Towing weight,
Discussion in 'Towing' started by Ray99Xcab4x45spd, Oct 26, 2011.
  1. Oct 26, 2011 at 8:55 PM
    Ray99Xcab4x45spd
    Ray99Xcab4x45spd [OP] Member
    Ray
    Bay area
    99 xcab 4x4 5speed
    3"spacers in front add a leafs in back kyb mono max all around onboard air k&n dynamax muffler 32X11-1/2 procomp mud t/a
    So im getting a Heartland edge M21 21' trailer dry weight of 3200lbs, wet and full of gear plus bike probbly a lil over 4000lbz ive towed the trailer allready just wondering if anyone tows regulary this much? and first thread and this site is pretty cool
  2. Oct 26, 2011 at 9:00 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
  3. Oct 26, 2011 at 9:01 PM
    Apple X C0re
    Apple X C0re Atomic Punk
    Josh
    Franklin, NC
    01 Tacoma SR5 4x4
    De-badged, MetalMiller grille emblem, brush guard, K&N Intake, Thrush tube, Black euro tail lights, Various scratches, Cobra 29LTD CB with custom echo board, 10" sony subwoofer with MTX amp, Black low-profile tool box, 5% tint all around.
    I've hauled well over that much with my Tacoma. I suggest using a trailer brake (if possible), if your hauling regularly. The light Tacoma tends to get loose with a heavy trailer.
    Also, Welcome to Tacoma World :D
  4. Oct 26, 2011 at 9:04 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    yea i've got a weight distribution hitch with sway control and the prodigy controller
  5. Oct 26, 2011 at 9:06 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    the trailer has brakes on both axles
  6. Oct 26, 2011 at 9:09 PM
    Apple X C0re
    Josh
    Franklin, NC
    01 Tacoma SR5 4x4
    You'll be fine then, no problem. My dump truck broke down on the scales at the quarry once, had to use a tow strap to get it home, which was about 5 miles. It weighed around 18,000 dry, and the 2.7 4cyl had plenty of power to do it. Do you have the 6cyl or the 4cyl?
  7. Oct 26, 2011 at 9:11 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    3.4 6cyl with exhaust and k&n
  8. Oct 26, 2011 at 9:12 PM
    Apple X C0re
    Josh
    Franklin, NC
    01 Tacoma SR5 4x4
    Good deal, nice truck.
  9. Oct 26, 2011 at 9:15 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    You towed 18,000lbs with a 2.7l tacoma?:confused:
  10. Oct 26, 2011 at 9:16 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    thanks! 2nd owner bought it in 2001 with 40k and its done everything i wanted it to do and then some.
  11. Oct 26, 2011 at 9:17 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    seems a bit much no? :confused:
  12. Oct 26, 2011 at 9:22 PM
    Apple X C0re
    Josh
    Franklin, NC
    01 Tacoma SR5 4x4
    Heh, yes I did. Tried to get my dad's dodge but he was working on it at the time. :rolleyes: I hooked the tacoma up, and had dad drive the dump truck/operate brakes. Couldn't crank it because the water pump locked up and sent the fan into the radiator. Had to use 4lo to get started, then switched to 2h after about 15 mph. It was interesting, but it did it with no complaints. Everyone that saw it was speechless. Wish i would have taken a video. :(
  13. Oct 26, 2011 at 9:43 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    yes after browsing some threads i think im golden so off i go this weekend when i pick up the trailer pics when i get back
  14. Oct 27, 2011 at 9:27 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    This is too much for your truck IMO.
  15. Oct 28, 2011 at 6:21 AM
    frano
    frano Member
    Western MA, USA
    2011 Tacoma Double Cab
    I'm towing a 2012 Edge M21 also. I have the V6 auto with factory tow package, a WD hitch, sway control and brake controller and have no problems except poor (10 MPG) mileage at turnpike speeds. Truck is comfortable towing the M21 through the hills of New England. By the way, look into joining the Heartland Owners Club--we did the Bath,NY rally a few weeks ago and had a blast.
  16. Oct 28, 2011 at 8:28 AM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    thanks will check it out and thanks again for the input guys!
  17. Oct 30, 2011 at 7:40 PM
    Ray99Xcab4x45spd
    Ray
    Bay area
    99 xcab 4x4 5speed
    so yes got the trailer and tows great better than i thought milage not as bad as i thought about 10-12 mpg
  18. Nov 1, 2011 at 7:43 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Nice trailer, it looks to have reasonable ground clearance and overall height. A lot of modern trailers seem to be all jacked up in the air for no good reason and making the trialers sit high makes for a lot more wind resistance. Your trailer looks to have relatively good aerodynamics compared to some.
