Toshiba satellite laptop help
Discussion in 'Technology' started by Anthony250, Mar 28, 2013.
  1. Mar 28, 2013 at 3:35 PM
    Anthony250
    Anthony250 [OP] E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Ok do someone at my house installed something on my laptop and probalby a virus. I turn it on and it works fine for 10 minutes an d then freezes and does nothing. I tried factory resetting it but it didnt work, so i went to command prompt and entered bcd rebuild and otherbstuff and now i turn it on and get only
    Windows failed to start file \boot\bcd and status 0xc0000098 and thats all it does i neeeed help its a tOshiba satellite l355-s7831
  2. Mar 28, 2013 at 3:39 PM
    169.254.255.201 Well-Known Member
    Interwebs
    Not sure what you mean by factory reset, but you should insert your windows 7 disk, or repair disk and do a repair first. If your laptop doesn't work after that, do a fresh install using the same disk.
    Or try getting into the boot menu (i think) probably F8 through F12 when booting up. Not sure what it is for toshiba and do the onboard diagnostics and see what that reports. You may need a new harddrive, as I recently had to do that to a computer based on the diagnostics.
  3. Mar 28, 2013 at 3:41 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2013 tacoma limited double cab long bed 4x4.
    can you start it in safe mode, then go back to an earlier time, before this happened? I'm not great with computers, just a thought, I'm sure someone good with computers will chime in soon, good luck!
  4. Mar 28, 2013 at 9:22 PM
    Anthony250
    Anthony
    San Gabriel Ca
    I did go into the boot menu, and followed some googled instructions to factory restart without cd, since i dont have the cd. And now its repeats back to the error page.
