Towing a 19' airstream
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seahawk, May 8, 2011.
  1. May 8, 2011 at 4:21 PM
    Seahawk
    Seahawk [OP] New Member
    Karl
    Tallahasse
    2004 Tacoma
    I am looking to purchase a 19' Airstream camper. It weighs about 3500 pounds. Can my base model 2004 Tacoma handle this?
    Thanks for any advice you can give
    Karl
  2. May 8, 2011 at 4:27 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    Welcome to TW from TX.
    Are you a V6 and do you have the tow package?
  3. May 8, 2011 at 4:38 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    A 19' Airstream might 3500 lbs unloaded. Don't forget to factor in water, battery(s), propane and cargo weight. IIRC the 19' is rated at 4500 lbs.
    Since you have an 04 regular cab, means you have the one of the two 4 banger motors and probably no tow package.
    That being said...I wouldn't.
  4. May 8, 2011 at 7:41 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Buy an old suburban, it will tow that thing all day.
  5. May 8, 2011 at 8:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    So would a Tundra, Sequoia, 4runner, FJ, or even a Tacoma (properly fitted) to name a few Toyota brands. Doesn't really answers his question though.
    OP, I just checked my owners manual (also a 2004). The max cargo + tow capacity of the 4 cylinder Tacoma is 3500 lbs. Meaning if you were driving by yourself with NOTHING else in the truck, you could safely pull a 3500 pound load. I don't think you'll be able to tow that big of a trailer with your truck. Once you add a second person, gear in the bed and fluids, you will be well beyond 3500 pounds.
  6. May 8, 2011 at 8:16 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    You need a bigger truck!
