Towing Harness Relocating Bracket (T.H.R.B.)
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Andres, Mar 7, 2018.
  1. Sep 17, 2018 at 8:08 AM
    #401
    Andres
    Andres [OP] Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    How was the fitment?
    Is there anything where I can improve?
  2. Sep 17, 2018 at 6:48 PM
    #402
    Taco4Life89
    Taco4Life89 Well-Known Member
    NM
    2015 DCSB TRD OR 4x4 6 SPEED
    Fitment was great and went on smoothly. It's so simple yet badass that I don't see how you can improve it. Maybe put a Toyota logo on it? I don't know. Lol
  3. Sep 18, 2018 at 6:45 AM
    #403
    Andres
    Andres
    Hawthorne, CA
    I'll keep it in mind.
    :thumbsup:
    Taco4Life89[QUOTED] likes this.
  4. Sep 19, 2018 at 6:15 AM
    #404
    Andres
    Andres
    Hawthorne, CA
    Did you get a change to install it yet?
  5. Sep 19, 2018 at 12:55 PM
    #405
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Dang, bought a used one. Didnt know they restocked! Still stoked
  6. Sep 19, 2018 at 1:17 PM
    #406
    Andres
    Andres
    Hawthorne, CA
    All good brother.
    What matters is that your harness will be out of danger.
  7. Sep 19, 2018 at 1:17 PM
    #407
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Man, I should have had one of these on my last trip. Does anyone have a full towing harness that the THRB relocates? Mine is mangled... see my want ad. Would like to get a replacement that I can just plug in. The plug is critical, the bracket that goes on the hitch to hold the plug in factory location is not critical...
    https://www.tacomaworld.com/threads/wtb-towing-harness-and-mount.569058/
    Thanks for any leads!
  8. Sep 19, 2018 at 4:08 PM
    #408
    Andres
    Andres
    Hawthorne, CA
    If you're unable to find a factory Toyota plug this might help:
    https://www.tacomaworld.com/threads/7-pin-trailer-harness-plug-replacement-tip.288024/
    It's a Honda harness identical to Toyota's and it's only around $50 (vs. $175 from Toyota).
    You will need to swap out a few pins, not hard at all.
    For about $50, 2 hours of your time and one THRB you'll be golden.
    :cool:
    Good luck mate!
    :cheers:
    TRDSport10 and medjah like this.
  9. Sep 20, 2018 at 5:15 AM
    #409
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    I would like to buy a black one.
  10. Sep 20, 2018 at 6:57 AM
    #410
    Andres
    Andres
    Hawthorne, CA
    Brackets are available at Diazfabrication.com
    :cheers:
    medjah and Stryker420[QUOTED] like this.
  11. Sep 22, 2018 at 9:05 AM
    #411
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Got mine installed, on the whole I like it, fit and finish is good. However, you asked for comments. I suggest the holes used to attach the THRB to the truck be drilled and tapped all the way through to the bungee cord opening. As it is now you supply 3/4 inch screws. The truck bracket is about 1/8 inch thick and its weld nut is another 1/4 inch thick (see picture above). This results in the THRB being held to the truck by 1/4 - 3/8 inch of screw thread. I attempted to use 1 inch screws, and that is when I discovered the holes were not deep enough to accommodate a 1 inch screw.
    I am still thinking about drilling out and tapping the THRB but it started to rain and so its currently installed stock w/no mods.
    Edit: Andres, you supply SS screws. The THRB is aluminium. I suggest to include a note recommending a drop of blue Loctite or a dab of anti-seize on the screws.
    TRDSport10 likes this.
  12. Sep 22, 2018 at 4:09 PM
    #412
    20somethingwidataco
    Will
    Washington State
    What bolts do I need for these? Just got mine today and the stock bolts dont work
  13. Sep 22, 2018 at 4:36 PM
    #413
    rnish
    Tacoma 2nd gen
    Mine came with 4 - 3/4 inch SS hex head. I believe 1/4 20 thread. Please post pictures, how do they not work?
  14. Sep 22, 2018 at 5:56 PM
    #414
    20somethingwidataco
    Will
    Washington State
    Stock bolts were too big. I bought some that worked. I bought mine used with no hardware.
  15. Sep 22, 2018 at 6:12 PM
    #415
    rnish
    Tacoma 2nd gen
    :thumbsup:
  16. Sep 24, 2018 at 3:36 AM
    #416
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mounted mine to the bumper on the floor in the garage...........now bumper on floor in garage needs to migrate to the truck!
  17. Sep 24, 2018 at 6:51 AM
    #417
    Andres
    Andres
    Hawthorne, CA
    Correct, it is not designed to accommodate 1" screws.
    Are you aware that the screws provided were 1/2" and 3/4?
    The 1/2" screws should be located at the harness molding and the 3/4" longer screws should be located at the frame holding the bracket.
    1/4" to 3/8" thread length is ideal to hold the bracket in place.
    There isn't any advantage of extending the length of the thread past a given length, there's a formula to calculate the thread strength but in this case the screws aren't taking any crucial load force they're simply holding an aluminum piece in place.
    Not contradicting you, just pointing out stuff.
    In fact I enjoy these small mechanical debates, exercise for the brain. ;)
    Personally I don't like the idea of the holes going thru the bracket as debarring a threaded exit hole onto a side that's not flat is a b!tch to deburr.
    If I decide to extend the length of the thread I may as well move the bungee cord holes back so there's more material to extend the depth of the thread and the holes don't have to go thru.
    Appreciate the feedback, good call on the anti-seize. :thumbsup:
  18. Sep 24, 2018 at 6:53 AM
    #418
    Andres
    Andres
    Hawthorne, CA
    1/2" screws should be at the harness side
    3/4" screws should be at the frame side
  19. Sep 24, 2018 at 9:13 AM
    #419
    rnish
    Tacoma 2nd gen
    Yes, I got the 1/2 and 3/4 inch screws situated correctly. I didn’t drill through and replace the 3/4 with a 1 inch screw. The way the hole is offset I was concerned about weakening the whole structure if I drilled through. What I did do was grind down a 1 inch screw and created a nominal 7/8 inch screw. I picked up 2 maybe 3 threads.
  20. Sep 28, 2018 at 12:34 PM
    #420
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    FED5E364-796F-4DA5-B7BC-94E013B5C95F.jpg My plug was pretty hammered. I was able to use a little redneck engineering and sandwich it together with the factory bracket for time being while I wait for my replacement. Lol, it’s ugly as hell right now but it’s out of the way.52E5FDB4-D45D-494C-8650-2D8D6E2BEE8C.jpg
