TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Nov 1, 2013 at 1:32 PM
    #1381
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    Solo Motorsports did the work
  2. Nov 1, 2013 at 5:56 PM
    #1382
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Thankyou for the clarification sir. :thumbsup:
  3. Nov 3, 2013 at 4:42 PM
    #1383
    Torspd
    Tor
    The Great America!
    Purchased a Mother's brand headlight restore kit. Came with a compound buffing wheel that you attach to the drill. About three times on each headlight, and wow. Quite impressed for the ease of work needed. Took my time on each pass, and made sure to overlap each row and column of movement. Doesnt look brand new, but doesn't look like they have 125k miles any more either.
    I am pleased with the outcome.
    Lucario Runner came down from SA as well. Went to a Ferrari meet earlier, then figured out how to do a slimilar oil cooler setup on his T4R as well.
    Doesn't look to be to much different than how mine is.
  4. Nov 4, 2013 at 12:20 PM
    #1384
    TurboHilux
    TurboHilux Member
    Leon
    Australia
    06 Turbo Hilux
    Tor two quick questions.
    When you installed your aeromotive stealth pump were you still running it as a two speed pump like the factory one, or did it just run flat out? (The hilux pump is two speed I assume yours is too.)
    In your travels when looking for the t56 and suitable transfercase did you ever come across a transfercase with low range to suit the t56 with a left hand drop?
  5. Nov 5, 2013 at 6:33 AM
    #1385
    Torspd
    Tor
    The Great America!
    It is installee with the factory fuel pump wires, in the fuel tank. Cut and spliced. So it is dual rate, per factory setup.
    As for the transmission, the only searching I did was for an AWD T-case. Not one which has low, or additional low gear selection. In fact, it isn't even selectable by manual actuation to go from AWD to RWD.
    It does however, have that ability, when a vacuum source is attached.
    Aside from all of that, did quite a bit of research yesterday, with the good aid of Lucario Runner, to find a different manufacturer for my 14" rotors. WILWOOD is out of the question. Their rotor to hat bolt pattern uses 12 bolts, while ROTORA's rotor uses 10. AP Racing is the same as Wilwood.
    Made a little headway with Stop Tech, but need to verify some details with the P/Ns which we received yesterday. Other than that, only last choice is Brembo, since we didn't look at their parts catalog.
    All of the resaerch is due to the fact that the ROTORA rotors are $350 each. Not including the hats. Quite expensive.
    Also dropped off a wheel at SABS to have a dent fixed.
  6. Nov 5, 2013 at 8:56 AM
    #1386
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    What about endless rotors?
  7. Nov 5, 2013 at 9:09 AM
    #1387
    Torspd
    Tor
    The Great America!
    Totally forgot about them as well. Damn. Thanks!
    Did get some info from a new source, but don't remember how to spell the name and don't want to butcher it. Going to look through that email and do some comparing. Hsve to look through Endless' catalog too now. :thumbsup:
  8. Nov 5, 2013 at 9:16 AM
    #1388
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    No need, just get a parachute. Advanced planning is required though as it's only good once.
  9. Nov 5, 2013 at 9:19 AM
    #1389
    BradyT88
    BradyT88 Well-Known Member
    :rofl:
  10. Nov 5, 2013 at 9:50 AM
    #1390
    Torspd
    Tor
    The Great America!
  11. Nov 5, 2013 at 10:10 AM
    #1391
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You know, I am going to take this back. This solution is definitely NOT high-tech enough for your build.
    I am now thinking that you need a reverse-turbo setup. You can either set it up to direct the pressure back into the cylinders on decelleration such that you get killer engine braking, or you could direct the turbo forward on decel such that it acts like thrust reverser.
    How about that?? :eek:
    JK, I like your build thread simply because it shows what can/can't, or should/shouldn't, be done on a Tacoma. Doesn't matter what you own, someone, somewhere will push the limits to see what it's capable of.
  12. Nov 5, 2013 at 12:12 PM
    #1392
    Torspd
    Tor
    The Great America!
    I think the space-time continuum might inversely proportionally implode upon itself! Great Scott, that would be something!
    Or....it might just work. I'll sacrifice Lucario Runner for the first test. He's the expert with those sorts of things. Lol
  13. Nov 5, 2013 at 12:39 PM
    #1393
    Torspd
    Tor
    The Great America!
  14. Nov 5, 2013 at 1:24 PM
    #1394
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  15. Nov 5, 2013 at 2:02 PM
    #1395
    Darthyota
    Alberta
    Blown BSP X-Runner
    you also forgot about brembo
  16. Nov 5, 2013 at 2:42 PM
    #1396
    Torspd
    Tor
    The Great America!
    No we didn't. :thumbsup:
    You got this . :devil:
  17. Nov 5, 2013 at 6:49 PM
    #1397
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    What did I miss... :confused:
  18. Nov 6, 2013 at 5:32 AM
    #1398
    Torspd
    Tor
    The Great America!
    My money tree shedding. Lol
  19. Nov 6, 2013 at 7:02 AM
    #1399
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    lol, that's a graceful way to put it.
  20. Nov 6, 2013 at 11:47 AM
    #1400
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Howdy Toe!
    :wave:
