towing a 23 foot boat
Discussion in 'Towing' started by awwmann, Nov 16, 2008.
  1. Nov 16, 2008 at 8:50 AM
    awwmann
    awwmann [OP] Well-Known Member
    pat
    staten island new york/ redbank nj
    2015 4x4 double cab trd sport
    bilstein 5100/ 265/70/17
    just bought a 23 foot chris craft boat going to pick it up next week end should i have any problem towing it with my 06 double cab trd sport with towing package
  2. Nov 16, 2008 at 9:02 AM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    What's the weight? On the basis that I would think it is nowhere near the 6,500lb capacity of your truck, you'll be fine.
  3. Nov 16, 2008 at 9:25 AM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Tacoma will be no problem as all models of the Chris Crafts are well under the towing capacity.
    You experience may be a limiting factor though. If you have never towed a boat, you will need to take it slowly with a learning curve. Don't let other drivers piss you off. Most city folk don't take into account the 6000# load behind you and cut you off. Get used to it!:D
  4. Nov 16, 2008 at 9:31 AM
    awwmann
    pat
    yeah i tow front end loaders every day through brooklyn and manhattan other drivers suck the paper work for the bat says 4800 pounds so i guess i should be ok
  5. Nov 16, 2008 at 10:50 AM
    CtryBoyInMT
    Then you will be pleased with how the Tacoma tows!
