Tow capacity v6 Tacoma standard 6 speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wildhog, May 24, 2018.
  1. May 24, 2018 at 3:09 AM
    Wildhog
    Wildhog [OP] Member
    2006 Tacoma 4x4 access cab
    can my Tacoma tow a 3800 lb camper? Any one out there towed that kind of weight? Any response appreciated, thanks Wildhog
  2. May 24, 2018 at 3:23 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    If you have the factory tow package, then you have 6500# tow rate. Without I believe it's 3500# tow rate. I have the tow package and tow around 6000# with mine. Don't tow in 6th gear.
    ausfahrt likes this.
  3. May 24, 2018 at 3:29 AM
    kevdog0710
    kevdog0710 Active Member
    Kevin
    Philly area
    Prerunner
    All stock
    My camper is 4000lbs dry. I don't want to say it does it with ease like some others, but it is more than capable. I have added the B&M supercooler and just received the scangauge you see in a lot of the threads. Trailer has the Equalizer 4 point sway and weight distribution bars. I'm looking forward to seeing trans temps tomorrow when I leave on a trip with the camper fully loaded. Trans currently reads around 140 degrees doing 75mph.
  4. May 24, 2018 at 3:55 AM
    jfoster92
    jfoster92 Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    I’m not certain of the weight but I’ve pulled a PT Cruiser on an 18’ trailer and it pulled fine. Balance your load and forget 6th gear lol
  5. May 24, 2018 at 3:59 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    I pulled a fully loaded 6x12 u haul trailer from Houston to Chicago. Had my tool box, jacks, and literally everything in that trailer... figured it had to be over 4K with the trailers weight
  6. May 24, 2018 at 6:08 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
  7. May 24, 2018 at 6:22 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    wow........^^^^^^^^^^^
    thats a lot of info.......
    thx !
    knottyrope likes this.
  8. May 24, 2018 at 7:15 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    A 6 speed doesn’t have a 6th gear, it has 5. Overdrive is not a gear, its a capability of a transmission.
    OP- if you don’t have the factory tow package you are a No Go to haul that trailer.
  9. May 24, 2018 at 7:47 AM
    09BlueBeast
    Cody
    Denver
    Definitely has a 6 on it...
    TireFire, jfoster92, ausfahrt and 2 others like this.
  10. May 24, 2018 at 8:09 AM
    kevdog0710
    Kevin
    Philly area
    Prerunner
    All stock
    Not talking about the legal side of it, but adding a proper receiver is the only difference between the 2 packages as far as load capability is concerned. The battery, alternator and coolers are a different story. My prerunner was not equipped with the tow package but I added the receiver, a trans cooler and wired the break controller. Only thing I am missing is the alternator, battery and engine oil cooler.
  11. May 24, 2018 at 8:22 AM
    knottyrope
    Knotty
    Bahstun
    kevdog0710 likes this.
  12. May 24, 2018 at 8:22 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Just a heads up, your 6spd manual wont have the need for a trans cooler. Those are a part of the tow package exclusively for the automatics. The tow package for your truck will include a higher output alternator, 27F battery, 7pin harness, and oil cooler.
    Skyway and ausfahrt like this.
  13. May 24, 2018 at 8:26 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
  14. May 24, 2018 at 8:28 AM
    PackCon
    Connor
    Thats false.
    There is a big difference in tow capacity between the two packages.
    How much weight a vehicle can handle is related to the vehicles ability to cool its fluids.
    Skyway likes this.
  15. May 24, 2018 at 8:30 AM
    PackCon
    Connor
    So do manuals no have O/D??
  16. May 24, 2018 at 8:33 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    6th gear on a V6 manual transmission is a overdrive - ratio is .85
    On a manual transmission it is an actual gear, just like gears 1 thru 5.
  17. May 24, 2018 at 12:06 PM
    POOLGUY
    JEFF
    ALABAMA
    I'm talking about manual 6-speed trans.
  18. May 24, 2018 at 12:28 PM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    i have the prerunner with no tow pkg. tow rating is 5200lbs. i'm adding a brake controller and the 7 pin harness. confirmed with dealer that i'm good to about 3500-3800 lbs no probs without the coolers. towing in 4
    Skyway likes this.
  19. May 24, 2018 at 2:35 PM
    nobescare
    Mark
    2019 Highlander SE
  20. May 24, 2018 at 2:53 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    @PackCon literally everything you contributed here is bullshit. Really.
    OP, if you have your manual look in there. If you don't have it an easy thing to verify is open the fuse box under the hood and check the alternator fuse. 140amp = towing package
    120amp = no towing package
    If you've got it your truck is prewired for a brake controller (which you'll need for that trailer weight).
    If not you can still add the equipment needed. Either read up in the towing bible someone posted above, do. it yourself and save money or bring it to a shop for a turnkey solution.
    09BlueBeast and POOLGUY like this.
