TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 15, 2014 at 7:19 PM
    #1721
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I knew it! :spy:
  2. Jan 17, 2014 at 8:19 AM
    #1722
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  3. Jan 17, 2014 at 8:21 AM
    #1723
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  4. Jan 17, 2014 at 8:47 AM
    #1724
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :rofl:
    And yes, to the interwebz, it is still clouded in a mysterious fog. :p
    It is really nothing to brag about. Simple in form and function. Going to sell this setup, and redo another so that the turbo will sit more properly under the hood. The current setup is compatible with the Precision Turbos, up to the 6766 size.
  5. Jan 17, 2014 at 9:32 AM
    #1725
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    ^ so you're saying I could get one of these fancy 1GR turbo manifolds soon and be boosting before I know it?!
  6. Jan 17, 2014 at 9:33 AM
    #1726
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    :rofl:
  7. Jan 17, 2014 at 9:51 AM
    #1727
    Torspd
    Tor
    The Great America!
    You want the manifold or the kit? o_O
  8. Jan 17, 2014 at 4:40 PM
    #1728
    SconnieHailer
    Marc
    wish I could go for it :pout: more-less a hopeful comment on my part. I'm planning on springing for the 2012+ equal length urd headers if/when Gadget gets em fabbd up. So i'll likely be supercharged down the line since i'll already have nice exhaust mani's...
    Are you working to turn this into a "1gr turbo kit" when yours is up and running well?
  9. Jan 17, 2014 at 4:49 PM
    #1729
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    aren't those headers currently available? or have they been placed on back order
  10. Jan 17, 2014 at 4:50 PM
    #1730
    SconnieHailer
    Marc
    they are for years before 2012... :( in 2012 they started putting some dumb air injection part on the header to heat up the cats quicker on startup, boo!
  11. Jan 17, 2014 at 4:55 PM
    #1731
    Torspd
    Tor
    The Great America!
    Already did that. Helped PowerFab, here in Houston, create a kit.
    Mine was the predecessor to theirs. However, since their fabricator left, I believe that he took the jigs with him.
  12. Jan 17, 2014 at 4:59 PM
    #1732
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    :mad::eek::(
  13. Jan 17, 2014 at 5:00 PM
    #1733
    Darthyota
    Alberta
    Blown BSP X-Runner
    and theres no way to remove that system from the engine?
  14. Jan 17, 2014 at 5:01 PM
    #1734
    Torspd
    Tor
    The Great America!
    At least I still have his #. :cool:
    I bet there is. Just that no one has done it yet.
  15. Jan 17, 2014 at 5:04 PM
    #1735
    Darthyota
    Alberta
    Blown BSP X-Runner
    tor you should see if you can buy the jigs off him if he has them
  16. Jan 17, 2014 at 5:13 PM
    #1736
    Torspd
    Tor
    The Great America!
    That is actually a pretty damn good idea. I'll talk to him the next time he is down.
  17. Jan 17, 2014 at 11:02 PM
    #1737
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :popcorn:
  18. Jan 18, 2014 at 6:32 AM
    #1738
    Torspd
    Tor
    The Great America!
    Found the reason for the air bubble, in the killer glass radiator hose. The worm gear hose clamp, which is meant to hold the feed coolant line to the turbo, was broken. Had a broken "tooth" on the band.
    I had move my truck back to bleed the clutch. There was a puddle of coolant on the floor. Checked over everything, and found that hose was very loose. Doubled up with two new hose clamps, and it was good to go. Topped it off, and ready for more boost-age.
    Btw, where is the location of that bike race which you are participating in?
  19. Jan 21, 2014 at 10:14 AM
    #1739
    Torspd
    Tor
    The Great America!
    Took some pictures, which I need to upload. Axle seals on both sides have worn grooves into the metal, so that they no longer seal properly. Just a few months ago, I replace a worn axle seal on the driver side, as well as drum brakes on both side.
    Pulled out the axles to be able to remove the 3rd member. Getting the TruTrac installed. Drums on both sides are saturated. Again. :facepalm:
    TruTrac will be installed regardless. It is way past due.
    Fixing the sealing problem, well.....I not yet sure if replacing the bearing will fix it, or a thin sleeve is necessary, or something else?
    As a new side quest, due to this latest developement, I decided to get new upgraded rear axles. Woot Woot! Need to package them up and send them out
  20. Jan 21, 2014 at 10:18 AM
    #1740
    Phil Dammit
    Your Mom
    Tempe, Arizona
    My truck completely changed after installing the hino. Took a little getting used to after the install.
