TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Sep 21, 2024 at 5:53 PM
    #9241
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Truck started farting recently. Like I am fueling it with a mix of ranch style and refried beans. Farted so much that is blew out a seam.
    TnShooter likes this.
  2. Sep 21, 2024 at 6:07 PM
    #9242
    TacoLeeSD
    TacoLeeSD Well-Known Member
    2009 TRD sport/4 door/long bed/magnet metallic gray
    6 inch Procomp lift/ king shocks/ 35 inch toyo mud terrains/ 20 inch XD spy wheels
    That’s a bummer, those bellows are really nice looking (nice job on the welds btw) but I have found that they always crack. Instead I go with the ones that are braided over the bellows and have never had one crack.
    Torspd[QUOTED][OP] likes this.
  3. Sep 21, 2024 at 9:48 PM
    #9243
    Torspd
    Tor
    The Great America!
    Ditto. All prior construction has been with braided couplings.
    TacoLeeSD[QUOTED] and colinb17 like this.
  4. Sep 22, 2024 at 9:40 AM
    #9244
    Torspd
    Tor
    The Great America!
    On that note, I have found a few places that sell Made in USA bellows. www.reidwashbon.com bring one of them. They also sell inconel bellows. I would have to look up which class of filler rod that would take to weld that to stainless. Out of curiosity.
  5. Sep 22, 2024 at 10:02 AM
    #9245
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Inconel 625, same as what you'd use on an inconel/inconel joint. Treat the weld itself like an inconel weld as far as prep and post weld cleaning. Oxidation is a bit of a pain to clean after it's cooled so clean it hot. Some people say the different melting points can make it difficult, but those two are closer than a mild steel/stainless steel joint (which is not difficult), so I tend to question those folks.
  6. Sep 22, 2024 at 4:22 PM
    #9246
    Torspd
    Tor
    The Great America!
    Very good to know. Thank you. :thumbsup:
  7. Oct 8, 2024 at 5:24 PM
    #9247
    hayrider2.0
    hayrider2.0 Over the hill and going down fast!
    Hey You
    2 Centimeters from Hell 200 Miles from Water
    05 & 07 White Reg. Cabs w/ sticks
    05 Magnuson 07 LS Swapped
    Mark,
    Here you go a brand new 2015 X-runner!!
    colinb17 likes this.
  8. Oct 9, 2024 at 12:51 PM
    #9248
    Torspd
    Tor
    The Great America!
  9. Oct 9, 2024 at 12:56 PM
    #9249
    Torspd
    Tor
    The Great America!
    This is far better.
  10. Oct 17, 2024 at 5:39 AM
    #9250
    Torspd
    Tor
    The Great America!
    Had a short window to work on my exhaust last night. Which was then rushed even more when I was called back into work. Time frame aside, I was able to get the new flex coupling in, but not a lot of photos. Here is the old bellow and it's crack. Then a photo of the tubes prepped, awaiting a wipe down.
  11. Oct 28, 2024 at 8:12 AM
    #9251
    Torspd
    Tor
    The Great America!
  12. Oct 28, 2024 at 9:25 AM
    #9252
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Gauge issue. Aem will fix and and cost about the same as a new one. Speaking from experience with same type of gauge.
  13. Oct 28, 2024 at 9:31 AM
    #9253
    Torspd
    Tor
    The Great America!
    Good thing that I have a new one waiting in the cart. I had been staying out of the throttle for a good while. Then I found the exhaust leak and was relieved that I had been, but also quickly realized that the gauge/sensor were still acting the same.
    Referenced against the Haltech, and the AFRs were as intended.
    At least the wiring won't have to be messed with, and I'll be left with spare wire.
  14. Oct 28, 2024 at 10:00 AM
    #9254
    Lucario Runner
    Robert
    06 Toyota 4Runner
    The older afr gauges seem alot more reliable. It could be the initial batch had a bad board or something like that for the newer afr series.
  15. Oct 28, 2024 at 10:27 AM
    #9255
    Torspd
    Tor
    The Great America!
    Technical difficulties
  16. Oct 28, 2024 at 1:45 PM
    #9256
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    My 10 year old AEM is going strong. Always thought it was weird though, that on its startup sequence is flashes "POO" for a second.
  17. Oct 28, 2024 at 5:47 PM
    #9257
    Torspd
    Tor
    The Great America!
    Well at least yours isn't POO-POO.
  18. Oct 28, 2024 at 8:06 PM
    #9258
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  19. Nov 11, 2024 at 5:47 AM
    #9259
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    BradyT88 likes this.
  20. Nov 22, 2024 at 12:14 PM
    #9260
    Torspd
    Tor
    The Great America!
