TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Dec 5, 2013 at 10:47 AM
    #1541
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i should come to the track :p
    i'd probably drag my side view mirror on the ground before i lifted a tire :anonymous:
    you sit at about the same height as grumpy right now?
  2. Dec 5, 2013 at 10:48 AM
    #1542
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Gangsta
  3. Dec 5, 2013 at 10:52 AM
    #1543
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    somebody say body roll????
  4. Dec 5, 2013 at 12:12 PM
    #1544
    BradyT88
    BradyT88 Well-Known Member
    You need some ORI's man! haha Crank the pressure up in the lower chamber and it not only helps them flex better, but reduces body roll! I had very little body roll until it got about 50* colder outside. That was enough to lower my pressure enough that I have had a little more body roll the last couple days.
  5. Dec 5, 2013 at 12:18 PM
    #1545
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    no point in me getting them right now, with the LT swap coming up. i'll look into some 10s as an option when that time comes though.
  6. Dec 5, 2013 at 12:23 PM
    #1546
    BradyT88
    I know. haha I was making a joke more or less. Poorly played on my part.
  7. Dec 10, 2013 at 3:39 PM
    #1547
    Lucario Runner
    Robert
    06 Toyota 4Runner
  8. Dec 10, 2013 at 6:43 PM
    #1548
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  9. Dec 10, 2013 at 7:06 PM
    #1549
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes!!!!! We just need a hill.....where are we going to find one in Houston.....?
  10. Dec 10, 2013 at 7:14 PM
    #1550
    Lucario Runner
    Robert
    06 Toyota 4Runner
  11. Dec 10, 2013 at 7:43 PM
    #1551
    Torspd
    Tor
    The Great America!
  12. Dec 10, 2013 at 7:58 PM
    #1552
    Torspd
    Tor
    The Great America!
    Edit***** goofed and forgot to add the video. In the previous post now.
  13. Dec 10, 2013 at 7:59 PM
    #1553
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Thats when I got kicked out of the novice class for being too fast. :D I still wasn't able to use your tires to its full potential due to that and the rain. :(
  14. Dec 11, 2013 at 4:52 AM
    #1554
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ...every overpass... :p
  15. Dec 12, 2013 at 10:11 AM
    #1555
    Torspd
    Tor
    The Great America!
    Well.....just purchased my Christmas present to myself. Lol.
    http://www.theboostlab.com/store/products/Borg-Warner-EFR%2d9180-T4-1.05-A{47}R.html?fullSite=1
    With that in hand, I can finish up some touches on the turbo kit. Such as routing the wastegate dump tube back into the exhaust. Had to have this piece first, so that incase changes were necessary to the down pipe, there wouldn't be any going back for double work.
    Then going to upgrade again, to this.
    http://www.treadstoneperformance.co...prodname=Walbro+E85+Approved+400LPH+Fuel+Pump
  16. Dec 12, 2013 at 10:18 AM
    #1556
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :popcorn:
    it always catches me off guard, how small fuel pumps actually are.
  17. Dec 12, 2013 at 10:26 AM
    #1557
    BradyT88
    So what do you expect the full spool time to be on this sucker haha? Monster turbo lag? I assume on the track you will have the RPM high enough most of the time to maintain the boost you want.
    I was thinking the same thing!!
  18. Dec 12, 2013 at 10:31 AM
    #1558
    SconnieHailer
    Marc
    mmmm nice lookn snail Tor!
  19. Dec 12, 2013 at 10:33 AM
    #1559
    Torspd
    Tor
    The Great America!
    Actually, we have done some calculations. Soooo, with the extrememly light turbine wheel, ball bearings, and increased displacement, it should still spool up at the same rpm as my smaller journal bearing turbo. Who doesn't spin freely at all. When I get this one in, I'll make a quick video of the differences in how easily they spin.
    If I remember correctly, the turbine wheel of this turbo is so much lighter that it is said to spool 30% more quickly than an inconel turbine wheel.
    Edit**** Thank you Sconnie.
  20. Dec 12, 2013 at 10:36 AM
    #1560
    BradyT88
    That is awesome!
