Touch Screen Freezing 3rd gen Tacoma
Discussion in 'Technical Chat' started by Scipio1096, Feb 3, 2021.
  1. Feb 3, 2021 at 4:01 PM
    Scipio1096
    Scipio1096 [OP] Member
    D.
    Texas
    2016 Black Sport Taco
    Hello all,
    I recently had an issue with the touch screen not responding. Bluetooth hook up still works just fine, even shows the song changing when I use the phone to do so, the touch screen buttons will not work tho. This includes the Home and Audio buttons on the left side. When I stop the car and restart it I guess "rebooting" the computer it works just fine. Anyway to do this without turning the car off? Or a better long term fix?
  2. Feb 4, 2021 at 6:04 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    See if your dealership cares at all. 8/10 times they won’t be able to “verify the problem” so they’ll send you on your way.
    pull the actual radio fuse up at the battery (Radio No.1) and wait about 30 seconds and pop it back in. This will clear any temporary funny business going on, but won’t solve any deeper problem. I would also see if there is a firmware update available
  3. Feb 4, 2021 at 3:57 PM
    Scipio1096
    D.
    Texas
    Thanks! I had browsed the forum and found a couple suggestions or also do hard resets by pulling various wires. Ill check on that firmware update too.
  4. Feb 4, 2021 at 3:58 PM
    Scipio1096
    D.
    Texas
  5. Feb 5, 2021 at 4:47 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Just do this update and check if it fixes it. it was a problem i had
    https://www.tacomaworld.com/threads/3rd-gen-multimedia-updates.696603/
  6. Mar 8, 2025 at 9:14 AM
    Batmantaco
    Batmantaco New Member
    2021 Tacoma TRD sport
    2021 Tacoma Trd sport. Out of warranty. Issue! freezing cluster. Disconnect the battery and it works again. Happens randomly. Anyone figured this out? Truck has the newest update. Update was done with laptop before I had it tuned But issue has happened way before the tune. So update didn’t fix it.
