Towing Questions
Discussion in 'Towing' started by F-125Racer, Nov 3, 2009.
  1. Nov 3, 2009 at 6:49 AM
    F-125Racer
    F-125Racer [OP] Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    I'm a noob here, trying to learn about my taco, but I've lurked for a few months. Great group here, super informative.
    I am towing a single-axle, 6' x 6' x 12' long, V-nose Featherlite enclosed trailer with a total weight of 4,400lbs, with about 500lbs on the front. Friction-type sway control is installed. I just finished my first trip and I've got a few questions I didn't find when searching:
    1) The truck handled the weight fine, power was ok. Shifting didn't seem right. On cruise, the tranny would downshift on small grades. When I drove without cruise, I could easily hold speed with minimal accelerator pedal movement without the tranny downshifting. By driving like this, I could go a long way with some sizeable grades maintaining 75 mph and the tranny would never have to downshift. Then I'd punch in the cruise and I would get one, and sometimes two downshifts on similar grades, then it would "hang" at high rpms for quite a ways past the crest of the hill, at the pre-set speed. I ended up not using cruise at all. Is there any fix for this ?
    2) Anybody towing with a supercharger ? Did the re-flash help the shifting, or did the additional power just let the truck stay in higher gears ? I got about 10mpg on the trip, would the S/C make this better, worse, same???
    3) Are there any published dyno charts showing stock HP and Torque, vs supercharged HP and Torque across the rpm range ?
    4) Any other reco's for more towing power, better mileage, better shifting?
  2. Nov 3, 2009 at 7:00 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Towed a Porsche from Cincinnati down to Atlanta on a flat bed trailer. Mine did the same thing. I never use cruise when I tow. It always seem to give it way to much gas on small hills and then its hunting for gears the whole time. Towing my boat (2800 LBS) I'm usually at 12-14 mpg..
  3. Nov 3, 2009 at 7:24 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    I would recommend not useing your cruise control while towing. Downshift to 4th gear if your transmission is hunting for a more suitable gear while going up hills, and downshift to 4th while going down hills to take advantage of engine braking. If the transmission is constantly searching for a gear you'll take a chance of overheating or damaging your transmission...especially since the sport models don't have the transmission coolers.
  4. Nov 3, 2009 at 7:36 AM
    MAXTacoma
    Lexus GS 350
    Sports dont have trans. coolers???? I thought that the tow package gave you a trans cooler?
  5. Nov 3, 2009 at 7:52 AM
    OffroadToy
    I stand corrected. For some reason I was thinking it was part of the Offroad Package.
  6. Nov 3, 2009 at 8:02 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Cruise control does this to me a lot on grades even while im not towing. I dont think it was the towing giving you hassle.
  7. Nov 3, 2009 at 8:04 AM
    MAXTacoma
    Lexus GS 350
    Ok that made me a little nervouse, I tow a lot so having the cooler is very important.
  8. Nov 3, 2009 at 11:32 PM
    MMOCGuy
    MMOCGuy Active Member
    Norm
    N. California
    09 Tacoma 4wd
    It could be happening because the cruise control operates by "Sensing" the amount of drag in the engine when climbing a hill and responds accordingly. This is a bit of a simplified explanation but it might help. When you have extra weight on the back as in towing a trailer, the criuse control thinks there is more engine lugging going on that actually is so it wants to downshift sooner and more often than if the extra weight wasn't there.
    Personally, I never use cruise control when pulling a trailer. I want to control the transmission and throttle myself in case I have to take evasive action or slow suddenly. Another reason I don't like to use cruise control is that it uses the truck brakes to maintain the speed when going downhill. I'm not sure if it applies the trailer brakes also and if it doesn't, it makes it hard on the truck front disks trying to hold back all of that extra weight.
    I hope this helps.
    Norm.
  9. Nov 4, 2009 at 12:09 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    you can find some dyno graphs HERE
  10. Nov 4, 2009 at 9:05 AM
    F-125Racer
    Arkansas
    Ever seen a chart just like that for the TRD supercharger ?
