Towing 2.4 vs 2.7
Discussion in 'Towing' started by RogueRafter, Feb 1, 2013.
  1. Feb 1, 2013 at 12:57 PM
    RogueRafter
    RogueRafter [OP] New Member
    Hello
    I have a 2003 Taco 2.4 liter engine. I use it to tow a tear drop trailer which weighs around 800 lbs. While I don't have much problem on a flat surface, It does lose speed going up a grade.
    Question:
    I'm thinking about purchasing a new Taco with a 2.7 liter motor. How much better if any will this 2.7 be able to tow the teardrop or something heavier like a boat. I'n not looking to get the V6 because of the reduced gas mileage.
    Rogue Rafter
  2. Feb 1, 2013 at 1:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It should be much better, as it has more torque. Welcome to the site, BTW>
  3. Feb 1, 2013 at 1:43 PM
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    Welcome to the group.
    I tow with the 2.4L/5 speed manual. It's fine towing a 1900lb boat @ 65MPH getting 19 to 20MPG. Also tow a CampLite 11RD 1500LB travel trailer and average between 16 to 17MPG @ 55MPH in 4th gear @ 2500RPM in non mountain areas. Have not weighed the TT or boat, just going by manufacturers weights. The wind resistance on the TT is the killer on power & fuel economy. Feels like a different (more powerful) TV towing the low profile boat.
    Have not towed with a 2.7L yet.
    Here's some info I found about the 2003 2.4 & 2.7 Tacos.
    http://www.new-cars.com/2003/toyota/toyota-tacoma-specs.html
