Total Chaos vs. Light Racing upper control arms...
Discussion in 'Suspension' started by DeeKay21, Nov 23, 2008.
  1. Nov 23, 2008 at 1:23 PM
    DeeKay21
    DeeKay21 [OP] Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm trying to figure out which UCA's to get for my truck but can't decide. I already got everything I need to get my lift done but now I want a set of UCA's. I only use my truck for general purposes and mostly for eyes only and don't do much off-roading at all. So which UCA's would be a better application for me. I know the Light Racing UCA's are about $200 cheaper then the TC's. I'm just trying to get some feedback with people that have knowledge of either product or own either product to help me decide.
  2. Nov 23, 2008 at 3:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    TC's!!! :D
  3. Nov 23, 2008 at 3:52 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    HAHA chris I already know what you like!!!:D
  4. Nov 23, 2008 at 4:40 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Well never mind guys. I already ordered the total chaos UCA's! :D
  5. Nov 23, 2008 at 5:44 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Good choice!
  6. Feb 13, 2012 at 7:13 AM
    Squaretail
    Squaretail Well-Known Member
    New Hampshire
    08 V6 Black Blurr
    I'm getting ready to pull the trigger on the group buy for the LR UCA's....
    Could anyone give me a comparison between LR and TC's? No threads found in search besides this one.
  7. Feb 13, 2012 at 8:27 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I've heard that TC has more travel cause of the ball joints.
  8. Feb 13, 2012 at 8:39 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    Total Chaos can yield longer travel because of the uniball, but you'd have to pair that with extended travel shocks. As for alignment I'm not too sure but they should add more camber to keep alignment in factory spec.
    Light Racing are a ball joint style UCA, they're cheaper, not as cool looking but they add more camber to keep your alignment within spec after lifting. They are booted so if you live in the salty north they will probably hold up better through the winter. I own these and must say they have done me well.
    If you don't offroad save your cash and get the LR UCA's. They will perform beyond what you need.
  9. Feb 13, 2012 at 8:39 AM
    TheGloryFades
    TheGloryFades Well-Known Member
    Seth
    Arizona
    '13 toaster
    Zombie thread! TC will allow for more travel due to the uniball, the light racing have more adjustment in the castor I believe
  10. Feb 13, 2012 at 3:48 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    Thanks for the help guys!
    From what I've read on this forum, aftermarket UCA's are pretty much a requirement with a 3in lift??? I am getting the alignment done this week, so I am going to see how the specs come out.
    But I want good alignment before I go spend $$$ on new rubber
  11. Feb 13, 2012 at 4:09 PM
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    I'm debating getting LR UCA's. Getting spindles which should allow me to ditch UCAs but I've decided to run Eibachs at 0, so 1.6" of lift. Will I be able to get my caster near 2.4 or do I need UCA's still?
    I've hated having 0 caster with my current lift near 3"
  12. Feb 13, 2012 at 4:13 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    I'm selling a set of camburge 1" uniball UCA's $450 shipped. I'll have them off when my new 1.25" come in this week. No prob in alignment issues.
  13. Feb 15, 2012 at 7:43 AM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    I know chris 4x4 prefers the TC, but at the discount price of $375 shipped for the LR, I don't think I can pass it up.
    I will not be doing heavy off-roading so from what you guys are saying, I should be fine right?
    I am just getting aftermarket UCA's to fix my alignment. Sole purpose!
  14. Feb 15, 2012 at 7:44 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    There are tons of guys on here that run LR UCA's and go hard on the trails. I know I beat the crap out of mine, and once you take off your stock ones and hold em next to the LR ones you will see how beefy they are
  15. Feb 15, 2012 at 7:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I prefer the TC's over other Uniball UCA's. The LR's are a great UCA, and offer alot of adjustment.
  16. Feb 15, 2012 at 8:19 AM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    Thanks for the input Chris...
  17. Feb 15, 2012 at 8:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I was told by my shop that they couldn't get the caster up that high. I'm at like 1.7-1.8 I think. I think it wanders a little bit at speed and am actually really debating getting in on the LR control arms. I've already paid for 3 alignments and they keep saying they can't get the caster any higher.
  18. Feb 15, 2012 at 9:39 AM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    Pugga: stock UCA's?
  19. Feb 15, 2012 at 9:41 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    dont forget about DSM UCA there uniball are stainless from the get go, doesnt matter to you cause you dont know what snow looks like :p
  20. Feb 15, 2012 at 9:41 AM
    Pugga
    Massachusetts
    Sorry, yes with stock UCA's. I'm debating going to LR UCA's because I want my caster to be higher and the boot design appeals to me because I live in the salt belt.
