Towing with 2.7L?????
Discussion in '4 Cylinder' started by akwagon, Sep 24, 2009.
  1. Sep 24, 2009 at 11:27 AM
    akwagon
    akwagon [OP] Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    I have an 09 Access cab 4x4 4 banger. I know it is rated to tow 3500 lbs. Just curious, I know the V6 is rated at towing at over 5000 Lbs. As per the suspension, brakes, weight. There really isn't any diff. in those areas between my truck and a V6. I didn't by this truck for daily towing, or anything over 3500 Lbs. Question is, say for example had to hook something up to tow it a mile or two (on the flats), this truck could do it just as as safely as the V6???
  2. Sep 24, 2009 at 12:01 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I don't understand what happened between the 1 gen and 2nd gen Tacomas as far as pulling?? My 04 2.7l 4 banger is rated to pull 5000 lbs.... at least I sure thought it was??
    I've never overloaded my Tacoma, but my work truck is a F250 and I have routinely pulled many thousands of lbs more than it was rated for on a 25' dual axle trailer loaded up with sheetrock. The only issue was the braking... on some down hills there would be no way I could completely stop, and that wasn't good at all.
  3. Sep 24, 2009 at 12:23 PM
    akwagon
    chris
    alaska
    08 Access 5spd 4x4
    Interesting, so the Gen 1 Inline 4 was rated for 5000 lbs. I know that on the gen 2 the suspension frame, brakes, etc are all the same as the v6. Only diff is the power and the tranny....
  4. Sep 24, 2009 at 4:32 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i think the V6 is only rated at that if you have the towing package...not to sure tho...my dad has the towing package ant it's rated at 6500 i believe...
    i think it's cause our trucks are so light as well...and the brakes are a bit on the small side...but power wise the truck should be able to tow
    3500 is the same whether it's my truck (a single cab 5 lug) and yours....so im pretty sure in reality you can tow more than me. you have a better axle ratio as well so power shouldn't be the problem..
  5. Sep 24, 2009 at 5:06 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    I just looked up the '04 2.7L Taco on Edmunds.com and according to them they were rated to tow 3500 lbs too. That's 2WD or 4x4... all cab configurations... all 3500-lb towing capacity.
    As far as what the 2.7L can safely tow... plenty of people on here tow with them... boats, motorcycle trailers, utility trailers, enclosed trailers... you name it. You'll be fine all the way up to the 3500 lb. capacity. I tow my 17' bowrider boat (I'd estimate around 2000-lbs. with fuel and gear) with mine and the handling and braking are GREAT. It feels solid as a rock. Power is decent too. I might have to downshift to 4th gear on the larger hills, but it'll maintain speed just fine. You'd probably be OK to put a hitch ball on your bumper to two something light, but I installed a class III receiver hitch to tow my boat.
    Check out the Towing Forum on here for more info.
  6. Sep 25, 2009 at 5:47 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    my 1997 4cyl. 4x4 is only 3500lbs not 5000lbs.
  7. Oct 3, 2009 at 6:38 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I was pullin an atv on a steel trailer and my truck sucked down the gas!!!
  8. Oct 3, 2009 at 7:06 PM
    snyder
    snyder Active Member
    none, dont want to void the warranty
    I hauled 4000lb from Alaska to NY with my v6 Taco with the towing package, it performed great, no problems what so ever. Though I cut my MPG in half and gas isnt cheap. Only once I had to use 4x4 to get up a muddy hill.
  9. Oct 3, 2009 at 8:53 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    wel, if its any consolation, centerforce clutches jsut came out with a new dual friction clutch assembly for all 05+ 2tr-fe engines. might wanna take a look at it if your interested in towing and want some assistance with it.
  10. Oct 5, 2009 at 11:46 AM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    I tow my 4000lb boat almost every weekend from late march to early november. Never a problem. Brakes are great, tsb susp is great. I even towed my fully ex-caged amigo an a 18' car hauler 25 miles on hilly wisconsin/IL roads. Trailer w/amigo was about 5500lbs. The 4cyl had the power and the trailer brakes/truck brakes worke great togather.
    http://www.tacomaworld.com/forum/towing/27460-show-us-what-you-tow-3.html#post457948
  11. Oct 8, 2009 at 4:57 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I tow probably about a 2000 lb trailer with my 2.4 almost daily. It tows it with ease and never complains.
