TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Aug 17, 2013 at 1:09 PM
    #1301
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I remember when legislators were trying to make Black cars illegal in CA because they use too much gas to cool down, since they absorb more heat. :facepalm:Love to visit there, but love to live here.
    When using the ProEFI 128, it is MAP based. Speed density, but self tuning once the base parameters are set, to maintain those commands as closely as possible. Just way easier to tune with. I have a 5 BAR MAP sensor, even though I was only using 2 BAR. Resolution might be a bit vast for just 2 BAR, but it leaves room to grow, and it certianly will be getting more usage once things are all back. :cool:
    The OEM MAF sensor reaches Max Duty Cycle around 415-430 g/s. Once you pass that, even with something like an X-1 or UCON, you are in need of a MAF sensor that has a higher resolution for 5.0 volts. I don't know if Gadget has added in programming for the UCON to run a different MAF sensor or not. The X-1 had the option to run a GM MAF sensor. I would bet money that Gadget did install some form of programming though as he likes to be prepaired for the future. Question is, which MAF will work? I don't know. What I do know is that MAP sensors are easier to come by and use. :D
    I made sure to have mine plug n play, so that in the event i need to have it back to stock (such as right now), it will be non interfering.
  2. Aug 17, 2013 at 1:12 PM
    #1302
    Torspd
    Tor
    The Great America!
    Stand up. We are all equals here. :cheers:
  3. Aug 17, 2013 at 1:18 PM
    #1303
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^Woohoo! :D
  4. Aug 17, 2013 at 1:35 PM
    #1304
    Torspd
    Tor
    The Great America!
    Yes I am. :p Think about it. Straighten out the fuel rail, and it is the exact same as a 4 cyl. Except with two more. Just like a 2JZ.
  5. Aug 17, 2013 at 2:28 PM
    #1305
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :thumbsup:
  6. Aug 31, 2013 at 2:18 PM
    #1306
    Torspd
    Tor
    The Great America!
    Kelford Cams paid for in full. Dropped off my CF hood to be painted and matched to the rest of the truck. :spy:
  7. Aug 31, 2013 at 8:26 PM
    #1307
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    No visible carbon = not racetruck! dude what are you going to do when you don't have any truck stuff to worry/think about? find more truck stuff to worry about I guess haha
  8. Aug 31, 2013 at 8:34 PM
    #1308
    Torspd
    Tor
    The Great America!
    Build a real flux capacitor. Then go back in time and save money and time on this build. :laugh:
    Maybe build a Rodin coil or s SEG. That looks like a fun challenge. ;)
  9. Aug 31, 2013 at 8:42 PM
    #1309
    SconnieHailer
    Marc
    into perpetual/free energy theories!? that does look kinda fun :D
    Marty Mcfly is strong in this thread, it could happen.
  10. Oct 7, 2013 at 5:03 PM
    #1310
    SuperJakeTheSnake
    SuperJakeTheSnake What is this place?
    Jacob
    Jacksonville NC
    02 Toyota Tacoma Prerunner
    :cool: Awesome build man! Any updates on built engine? Oh and a bump for your build thread, kinda died out here lately.
  11. Oct 7, 2013 at 6:03 PM
    #1311
    SconnieHailer
    Marc
    x2 any updates :cool:
    also tor are you gonna get to the F1 race at COTA November 15-16-17? Wish I could make the time to come down!
  12. Oct 7, 2013 at 8:26 PM
    #1312
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  13. Oct 7, 2013 at 8:43 PM
    #1313
    BradyT88
    BradyT88 Well-Known Member
    Did Tor get his motor back finally and has been busy installing and tuning it for the last month and that's why this thread has been dead for about 5 weeks now? Haha
  14. Oct 7, 2013 at 11:16 PM
    #1314
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    He's just putting in work to improve the already improved mods. I'll leave it at that. ;)
  15. Oct 8, 2013 at 7:58 AM
    #1315
    Torspd
    Tor
    The Great America!
    Thanks man! Been really busy, and held back by some mods, to where I couldn't do other mods, until one was finished. Namely, the hood..... that took far to long.
    I really hope to! I have family right close to the track, so I already have the perfect place to stay. :cool:
    Not back yet, but I do have a good update. :D
    :spy: vs :spy:
    ^^^ He is in the know.
  16. Oct 8, 2013 at 8:00 AM
    #1316
    Torspd
    Tor
    The Great America!
    Some might know how poor a condition the hood was in. If not, in my MSR track video, it is very obvious. The clear had had it. I was finally able to get it fixed.
    Three weeks later.................................
  17. Oct 8, 2013 at 8:09 AM
    #1317
    SconnieHailer
    Marc
    Hope you can get to the race too! Please post pictures :D :cool:
  18. Oct 8, 2013 at 8:20 AM
    #1318
    BradyT88
    You have a skewp! Is that an OEM hood or an aftermarket one. I never realized you had a scoop until now. haha Just rewatched the track video and it is there just hard to see at that angle.
  19. Oct 8, 2013 at 8:35 AM
    #1319
    Torspd
    Tor
    The Great America!
    Of the race or my truck?
    VIS Carbon Fiber hood. Painted in OEM BSP. Got to watch the video where the camera is on top. :p ;)
  20. Oct 8, 2013 at 8:38 AM
    #1320
    Large
    Large Red
    Looks better without a hood, just sayin :anonymous:
    GT7 likes this.
