TORSPD: NEVR
Discussion in '2nd Gen. Builds (2005-2015)' started by Torspd, Feb 9, 2012.
  1. Feb 24, 2014 at 8:46 AM
    #1881
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    wait, he has a budget? :laughing:
  2. Feb 24, 2014 at 10:33 AM
    #1882
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Intercooler and oil cooler would need to be recommended as not to have any spikes both in pressure and temp. Those spikes can have tremendous loads which in turn can cause damage. Those IAT's can get very hot. We had a non intercooled turbo diesel in for testing (non us market) and put in the right circumstances (high loads, stop start, high speed endurance testing) would overheat. Fueling, A fuel pump should be in the plan considering how little capacity the oem one has. Injectors I'm sure URD has them for your engine for its supercharger kit. Now if they are they same as the 1gr's then there is a good deal of reserve for 4-5lbs as has been tested before. Also would recommend you increase the oil weight. An sae 40 would be a good all rounder.
  3. Feb 24, 2014 at 10:49 AM
    #1883
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Yeah I will be sending Gadget an email here in a couple weeks after I purchase the DIY turbo header to see if he will let me pick his brain about injectors and ECU issues he has worked out for the 2tr.
  4. Feb 24, 2014 at 10:50 AM
    #1884
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh:
    :thumbsup: :thumbsup: Listen to this man.
  5. Feb 24, 2014 at 12:07 PM
    #1885
    Gaunt596
    Matthew
    Central Maryland
    wait, he sells a diy turbo header?
  6. Feb 24, 2014 at 12:31 PM
    #1886
    Torspd
    Tor
    The Great America!
  7. Feb 24, 2014 at 12:45 PM
    #1887
    Gaunt596
    Matthew
    Central Maryland
    oh, thank you for the link, i thought gadget owned URD?
    Edit: aww man, they don't make a 1-GR-FE header
  8. Feb 24, 2014 at 1:59 PM
    #1888
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Gadget owns URD, URD is not treadstone performance. Correct me if I am wrong but Treadstone owns Treadstone, correct Mark? And no I have 2tr, not 1GR. I was chiming in on Singlecab's turbo talk.
  9. Feb 24, 2014 at 2:36 PM
    #1889
    Gaunt596
    Matthew
    Central Maryland
    yeah, i understand that urd and treadstone are separate companies, i thought you meant gadget owned both. and yeah, i was hoping for a header for a 1-GR-FE, as most of the shops around me are garbage.
  10. Feb 24, 2014 at 2:59 PM
    #1890
    Torspd
    Tor
    The Great America!
    Correct. Jason Treadstone owns said company.
  11. Feb 24, 2014 at 3:01 PM
    #1891
    Clifford
    Clifford Well-Known Member
    Cliff
    Seattle
    low and slow
    Tree Air Freshener
    PowerFab was selling hot side turbo kit parts not too long ago, dunno if they still are or not. Anyways, stop bumping this thread assholes I got all excited and though something happened on this build lol.
  12. Feb 24, 2014 at 3:10 PM
    #1892
    Lucario Runner
    Robert
    06 Toyota 4Runner
    U MADD???? :p
  13. Feb 24, 2014 at 3:16 PM
    #1893
    Lucario Runner
    Robert
    06 Toyota 4Runner
    No prob. So whens the boost coming?
  14. Feb 24, 2014 at 3:55 PM
    #1894
    Gaunt596
    Matthew
    Central Maryland
    :rofl: ill have to call them, their website is crap.
  15. Feb 24, 2014 at 4:06 PM
    #1895
    Torspd
    Tor
    The Great America!
    I have any extra fuel pump, and an oil cooler off of a Ferrari race car. Neither are free though. :p
    I have the original fabricator's # if PowerFab cannot any longer. He might have taken the jigs with him, when he left. There are alternatives available. Just have to contact me. ;)
    As a matter of fact, there are a few fab shops in your area which could do the work rather easy for you. Justice Racing Engines, being one of them.
  16. Feb 24, 2014 at 4:15 PM
    #1896
    Gaunt596
    Matthew
    Central Maryland
    cool, ill call around, single cab gave me an idea about finding a turbo off of another car with a 4.0
  17. Feb 24, 2014 at 7:33 PM
    #1897
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you should start a company called Frankenstein Fab......build turbo kits out of parts from 10 different cars......then crack a beer as people drive out of your shop, so you can relax and watch the engine snap, crackle, and pop as they drive away.
  18. Feb 24, 2014 at 10:41 PM
    #1898
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I have a walbro pump. I'll sell it 50$ to u
  19. Feb 24, 2014 at 10:44 PM
    #1899
    RedLantern
    Honolulu, Hi
    Hah well there you go. I plan to do the same to a 4cyl double cab in the future
  20. Feb 25, 2014 at 6:16 AM
    #1900
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'm not concerned about it working or it's efficiency. moresor reliability. you're right, doesn't need to be a race truck level setup, but it does need to be reliable. just don't want you stranded on the side of the road. because you skimped on something.
