TOTAL CHAOS | Expedition Series +2" Long Travel
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Oct 4, 2019.
  1. Oct 4, 2019 at 10:34 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    TOTAL CHAOS is excited to announce the release of the all-new 2” Expedition Series long travel kit. With the success of the stock length Expedition Series lower control arms it was only natural to incorporate the upgraded features into one of our long travel systems.
    Enthusiasts and racers alike can now benefit from the increased strength of a billet CNC machined uniball end piece and integrated steering stop tabs which retain the factory turning angle.
    Increasing a vehicle’s track width improves performance in a few different ways. With a wider stance comes improved cornering stability and increased wheel travel. Do you want more articulation when crawling over obstacles on the trail? Want to carry more speed through rough terrain? Long travel is what you’re looking for.
    Going with a 2” kit vs. something wider has its up-sides as well. When paired with certain wheel and tire combinations, a 2” kit may not require aftermarket fiberglass fenders like other wider long travel kits. Trail width limitations are also something to consider. A 3.5” or wider prerunner suspension system may be perfect for the desert but too wide for tight trails littered with trees, rocks and other obstacles.
    Extended 4130 chromoly upper and lower control arms increase the vehicle's track width 2" per side and bolt to factory control arm mounting locations yielding 11.5" of travel. Upper and lower control arms utilize urethane bushings and steel inner sleeves which greatly reduce bushing deflection compared to stock rubber bushings.
    Both the upper and lower ball joints are upgraded to 1" uniballs for maximum wheel travel. Custom TC 1" I.D. uniballs feature a heat treated stainless steel ball & race for superior corrosion resistance and component strength. A military grade PTFE woven fabric liner surrounds the uniball which helps prevent noise and debris buildup.
    The Expedition Series 2" kit lower control arms come pre-tabbed for secondary external bypass shocks which can be installed to increase dampening and offer more tunability. Secondary shocks are not required when installing this kit, however it makes for a significant improvement in ride quality and furthers your vehicle's off road capability.
    As the control arms extend outward, the brake lines need to be extended to reach the brakes. TC has you covered and includes DOT approved stainless steel braided brake lines. For vehicles with 4WD, custom 4340 extended axles are available, although not included with the kit. These axles reuse factory Toyota inner and outer CV's for ease of maintenance and install. Adjustable limit strap clevises are included to properly limit suspension droop wheel travel and allow necessary adjustments during the life of the limit strap.
    A great upgrade to compliment the 2" Expedition Series long travel kit is the custom TC extended swaybar. With a lighter rate than the OEM piece, this sway bar improves cornering stability at high speeds without compromising wheel travel or articulation. The sway bar is an upgrade and is not included with the kit.
    Shop Now
  2. Oct 5, 2019 at 5:45 AM
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    These are freaking awesome! I'm hoping to snag a kit for the shop Tacoma! It's time to ditch this AP long travel kit and do some bypasses.
  3. Oct 7, 2019 at 1:27 PM
    TOTAL CHAOS
    Corona, CA
    Reach out when you're ready!
  4. Oct 14, 2019 at 5:00 PM
    Jpiskura
    Jpiskura Well-Known Member
    So keeping the sway bar, factory or your aftermarket one will not limit vehicle articulation or travel...? What would be the advantage of taking off a sway bar..?
  5. Oct 14, 2019 at 5:03 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    The stock sway bar limits travel because of its stiffness.
    ditching the sway bar nets more travel that’s not under bind so much, make sense? So it just moves much smoother and has to work less.
    going with the +2 length sway bar from TC also doesn’t limit travel because it was designed to have less stiffness than stock letting it twist easier but also enough stiffness to keep things from feeling like a boat.
    Jpiskura[QUOTED] likes this.
  6. Oct 14, 2019 at 5:08 PM
    Jpiskura
    Gotcha... I just saw someone running a +2 kit with a sway bar and had me question what the hell I took mine off for...? I never ran one in my wrangler and for good reason. But I just figured I’d take it off the taco to see how it was and I really isn’t bad driving corners at speed...
  7. Oct 14, 2019 at 5:15 PM
    3JOH22A
    3JOH22A Toyota Gigolo
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Does this kit push the spindle forward to get more clearance from the cab mount?
  8. Oct 14, 2019 at 6:16 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    I much prefer no sway bar. the extra stiffness from the coilovers mitigates some of the body roll.
  9. Oct 14, 2019 at 6:17 PM
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    The arms are designed for a little extra forward caster, so you can clear bigger tires better.
    3JOH22A[QUOTED] likes this.
  10. Oct 24, 2019 at 8:43 AM
    TOTAL CHAOS
    Corona, CA
  11. Nov 4, 2019 at 12:52 PM
    TOTAL CHAOS
    Corona, CA
    Dune days with the TC crew plotting the 2019. CHAOS crop circles are standard protocol.⁣
    1 crop circle a day will keep the doc away. I think michaelallen and dirthurts might suffer a tad bit from ADD.⁣
    Photos: mayfieldmedia
    72187590_3416703098370214_16645983403119_df756f6d9e0982ca7e46719a8e9353838e077c9a.jpg
    75462497_3416703171703540_40573528517336_a9a90f11c93c7c59cb9128c6a8df348ffb1f82a6.jpg
    74395719_3416703235036867_48253564838750_2c22be80fbaca1e58e27ec002118abb77b760796.jpg
    75146356_3416703381703519_50589615847605_27437c5e1532df051549f0cca1e7fd402f7609d6.jpg
    74609497_3416703431703514_16323123710682_bf8beb0062cc49ed2c29e87b6dae69c885279b74.jpg 74785853_3416703695036821_75293824064075_7fa978d1ad104ebe3fea50a46b203391ce39b92a.jpg
    76726005_3416716728368851_34206231340578_83b9d57bd5bdb07b510099e64bfc01bb8ee1c792.jpg
    75258570_3416703851703472_17946935525428_4a6980687390f7e46a5dae38b88861820b182a91.jpg
    Jpiskura likes this.
  12. Nov 15, 2019 at 11:36 AM
    TOTAL CHAOS
    Corona, CA
    "Thanks for making such a killer product, it’s handling business anywhere we take it! "
    75543751_3452913201415870_91752045455658_92c72d38f530fbb6c7b8bf8907aee43ac9ec6681.jpg
    75271542_3452913231415867_78709469906563_4fbf6c48dd942c456dd656391af84beeda93d581.jpg
    The Russian Arm Tundra loving the Alberta elements over the weekend. Played in the snow and made it up to the top of this snowy mountain without chains!⁣
    76613117_3452913361415854_25641484326587_399ebc077fc51eb04677533679b81d4daf87f3a8.jpg
  13. Nov 30, 2019 at 2:18 PM
    TOTAL CHAOS
    Corona, CA
    The main difference is that our Expedition Series allows a large diameter shock (up to 3.0) and it also has increase turning clearances. You are no longer required to clear the steering stops
  14. Dec 11, 2019 at 12:37 PM
    TOTAL CHAOS
    Corona, CA
    79186037_3547819445258578_81284104845472_59a1576fed7f359f55ee2e8e810e32529aaed835.jpg ... get out and explore with tacorunner
    photos: imjoshuawalker
    79218954_3547819541925235_38039739619354_df59667819d2a5dda861e1d78efe233cf3363121.jpg
    Taco230032 and Mallardmaster1 like this.
  15. Feb 20, 2020 at 11:57 AM
    TOTAL CHAOS
    Corona, CA
  16. Aug 20, 2020 at 5:30 PM
    hedg21
    hedg21 Well-Known Member
    09 TRD off-road
    Probably a stupid question, but what needs to be done to the rear aside from adding the complimentary shocks to make the rear match the fronts increased width?
    TOTAL CHAOS[OP] likes this.
  17. Aug 26, 2020 at 7:03 AM
    TOTAL CHAOS
    Corona, CA
    expensive route = new wider diff
    Cheaper route = spacers
  18. May 13, 2021 at 5:45 PM
    Darley_offroad
    Darley_offroad Darley_offroad
    I know that this thread is old and dead. but im wondering how much down travel this kit has after lifting around 2.5 in?
  19. May 26, 2021 at 7:02 AM
    TOTAL CHAOS
    Corona, CA
    it's dependent on a lot of variables so we couldn't give you an accurate answer
  20. May 26, 2021 at 4:21 PM
    Darley_offroad
    Based on your experience running the kit and seeing where others have there kit what would be a good split of up vs down travel for mild rock crawling and going fast? I'm looking at this kit so that I can stay narrow but get back some of the down travel that I lost lifting the truck a bit. Going long travel is expensive and I just want to be fully informed befor any investment is made. Thanks
