TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Jan 29, 2014 at 1:42 PM
    #1841
    Clifford
    Clifford Well-Known Member
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Only motor to be built like this?
    I kid, Mark pulled out all the stops.
  2. Jan 29, 2014 at 1:46 PM
    #1842
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Does Mark = Tor?
    And how do you think your built motor would fair on a daily N/A setup, power curve and abuse wise for a daily wheeling rig?
  3. Jan 29, 2014 at 1:48 PM
    #1843
    BradyT88
    BradyT88 Well-Known Member
    Yes Mark = Tor
  4. Jan 29, 2014 at 1:49 PM
    #1844
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Learn something new everyday
  5. Jan 29, 2014 at 2:20 PM
    #1845
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    Neither one of our motors are built for NA power, so hard to answer that question.
  6. Jan 29, 2014 at 3:33 PM
    #1846
    Phil Dammit
    Your Mom
    Tempe, Arizona
    That's what I thought.
  7. Jan 29, 2014 at 3:48 PM
    #1847
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well I cannot say that you wouldn't need the extra mods because this engine will be the end all....it likely won't be the case. Buuuuut VVV
    If another person were to build a stroked engine (4.3L) , and leave the compression stock @ 10:1, or sleeve then stroker and over-bore up to 4.6L w/10:1, then there should theoretically be a huge torque gain across the whole rpm range. That wouldn't require any additional modding really. Unless you already had, or wanted to improve upon the V.E. more-so.
    I am not referring to adding cams or anything else. Once you go inside, the wallet is the limiting factor of reality.
    Mine was built with barely an over-bore, and 9:1 compression. Built with lower compression due to the future addition of cylinder filling boost. Trying to make diamonds yo. Lol... Mine has cams custom ground to match the type of boost, gearing, tire/wheel size, RPM range, and end power goal. Mine has a lot more variables than a potential "basic build" for the daily wheeling rig.
    More liters off of an already torqy-ish engine, which responds well to basic bolt-ons, only means even greater gains, and would be a beast even if in a more simplified version than mine. :D
    To get some sort of idea and knowledge on the subject of what this build of engine will do in N/A, I am going to dyno it in N/A trim. That is the easiest way to hypothesize future boost gains. Also lets everyone know what a lower than stock compression, N/A, 4.3l(ish) stroked 1GR can do. As that will be the reference from which a stock compression sister would be capable of.
    I was told this long ago, by Brian Crower (BC). That the peeps in the U.A.E. were seeing gains of 100 hp with the stroker kit. In my excitement, I forgot to ask whether N/A or boosted. :(
    :spy:
  8. Jan 29, 2014 at 6:12 PM
    #1848
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    :bowdown: just finished reading the whole thing..... Oh. My. God.... and if i had more gas money id bring the engine to you.... and hang around for a track day...
    your making me jelly that there no real race tracks in MD, only drag strips or dirt tracks :(
  9. Jan 30, 2014 at 11:36 AM
    #1849
    Torspd
    Tor
    The Great America!
    That would be awesome. Lol. ;)
    Track day is amazing. Especially putting the hurt on people who have cars that are on paper "better". Then the cherry on top is when they talk about reasons why our vehicles are "so much faster." :laugh:
    Lucario Runner knows what I am referring to.
    Here is the good stuff. Cam specs.
    Total duration 265 intake, 270 exhaust.
    Duration at 1mm valve lift, 225 inlet, 231 exhaust.
    Total valve lift with lash set, 10.55mm inlet, 10.75mm exhaust.
  10. Jan 30, 2014 at 11:40 AM
    #1850
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    That driver mod though haha.
  11. Jan 30, 2014 at 12:03 PM
    #1851
    Torspd
    Tor
    The Great America!
    Gets them every time. :laugh: And their expressions = :confused:
    Rob, Jeff, and I should all have some new goodies to aid in traction, handling, performance, or all three come March 29th's event. ^_^
  12. Jan 30, 2014 at 12:46 PM
    #1852
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Just wait i have lots of goodies. ;)
  13. Jan 31, 2014 at 2:32 PM
    #1853
    TurboHilux
    TurboHilux Member
    Leon
    Australia
    06 Turbo Hilux
    Tor, I may have missed it in earlier posts but are you going to keep the VVti or lock it up or get hold of some adjustable cam gears.
    On that APR fuel rail are the injectors still all in series like the factory rail? When I upgraded my fuel system my new regulator had two inlet ports so rather then just plug one I plumbed my standard fuel rail up as two banks of 3 injectors, it was a cheap way of flowing a lot more fuel through the standard fuel rail.
  14. Feb 1, 2014 at 1:20 PM
    #1854
    Torspd
    Tor
    The Great America!
    You know, I had talked with Jim in great detail about some form of a phase limiter for intake cam gears. Then time passed and had planned on no cams. Then the realization that I had a stroker crank came into play. So back to the cams for the engine. Forgot about the discussions we had had previously.
    Means I need to see what he says with the clearances, come next week.
    I was planning on doing each bank independently, but then decided to keep things simple.
  15. Feb 4, 2014 at 9:45 AM
    #1855
    Torspd
    Tor
    The Great America!
    Talked with Darton yesterday about that. It had slipped both of our minds, so thank you for reminding us. :thumbsup:
    Here is a good engine build which loosely parallels mine.
    2JZ being built for 800 whp
    http://www.motoiq.com/MagazineArticl...nder-Head.aspx
    ^^^ That gives an idea of the cam similarities. At least on the exhaust duration.
    Here is another, showing the head studs which I am after.
    http://www.motoiq.com/MagazineArticles/ID/3004/PageID/6028/Project-Toyota-Supra-MKIV-Part-5-Thermal-coating-and-wrapping-and-engine-assembly.aspx
    Note that the heads use bearing caps to retain the cams. As well as bucket shims (changed to MR2 bucket shims from stock). Both of those implementations are the same as the 1GR's.
  16. Feb 4, 2014 at 10:07 AM
    #1856
    Torspd
    Tor
    The Great America!
    Well, just got word from Moser. It's a no go, due to the step-up bearing race.
    Back to square one. Per say.
  17. Feb 4, 2014 at 10:47 AM
    #1857
    Clifford
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    time for complete axel swap?
  18. Feb 4, 2014 at 11:33 AM
    #1858
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    did you ever look into the dimensions of the fj cruiser axle shafts?
  19. Feb 4, 2014 at 12:16 PM
    #1859
    Torspd
    Tor
    The Great America!
    Possibly. Maybe a Currie, since they already built one for the TRD XR.
    I was told that they have a different part number from the Tacoma, by my contact at Toyota. But I do not have the specifics between the two. I think that I also read recently that there is a difference, from a link recently posted in this thread.
  20. Feb 4, 2014 at 3:58 PM
    #1860
    Darthyota
    Alberta
    Blown BSP X-Runner
    If you do a complete axle swap for 9s and 8.8s are dirt cheap and lots of aftermarket support and are fairly strong with out tons of weight
