Towed my boat this week
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BroncoAZ, Sep 13, 2021.
  1. Sep 14, 2021 at 12:17 PM
    MGMDesertTaco
    Plus fuel, gear, people, dogs...it all adds up.
  2. Sep 14, 2021 at 12:40 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I saw someone on here awhile back that was talking bout a boat right at or above max tow rating. He didn't realize the boat's listed weight didn't include the engines, lol
  3. Sep 14, 2021 at 2:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Been on the scales with it? Or is it just reading the tags. How much fuel, beer etc.? I tow a 3500 lb loaded camper I am fully aware it's behind me even at that weight.
  4. Sep 14, 2021 at 2:36 PM
    BroncoAZ
    BroncoAZ [OP] Well-Known Member
    Cape Cod, MA
    2021 WhiteTacoma TRD Offroad
    Reading tags on both boats, haven’t had any reason to put them on a scale. For most of the time I’ve had the big boat I used my Touareg (rated for 7716# towing) or something 1/2 ton to pull it.
    The 2016 version of my Welcraft is 4200# dry with the engine, add 650# for 100 gallons of fuel, 72# for 9 gallons of fresh water, trailer weighs 1246#, so that puts it at 6168# before gear. I would guess my gear is in the 300-400# range, so we are likely a little over the truck’s capacity. I don’t know if the older hull is lighter, but the trailer that came with the the boat is rated for 6000#GVWR.
    My Noreast is a 2018, I’m assuming I can trust the numbers listed in the certificate of origin. I keep less than 100 pounds worth of gear on that one, and it’s only a 41 gallon gas tank.
  5. Sep 14, 2021 at 2:57 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Both boats are beautiful!
    BroncoAZ[QUOTED][OP] likes this.
  6. Sep 14, 2021 at 7:25 PM
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
    Trailer brake controller for sure.
    2016Tacoman likes this.
  7. Sep 14, 2021 at 7:29 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Air bags work better imo.
    Level out to 0 with any load.
    kauaihunter likes this.
  8. Sep 14, 2021 at 7:30 PM
    2016Tacoman
    J
    If the trailer had electric brakes I wouldn't have an issue.
    An 18 wheeler small semi truck cab pulls an 80,000 lb trailer just fine.
  9. Sep 14, 2021 at 7:36 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There’s a lot more to towing than just brakes. A 20k lb semi with a 5th wheel hitch is much different than a 5k lb Tacoma with a class 3 hitch.
  10. Sep 14, 2021 at 7:37 PM
    BroncoAZ
    Cape Cod, MA
    A trailer brake controller won’t do much with the hydraulic surge brakes on my boat trailer.
  11. Sep 14, 2021 at 7:42 PM
    kauaihunter
    Jay
    Electric brakes implied. I removed my surge brakes from my boat trailer because it sucked.
  12. Sep 14, 2021 at 7:48 PM
    BroncoAZ
    Cape Cod, MA
    For my use, approximately 50 miles per year on local roads, the surge brakes work well enough. The electric over hydraulic conversion is around $1000, I would consider it if I towed long distances on the highway.
    kauaihunter[QUOTED] likes this.
  13. Sep 14, 2021 at 7:50 PM
    2016Tacoman
    J
    We've been through this before. Toyota used SAE J 2807 towing standards to rate the truck higher than 6000.
    I'll put my faith in the design engineers.
    Do you think they would rate it that high due to liability concerns if it weren't capable ? Seriously doubt it.
  14. Sep 14, 2021 at 8:07 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    it’s capable of towing 6k for sure. Obviously they are rated to tow over that. So when your cousin skeeter loads up his 6k dry fishing boat with gas, food, and all the gear and is pushing 7500+ lbs. Without a weight distributed hitch, too much tongue weight, and no helper springs. Toyota has to make sure the truck isn’t going to grenade going down the road and wipe out some minivan full of kids. But only some jackass would be towing something like that at high speeds or long trips through the mountains. Plus if the above did happen Toyota wouldn’t have any legal liability for anyone towing recklessly and beyond their rated limits.
