Towing and wheel spacers - any issues?
Discussion in 'Towing' started by KDOG, Feb 4, 2014.
  1. Jun 16, 2014 at 6:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Well then you would be incorrect
  2. Jun 16, 2014 at 6:31 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Well say what you want but it's not a secret cast aluminum isn't as strong as billet. I learned that when screwing around with paintball crap years ago.
    I got my spacers for cosmetic at this point. Put my tires out exactly where I wanted. I also got them for future plans of lift and bigger tires one day.
    I personally don't see the difference between the spacers and wheels with different offset, either way the tires are farther out than designed. I know it hasn't been brought up yet but that's going to be shortly...
  3. Jun 16, 2014 at 6:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. I understand wheel studs are more prone to breaking off due to improper applied torque but with spacers, you've just doubled the chance for failure. There's an added failure point. Before you just had 6 wheel studs that need to be properly and evenly torqued per wheel, with spacers you have 12. All things being equal, that's still double the chance of failure.
  4. Jun 16, 2014 at 6:34 PM
    wake100
    Syracuse, NY
    How? Using an impact or torque wrench? I used to work installing tires and all I will say about that and the dipshits I worked with is there is a reason I do my own work...
  5. Jun 16, 2014 at 7:22 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Sorry Mike,,, I don't buy it.....thats like telling me my 10 wheel tractor attached to my tri-axle trailer now has more chance to loose a wheel compared to an 18 wheeler..... TORQUE IS TORQUE should not matter on number of matching surfaces unless someone gets lazy or should not be "touching" things they know NOTHING about...
  6. Jun 17, 2014 at 7:38 AM
    Pugga
    Massachusetts
    Not quite the same. Bolts can fail for multiple reasons, case in point is Monkeyproof who had his studs fail due to fatigue from constantly changing wheels around. With wheel spacers, you don't have 12 lugs all holding on one wheel, you have 6 studs holding in 6 more and 2 planes of potential failure (between the hub and the spacer and between the spacer and the wheel). Whether you buy it or not, there is more opportunity for failure with wheel spacers than without.
  7. Jun 17, 2014 at 7:41 AM
    OZ-T
    Peter North
    British Columbia
    I don't buy it
  8. Jun 17, 2014 at 7:55 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Agreed that the chances are more likely but from improper install rather than the spacers themselves. It just adds 24 more opportunities for something to fail. It only makes sense that if "something" can break and you double that "thing"... It doubles the chances of that "thing" breaking... :confused:
  9. Jun 17, 2014 at 8:41 AM
    wake100
    Syracuse, NY
    with the idea of the lugs fatiguing the spacers aren't being taken off and put back on repeatedly. also taking an exception and quoting it as the norm doesn't seem right. the two examples of why its bad sounds like one was over torqued and the other one was a guy that liked different wheels a lot... those are exceptions. how about the rest of the guys that say they are fine and had no issues that rotate tires at normal intervals only and torque them correctly?
  10. Jun 17, 2014 at 9:22 AM
    Pugga
    Massachusetts
    Yeah, but you're in Canada, the ice will hold your wheels on year round :cool:
    More or less.
    No where did I exaggerate and say that an outlying case was the norm. I simply said it introduces more points for potential failure. There are obviously lots of people who run them without issue and I would 100% agree that they can be run without issue. That being said, I wouldn't put them on my vehicle and I've stated one of my reasons. The other is I don't want the added stress they put on wheel bearings or other suspension parts.
  11. Jun 17, 2014 at 9:32 AM
    OZ-T
    Peter North
    British Columbia
    at least I own a Tacoma
  12. Jun 17, 2014 at 9:49 AM
    Pugga
    Massachusetts
    I'm sure I don't know what you're talking about :anonymous:
  13. Sep 5, 2015 at 7:38 AM
    TacoSauceHB
    TacoSauceHB Well-Known Member
    Brian
    Rathdrum, ID
    2017 _TRD Off-Road DCLB 4X4 Tech Package
    King 2.5 ext travel, Camburg uniball UCA, SCS Ray10 wheels, 285/75/16 Cooper STT Pro's, CMC , MBRP exhaust, K&N cai , OVTune 1.05 , T-rex billet grill, Rigid DS Pro ditch lights, SDHQ ditch light brackets, Leer 100XQ Shell, ShmellFab Sliders, Victory 4x4 Roof rack, LED headlights. SOS Concepts bumper, Smittybilt X20 Winch, Nitro 5,29 gears, ECGS clamshell bushing.
    Same thing just happened to me . Iv had the spacers and wheels on the truck for 2.5 yrs now. I do all my own work and always use torque wrench. I used 85lbs on both wheel and spacers along with lock tight with the spacers and a proper criss cross install. Only taken the wheels off once to replace brakes in the 2.5 years. Yesterday I was driving home from welding class and noticed a vibration start suddenly so I got over into the carpool lane so I could pull over on the shoulder to check and when I hit the brakes SNAP!! And my brake pedal lost pressure since the rotor was moving all around . Luckily it was a straight section and I was able to slide to a stop while watching my (285/70/17) wheel almost take out multiple cars as it cruises another mile down the freeway before coming to a stop. If you live in So Cal you know how terribly bumpy the 91 freeway is out bear the 215 and I suspect the lugs were already stressed and weakened but the bumpy freeway was the straw that broke the camels back. After talking to a friend of mine who has a long travel tacoma I learned the same thing happened to him out in the dessert and was stranded for 7 hours. He said his wheel spacer was still bolted to the wheel just like mine . I don't buy the whole ( over-under torque) issue because I know confidently mine were properly torqued. Especially mud tires in combination I think just puts to much extra leverage on the lugs than the grade they are designed for.
    What are your thoughts ?
  14. Sep 5, 2015 at 7:48 AM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    My thoughts, don't run spacers. Get a properly backspaced wheel. Seen this happen in person twice.
    TacoSauceHB likes this.
  15. Sep 10, 2015 at 8:46 AM
    #35
    wake100
    Syracuse, NY
    makes me wonder actually... it was the trucks lugs that failed
