TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Nov 26, 2013 at 10:15 AM
    #1481
    rcfreak201
    rcfreak201 Well-Known Member
    Gahh I just wanna see this thing rip! Your one patient man..lol
  2. Nov 26, 2013 at 10:31 AM
    #1482
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Inside my mind, I feel like this....:goingcrazy:
    At least it is almost finished for MSR. Which has still been a heck of a challenge.
    Cams should be at Darton by the end of this week. Been some unexpected delays in that realm. Then we can finally get that engine finished.....
  3. Nov 27, 2013 at 5:11 AM
    #1483
    Torspd
    Tor
    The Great America!
    Test drive went flawlessly last night.
    Homer, if you thought it was easy to take off in 1st last time, you will be amazed how easy it is now.
    I need to adjust the clutch pedal, though. Doesn't reach the start sensor anymore, strangely. Luckily for clutch start cancel button.
    A few punch list items to take care of before the race, and it will be done!
    On to wrenching on Lucario Runner's T4R and my roommate's tC. Getting theirs ready as well.
  4. Nov 27, 2013 at 6:13 AM
    #1484
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :cool:
  5. Nov 27, 2013 at 7:44 AM
    #1485
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    :woot:
    what does Jeff's car need?
  6. Nov 27, 2013 at 8:50 AM
    #1486
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    New front boots. One is installed now. And then oil and trans fluid change. Lucky for me the weather is warming up
  7. Nov 27, 2013 at 9:00 AM
    #1487
    Torspd
    Tor
    The Great America!
    Replacing the boots/isolation pads that the springs rest against at the top of the strut. Then the fluid change.
    Rob tapped his Greddy oil cooler sandwich plate fittings last night. From 1/8PT to 1/8NPT. Now it is install time, and fabbing up some mounting brackets for the cooler.
  8. Nov 27, 2013 at 9:24 AM
    #1488
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    doin work!
    yeah, Rob, good thing you weren't down for the weekend. way too cold and wet.
  9. Nov 27, 2013 at 9:29 AM
    #1489
    Lucario Runner
    Robert
    06 Toyota 4Runner
    It was pretty cold in Sa too :/ to the point I had to plug in my powerstroke to start it. The boost was nice though
  10. Nov 28, 2013 at 6:45 PM
    #1490
    BradyT88
    BradyT88 Well-Known Member
  11. Nov 28, 2013 at 8:44 PM
    #1491
    Torspd
    Tor
    The Great America!
    Hahaha. That is awesome! Something like that down here. ;)
  12. Nov 28, 2013 at 9:46 PM
    #1492
    BradyT88
  13. Nov 29, 2013 at 2:41 PM
    #1493
    Torspd
    Tor
    The Great America!
    :cheers: to you as well Brady.
    Had to drop the transmission again yesterday. Was having a very difficult time engaging gears, as well as the fact the clutch pedal had a very limited stroke.
    Upon tinkering with the TOB, we noticed that it was extremely hard to extend and depress by hand. Opened it up, and found a few large metal shavings inside. Not sure how they got there, but there was clear scoring where a piece was wedged between moving parts. Luckily in an area that wasn't affecting seals.
    Cleaned it up, double checked measurements, & re-installed it last night. Works like a charm now. So fluid and smooth. Unbelievable. Lucario Runner and I put in some serious work yesterday.
  14. Nov 29, 2013 at 5:05 PM
    #1494
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  15. Nov 29, 2013 at 5:23 PM
    #1495
    BradyT88
    Glad to hear it didnt do any harmful damage!!:woot: is MSR tomorrow?
  16. Nov 29, 2013 at 6:25 PM
    #1496
    Lucario Runner
    Robert
    06 Toyota 4Runner
    yes msr is tomorrow! :D
  17. Nov 29, 2013 at 6:27 PM
    #1497
    BradyT88
    :cool: I wanna see some sweet vids!
  18. Dec 2, 2013 at 4:36 AM
    #1498
    Torspd
    Tor
    The Great America!
    Vids are painfully slowly uploading. Annnnd for some reason they videos play very glitchy on my computer. And power supply burnt up last night as well.
    We flipped one video yesterday, then uploaded it. That in itself took something like 6 hourse. Phuuuu...
    All 5 of us went with out issues, and and 5 came back the same. Also, the oil cooler kits which I installed on my truck and Lucario Runner's T4R, worked very well.
    Took A LOT of work to get our vehicles ready for the event. Up until about 12:30 AM Saturday morning wrenching, of the race day. But we did it and it was an absolute blast!
  19. Dec 2, 2013 at 5:44 AM
    #1499
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    million doll hair question.........who won? :stirthepot:
  20. Dec 2, 2013 at 6:31 AM
    #1500
    Torspd
    Tor
    The Great America!
    In the Novice DE, of the 5 of us, Grumpy in his SWB XR was laying down the fastest lap times. (The most power and skill combined.) I was putting down the 2nd fastest times (Good skill, but lowest power 1GR there.) 3rd was Jeff, in the stock engine tC (great skill & but lowest overall power). Then Danny was 4th. (Most power, and novice skill. He has greatly improved though.)
    Lucario Runner. ....Excellent driving skill, and held his own very well against a pack of highly powered cars. Best he could do considering that most the cars in his class have a lot more power.
