Towing and Fuel Economy Testing (14mpg) with a 2019 TRD OFFROAD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xzatx, Jul 11, 2019.
  1. Jul 11, 2019 at 7:38 PM
    xzatx
    xzatx [OP] Well-Known Member
    In this video, i drive my tacoma for 143 miles under different road conditions while towing my winnebego 2100bh which is around 4500lbs WET and 400lbs of passengers inside the truck.
    Overall, the truck did really well, at long 6% grade though, i was going around 30mph to conserve fuel behind a walmart truck :D
    however you could push it and go faster..
    overall,
    143 miles
    10.3 gallons consumed
    13.88 MPG
    https://www.youtube.com/watch?v=gG4BafVOn7g&t=249s
    Inferno! likes this.
  2. Jul 11, 2019 at 8:24 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    That's better than what I usually see towing my Coachman 204RD with a weight of just under 5K wet. Lowest I've was around 8mpg and best was about 12.5. Normal condition with no wind and flat running 65 I see about 11.5mpg.
  3. Jul 11, 2019 at 8:48 PM
    xzatx
    the speed changes everything. i found that tacoma is very happy at around 2100rpm.
    so. i adjust my speed to that, that's why you see me crawling 6% grade at like 38mph haha :D.
    i also found that you dont really need ECT and no need to stay in 4th gear if your rpm is at 2k. and your transmission is not jumping up and down. so i was able to cruise at 5th speed most of the time which also helped.
    Just be careful in heavy descents to adjust the brake controller well and adjust your engine braking properly.
    Ruggybuggy likes this.
  4. Jul 12, 2019 at 10:09 AM
    xzatx
    i had few questions on my weight distribution set up, its husky centerline 400lbs to 600lbs tongue.
    nice WD hitch and it's about 100lbs weight.
