Total chaos upper arms?
Discussion in '1st Gen. Tacomas (1995-2004)' started by So.Cal Taco, Jun 25, 2011.
  1. Jun 25, 2011 at 9:53 AM
    So.Cal Taco
    So.Cal Taco [OP] Well-Known Member
    Jeremy
    So.Cal
    1996 4x4 v6
    Total Chaos Long travel Total Chaos Spindle Gussets, Nathan Air Chime K3LA's,Onboard Air system,K&N intake,Chuys 200 plus Amp Alternator,All Pro front Bumper,Lots of Dynamat,99 tacoma Gas Tank Mod ''Secret'' maybe I'll Tell
    I just put on my T.C upper arms lastnight what a pain old ball joints :mad: well there on now i set the torque to 85lbs is that to much?
  2. Jun 25, 2011 at 10:07 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    I think it's 100lbs?
  3. Jun 25, 2011 at 10:22 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 285 x 70 x 17 Toyo Tires on 17" x 8" ICON Wheels
    That's correct, per their instructions...
  4. Jun 25, 2011 at 10:23 AM
    Oh....and be sure to re-torque after about 500 miles!
    whatstcp likes this.
  5. Jun 25, 2011 at 11:00 AM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    Thanks guys the uniball i did 100 lbs but the eye bushings i did 85 is that good?
  6. Dec 22, 2020 at 2:41 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Old thread revival-I just ordered a set of these. Any recommendations to help with the install? Thanks!
  7. Dec 22, 2020 at 2:43 PM
    treyus30
    treyus30 cntl-y
    Trey
    Mesa / AJ, AZ
    '99 5VZ-TT 14PSI+
    Two spooly snails, Haltech 2500, 35s, 125kmi
    o_O
    oh.
    The old factory pivot bolt can be a bitch to get out, I remember that.
    Poncate[QUOTED] likes this.
  8. Dec 22, 2020 at 3:02 PM
    04tacoma trd
    04tacoma trd Well-Known Member
    I put a set of these on like 13 or so years ago. They probably have update their product since then, but no complaints here (except for a slight squeek).
    Poncate likes this.
  9. Dec 22, 2020 at 3:21 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    First, I must commend you on your search skills. I can't imagine this thread it was comes up first when searching. :D
    Put the ball joint plug in the freezer overnight. It will press into the spindle like butter.
    There are some fittings on the fender you'll have to unbolt and move in order to get the pivot bolt out.
    Other than that, just follow the instructions.
  10. Dec 22, 2020 at 6:53 PM
    Poncate
    PNW
    04 DCSB 4x4
    Ha! Thanks and thanks for the tip. I’ve been trying to search and revive old threads.
    What King set up are you running? Been wavering between Kings and Icons.
  11. Dec 23, 2020 at 8:34 AM
    jbrandt
    Justin
    They are both great quality shocks, but they are designed totally differently.
    Kings are linear, Icons are digressive.
    https://accutuneoffroad.com/article...qaplguzU2UD_gTPhJjgnq_4uQiCXJXuxoCaQ4QAvD_BwE
    I'm running the extended travel Kings, and I absolutely love them. As the article states, great all around performance. The street ride is great, and they hammer off road.
    So it really just comes down to the type of driving you do, which will be a better fit. I had 5100s on before, and they worked fine but I could definitely tell they weren't ideal for things like potholes or big hits (as the article describes). I used to think that was because they are relatively cheap shocks, but this article shows that's a design "feature" not a bug of digressive shocks. Not having driven with high end digressive shocks, it's hard for me to say what would change going from 5100s to Icons...
    As for the handling, I haven't run a swaybar since I put my Kings on. It rides just fine. Sure, it has some body roll in corners (like freeway on-ramps). No, it doesn't exactly handle like an F1 car, but that's not what I'm going for anyway. It's a trail truck, not a daily driver. If it was still a DD, I'd probably still have the swaybar.
  12. Dec 23, 2020 at 2:09 PM
    Poncate
    PNW
    04 DCSB 4x4
    Good article, thank you for sharing. I learned a ton and now understand why my current set up is so stiff on the smallest bumps. I’ll most likely go with a linear set and some form of long travel to take advantage of the UCAs.
  13. Dec 23, 2020 at 6:04 PM
    jbrandt
    Justin
    What you'll want is "mid travel". That's the extended travel coilovers like I have. It's 1" more down travel.
    "long travel" is an entirely new setup requiring longer control arms, etc...
    You'll probably also want poly bushings for your lowers (uppers already have them) if you don't have them already. The stock rubber ones might be okay, but the extra down travel might stretch the rubber bushings a bit much.
    Good luck, and enjoy!
