Towed my boat this week
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BroncoAZ, Sep 13, 2021.
  1. Sep 13, 2021 at 9:35 PM
    BroncoAZ
    BroncoAZ [OP] Well-Known Member
    Cape Cod, MA
    2021 WhiteTacoma TRD Offroad
    I decided to pull the boat for some maintenance, I was curious to see how the Tacoma handled the weight rather than using my 2000 Expedition. The boat weighs around 6,000 pounds, measured the tongue weight is 580 pounds. The Tacoma did great on my short (5 mile) tow, and no issues on the steep ramp. I did use ECT. I don’t know that I would feel great about towing this load on the highway, but typically my towing is 4-6 times a year within 10 miles of home. I’m not surprised the truck was able to tow a load within it’s specified capacity, but you don’t really know until you test it.
    1949E2DA-D4E5-4BE7-8007-431B5A1592D4.jpg 5D796258-A923-415E-9CE0-39A5ED66AA9F.jpg
  2. Sep 13, 2021 at 9:38 PM
    MGMDesertTaco
    I take it there wasn't any algae on the launch ramp to pull you back down then. o_O:eek:
    BalutTaco and tcjacado like this.
  3. Sep 13, 2021 at 10:16 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Definitely will need rear sumo springs and weight distribution hitch when you use it as primary vehicle for towing that boat.
    cryptolyme likes this.
  4. Sep 13, 2021 at 11:04 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Those weight distribution hitch's are the shit. I know a girl that pulled a loaded 16 foot dual axel trailer from California to Florida in a little Mercedes SUV with zero problems.
    bulalo[QUOTED] likes this.
  5. Sep 14, 2021 at 3:37 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Anything with wheels is able to move. I wouldn’t feel comfortable towing that on the freeway either
    Chew likes this.
  6. Sep 14, 2021 at 3:50 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Impressive no problems on the steep ramp, do you use 4 wheel drive?
    baustin likes this.
  7. Sep 14, 2021 at 4:11 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Slow and steady. Definitely need trailer brakes with something like that. I had surge brakes on a previous trailer/boat combo and they worked very well for me.
  8. Sep 14, 2021 at 4:17 AM
    BroncoAZ
    Cape Cod, MA
    It was mid tide, so not too much algae and slime on the upper half of the ramp. I back it in until the tires in the water but the rims aren’t yet submerged.
    I was actually impressed with how not squished the truck was when loaded. Weight distribution doesn’t work well with surge brakes to my knowledge. The tacoma may become the primary tow vehicle, but it’s only from the house to the marina a few times per year on roads with a posted limit no more than 45 mph.
    I used to tow that same boat much farther and on the highway with my 2011 VW Touareg TDI, but the Touareg was significantly heavier than a Tacoma. The boat is within the weight limits for the Tacoma, I think a lot of people would just send it.
    This time I kept it in 2wd to test it. Generally I do shift whatever truck I’m driving into 4wd for ramp traction, or even 4 low for the extra torque just to ease the load on the transmission. For some reason my Tacoma takes a while to shift in and out of 4 low.
  9. Sep 14, 2021 at 4:27 AM
    BroncoAZ
    Cape Cod, MA
    Trailer brakes are required over 3000 pounds here. Someone recently reminded me that brakes have to be installed, but nothing in the law says they have to work. I much prefer electric brakes, or electric activated hydraulic for boats, on newer trucks with an integrated brake controller, but surge brakes work just fine and continue to work if the wiring gets disconnected.
    Toyko Joe likes this.
  10. Sep 14, 2021 at 5:23 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've towed my 2k lb boat 60 mile round trips...it tows fine, but i feel if i had to make an emergency stopped i'd be sol. I have another 5x10 aluminum utility that i tow every couple weeks to the local landfill with garbage that sometime's you don't even know its there. Truck brakes work fine with that.
  11. Sep 14, 2021 at 5:44 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I would bet a court case would see that a little differently.
    Inferno! likes this.
  12. Sep 14, 2021 at 5:59 AM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    OP!
    Is that a 22’ it looks big! I might be on your shoes in some years.. why? I am keeping my Tacoma until it falls apart and I am hoping to be able to buy a boat in some years, so, I wanted to know how long is your boat and what engine you have? 150? 200?
    Very nice boat!
  13. Sep 14, 2021 at 5:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I have no doubt that I could pull 10,000# or more that's not the point. Tail wagging the dog.
    zoo truck likes this.
  14. Sep 14, 2021 at 6:19 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    You need some Timbren's to reduce the rear sag!
  15. Sep 14, 2021 at 6:28 AM
    Charlie Marlow
    Charlie Marlow Well-Known Member
    Georgia
    19 TRD OR
    I haul a 24 foot pontoon boat with mine with little trouble. I have a manual transmission, so 4-lo is practically required to pull it out of the water. If it's really windy, I can sometimes feel the boat trying to induce a sway at highest speeds, but it's not bad and those aren't good days to take a pontoon boat out, anyway. All told, the boat and trailer with a full tank of gas is under 5k and the Tacoma handles it well.
  16. Sep 14, 2021 at 7:47 AM
    802Tacomas
    802Tacomas Well-Known Member
    Winooski, VT
    2020 OR DCSB
    Bilstein 6112’s AAL w/ Bilstein 5160’s JBA UCA’s ARE CX Bed Cap Custom 8020 Extruded Cap Rack Falken Wildpeak AT3W 265/75r16’s Caliraised Lower Bumper Hidden LED Bar Caliraised Ditch Lights
    I pull my ‘90 Glastron 20ft. I’d guess the boat and trailer weigh in at +or - 4K. The truck definitely has the power to pull it, but not having brakes on the trailer makes for quite a long stopping distance.
  17. Sep 14, 2021 at 10:05 AM
    BroncoAZ
    Cape Cod, MA
    My other boat is just under 3K and the Tacoma tows it like a champ.
    Thanks! That is a 2003 Welcraft 24 walk around with a Yamaha 225.
    Here is my other boat I bought it last spring.
  18. Sep 14, 2021 at 10:15 AM
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    I put Firestone air bags on the rear axle of my '07 Ram 1500 to "level up" when towing our camper years ago. Worked great!
    Now, I'm not knocking the load distribution hitch but, the air bags were great for ANYTHING I put in the bed to level out the ride and of course, for pulling any variety of trailer tongue weight. Just an easy, cheap and versatile option. Cost was (then) about $200 or so. I used them for more than 10 years with no issue.:thumbsup:
  19. Sep 14, 2021 at 10:22 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Boat weights 6000. how much does the trailer way? lol.
    Don't worry, no weight police from me. but still curious!
  20. Sep 14, 2021 at 12:15 PM
    BroncoAZ
    Cape Cod, MA
    Boat and trailer combo is 6000 pounds combined, I wouldn’t try it if it were past the listed capacity. That boat isn’t that heavy for it’s size. I looked at a 25’ Hydra Sport Vector last spring, that’s a tank of a boat at 5200 pounds dry, over 8000 pounds for trailer and boat (wet).
