tow package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maui808, Oct 27, 2010.
  1. Oct 27, 2010 at 4:45 PM
    maui808
    maui808 [OP] Well-Known Member
    Jacob
    Maui
    09 sport
    where did u g=buy your from the factory or aftermarket if so can i see pics pls i really dnt wanna buy it from the dealer
  2. Oct 27, 2010 at 5:19 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I bought a drawtite, simple to install and only a couple hundred bucks. Check out my build for some pics. DrawTite and Hidden Hitch are the same manufacturer. Uhaul and Valley are also the same. There might be some others, but those are the ones I know.
  3. Oct 27, 2010 at 5:34 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    factory tow package also comes with a trans cooler i believe, thats probably what makes the price look alot bigger
  4. Oct 27, 2010 at 5:35 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Higher output alternator as well
  5. Oct 27, 2010 at 5:40 PM
    bailerc
    Cody
    Fayetteville, NC
    16' MGM Limited
    ahh yes , i thought there was something else , and battery too i think
  6. Oct 27, 2010 at 5:41 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yep its bigger battery and stronger fan to cool everything down
  7. Oct 27, 2010 at 5:47 PM
    RAMZAK
    RAMZAK Well-Known Member
    Mark
    Houston
    2008 Tacoma TRD 4-DR PreRunner
    BIG Difference between getting a factory Tow package and getting Uhaul to instal a dratite.
    Factory Tow Package Includes:
    1. Transmission Oil Cooler
    2. Engine Oil Cooler
    3. Larger Alternator
    4. Larger Battery
    5. 5 Pin Harness
    6. Class IV Hitch (goodluck finding that aftermarket)
    7. Increases (legally) your Tacoma's towing rating from 3000lbs to 6000lbs.
    Because I tow a boat with mine, I would never buy a tacoma without the FACTORY TOW PACKAGE. There are some people on here that have tried to install all the above equipment on their truck. It cost them more plus it is NOT covered under warranty. It is also not as reliable as toyota equipment and is bootleg.
  8. Oct 27, 2010 at 6:15 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I have a Hidden Hitch. So far it's worked very well. I don't tow very frequently but it's nice to have when you need it.
  9. Oct 27, 2010 at 6:17 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    fixed :thumbsup:
  10. Oct 27, 2010 at 6:19 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    x3
  11. Oct 28, 2010 at 12:32 PM
    Jetfixr
    Jetfixr What was I thinking??
    William
    Cocoa, Fl.
    Indigo Blue 4 door 6spd 07 4x4 TRD Offroad.
    TRD, filter and exhaust system. Red line hood struts, New frame, Truxedo cover, Spyder pro headlights, 3" lift, 17" wheels.
    I am having an issue with my truck with the towing package, i have no power at the 7 pin plug under my bumper. Replaced the harness and still no luck. Any thoughts?
    Jet
  12. Oct 28, 2010 at 6:53 PM
    larryde09
    Larry
    Boston, MA
    My DrawTite is a Class III/IV, so that's not entirely accurate. I have a manual so I didn't have to worry about the trans cooler. Also, larger alternator might not be necessary if you typically tow a trailer with LED lights (e.g. no significant extra load on the battery). However, this stuff is certainly worth it if you tow a lot and/or a trailer with more electrical demands and weight requiring more engine/trans cooling. It all depends on your needs.
  13. Oct 29, 2010 at 3:08 PM
    RAMZAK
    Mark
    Houston
    Ha! Thanks!
  14. Oct 29, 2010 at 3:09 PM
    RAMZAK
    Mark
    Houston
    Makes it less of a drag on your electrical system if you put a nice stereo in your truck.
    I hate my factory stereo, cant wait to put a new one in.
  15. Oct 29, 2010 at 3:11 PM
    RAMZAK
    Mark
    Houston
    Fuse? I think it may be a "under-the-hood" fuse.
  16. Oct 29, 2010 at 6:35 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    For the record, the bigger 27F battery is standard on all V6 Tacoma's sold in Canada, and maybe the Northern States?
    Also my non tow package fan is the same as the tow package (pink clutch).
