    The Great America!
    Busy day yesterday. Only had a enough time to get this piece cut to shape. Odd fitment, that would have been easier with pie cuts. However, that is the fun of the challenge. Depending on how quickly I get the engine/transmission installed in the BRZ today will determine how much time I have to fuse that section together.
    BassAckwards and TacoLeeSD like this.
  12. Jul 20, 2023 at 8:28 AM
    #8992
    TacoLeeSD
    I am actually not sure, it would be pretty cool if they did!
  13. Jul 20, 2023 at 11:13 AM
    #8993
    Torspd
    Tor
    The Great America!
    I hope that they do.
  14. Jul 20, 2023 at 11:24 AM
    #8994
    Torspd
    Tor
    The Great America!
    What all are you having them do to your engine?
  15. Jul 20, 2023 at 11:27 AM
    #8995
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  16. Jul 20, 2023 at 11:43 AM
    #8996
    Torspd
    Tor
    The Great America!
  17. Jul 20, 2023 at 11:50 AM
    #8997
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  18. Jul 20, 2023 at 12:21 PM
    #8998
    Torspd
    Tor
    The Great America!
    :spy: vs :spy:
    TacoLeeSD likes this.
  19. Jul 20, 2023 at 12:22 PM
    #8999
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  20. Jul 20, 2023 at 12:23 PM
    #9000
    Torspd
    Tor
    The Great America!
    I spy what you did there.
