Towing my boat
Discussion in 'Towing' started by chappie99, May 24, 2017.
  1. May 24, 2017 at 6:16 AM
    chappie99
    chappie99 [OP] New Member
    Greetings-
    I have a 24' boat w/ with trailer, full belly of gas, and gear ~5500lbs, give or take a 100lbs. I've never weighed mine but have read same boat weighs in at 5200lbs w/ full load and others say 5600lbs.
    Really want a '17 Tacoma b/c 1)I like the look and 2)I can park it in my garage vs full size.
    --Concerned about being so close to tow capacity of 6400lbs.
    --Towing guide I'm using has '17 engine as 4.0L V6 but new Tacoma's have 3.5L V6
    http://webcontent.goodsam.com/trailerlife.com/digital_editions/TrailerLifeTowGuide2017.pdf
    From what I've read on this site, sounds like Tacoma can handle the load but still bit concerned mainly b/c I dont want to drop $30k on a truck only to find it cant handle it down the road, no pun intended.
    And curious if anyone using 3.5L V6 (vs 4.0L V6) has any drop in towing performance?
    Would appreciate any feedback.
    Cheers.
  2. May 24, 2017 at 6:24 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Short distances will be fine
  3. May 24, 2017 at 7:26 AM
    chappie99
    Yes. I should've mentioned that most of the towing will be short distances on flat terrain. However, plan to take it on some trips to lakes in the region that has hills (Mid-Atlantic region) ie going to Deep Creek Lake this summer. 200 miles one way, with some climbing.
    I see trucks w/ a "tow mode" button. Do you have to be in tow mode anytime you are towing or just for more strenuous parts ie climbing or pulling out from ramp? Does Tacoma have a "tow mode"?
  4. May 24, 2017 at 7:41 AM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    hills will suck. I have the 4.0 litter older motor 06
    I pull my 20 ft boat and fully loaded for camping. It dose pull it but hills suck and brakes suck. if it was me I would get a full size, I wish I had one and my boat is much lighter. but with the 500lbs of armor and all the gear its probably close to 5000lbs total load. like said above it will do it, but you wont like it.
  5. May 24, 2017 at 4:52 PM
    jake72
    Jake
    N.E. PA
    Use ect button and drive in 4th gear
    lsutiger1 likes this.
  6. May 24, 2017 at 5:04 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    I have a 24' formula speed boat. On a saturday shes freighted with shit runs about 5750 ive been towing it with my taco all around town. I live in NH where it is steep hills and constant speed changes. She does great in ect and s mode. Boat launches are minimum of 6 miles away and gas is in the opposite direction. Your good!IMG_0731.jpg
  7. May 24, 2017 at 5:32 PM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    What is ect?
  8. May 24, 2017 at 5:36 PM
    Arlaghan
    Arlaghan Well-Known Member
    Alex
    Redmond, WA
    2017 Red TRD Off-Road
    I believe it stands for electronic controlled transmission or something like that. Changes the shift points to maximize power. At least that's what I understand.
  9. May 25, 2017 at 3:07 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Yeah, I looked it up. Thanks! I wish that I had it on my 2015
  10. May 25, 2017 at 6:29 AM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Sounds fancy. My o6 has no bells and whistles.
  11. May 31, 2017 at 7:16 AM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Maybe get some Sumo Springs. I bought a pair but have yet to install.
  12. May 31, 2017 at 7:30 AM
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    rear suspension upgrade or air bags will be a must. also the brakes if you doing steep grades. i run the
    Power Stop K137-36 Front Z36 Truck and Tow Brake Kit
    and coming down a long grade i had to pull over as the brakes over heated and i had sever brake fade. not fun heart was racing. as for the rear i have the all pro expo leafs and after two yrs of pulling the boat those have started to sag with the weight. I used to run air bags those will work great for stock height .Im now thinking of going with the big brake kit as that shit was scary coming home . Either that or full size truck for the boat.
