Towing a small RV
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gdgraph, Oct 18, 2020.
  1. Oct 18, 2020 at 7:45 AM
    gdgraph
    gdgraph [OP] Well-Known Member
    Northern Virginia
    2020 TRD Pro
    I'm considering a small truck because I want to eventually buy an RV (16-20') around 3,000-4,000 pounds fully loaded. I've read that you shouldn't tow something above 60% of the tow rating because power/handling diminishes quickly.
    Should I go with a full size truck to tow something that's 4,000 lbs, or will the Tacoma have plenty of power for that?
  2. Oct 18, 2020 at 7:50 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Lots of other variables, like tongue weight, frontal drag, elevation, hills, etc.
    4k loaded (actually loaded with all your stuff and passengers) is doable, but if you intend to travel often, far, and explore mountain ranges, I'd go full size. If you're only traveling flat land, a couple hours out, a few times a year; Tacoma will do fine.
  3. Oct 18, 2020 at 8:24 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If it's 4K total, meaning adding passenger weight+ everything in bed+ trailer+everything in trailer like food and water and propane tanks+dog+skid plates and mods and that all equals 4K, then the Tacoma will be fine.
    Pretty much every new person to towing forgets how much stuff weighs.
    If a trailer weighs 4K lbs, by the time you add everything I listed above you now are close to 6K lbs and that is full size territory. The Tacoma can do 6K but now you will be riding the struggle bus.
    Good luck.
    CorbinDallas, Chew, Inferno! and 2 others like this.
  4. Oct 18, 2020 at 8:30 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  5. Oct 18, 2020 at 9:38 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Agreed, I don't think most truly realize how quickly weight stacks on.
    I can't remember the number, but this did summer, my buddy bought his first travel trailer. He was weighing his combo to look at how the weight distribution setup affected truck and trailer individual wheel weights. He realized two things. 1. His weight distribution was spot on. 2. How much SHIT his family packed in the truck and trailer!
    hiPSI[QUOTED] likes this.
  6. Oct 18, 2020 at 12:22 PM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    IIRC.....
    Don't forget the "payload" allowed in the truck to bring it up to Gross Weight doesn't include fuel or passengers Put 4 big guys and full tank in your Tacoma and it's maxed out by the book.....
    We used to have a class A motorhome on a 2 1/2 ton chassis that was this way. Full tank of fuel, full water tank and the "optional" factory installed generator raised the weight to a point that we couldn't (by the book) tow more than 800lbs.
    Chew likes this.
  7. Oct 18, 2020 at 12:27 PM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Keep it on the lower side of 3000 dry and it’ll do fine!
    S4 + ECT = success
    GarlicFarts likes this.
