Towing with 33s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 16taco, Jul 5, 2016.
  1. Jul 5, 2016 at 2:52 PM
    16taco
    16taco [OP] Well-Known Member
    2016 tacoma sport
    Is it safe to run 33s 12.5s and tow a small travel trailer (3,000lbs)Will this damage truck over time?
  2. Jul 5, 2016 at 3:06 PM
    0311K1LL
    0311K1LL The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    Not really, but you'll have barely any power with that set up. You could re-gear your truck to gain back mpg and power.
    GillyLink likes this.
  3. Jul 5, 2016 at 3:08 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Just don't put it in "drive" if you have an automatic. Hopefully you have a tow package as well. It's gonna drive like a cow with an attitude problem I'd bet.
    0311K1LL likes this.
  4. Jul 5, 2016 at 3:09 PM
    0311K1LL
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    Especially with the new 16 transmission. Just use ECT and save $ for re-gearing both diffs.
  5. Jul 5, 2016 at 4:16 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    What is the best gear ratio for gain mpg and lower?
  6. Jul 5, 2016 at 4:24 PM
    16taco
    2016 tacoma sport
    Thanks is regearing opening a can of worms? How much for reagearing approx.?
  7. Jul 5, 2016 at 4:41 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That is about 8% larger diameter tire than factory, it will reduce the amount of power getting to the wheels by about the same amount. A lot depends on how much your truck is rated to tow. My Tacoma is rated for 6500 lbs. I went from the factory 31" tires to a 32" tire, about 3% larger. I can't tell any difference at all in performance or fuel mileage. If yours is rated for 6500 lbs towing less than 1/2 that even with the larger tires won't make any noticeable difference. Some Tacoma's are rated for much less weight depending on the engine, transmission and gear ratio. If your truck is only rated for 3500 lbs, then towing 3000 lbs with larger tires might make a difference. Most Tacomas come with 3.73 gears anyway. You shouldn't really have to worry about re-gearing until you get to 35" tires if you have 3.73's from the factory.
    synaps3 likes this.
  8. Jul 5, 2016 at 4:42 PM
    digitaLbraVo
    Stop. Your math is wrong. The size difference alone is not what matters, a load E tire that that's 12.5" wide is a lot heavier than the passenger crap that comes outta the factory on these trucks.
  9. Jul 5, 2016 at 4:50 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Size definitely matters...
  10. Jul 5, 2016 at 11:40 PM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    LOL your all sorts of wrong. these trucks come with 3.90 gears. Nitro recommends 4.88 with 33s on these truck. Overland already has their truck regeared with the 4.88s said they gained back 1.5mpg with a lot better shift patterns. I'll be looking into doing this in the near future.
  11. Jul 6, 2016 at 4:08 AM
    Marshall R
    Marshall
    none
    The math is right on the money, a 33" tire is 8% larger diameter than 30.5" tire that comes from the factory, plus most tires advertised as 33" are actually closer to 32.5. Towing a 3000 lb trailer with 33" tires will be no problem if his truck is rated to pull 6400 lbs with factory tires. If his is rated for only 3500 lbs then he has a problem.
    Of course they recommend different gears, they want to sell them to you. Didn't realize the 3rd gens were coming with 3.90's. But if anything that tells me it will be even less of a problem.
    synaps3 likes this.
  12. Jul 6, 2016 at 4:11 AM
    catfish37
    catfish37 Well-Known Member
    16' dcsb trd or 4x4
    I agree completely. Mine has3.90's I really think the truck could use 4.30 stock. If your planning on 33's I would definitely go with 4.88.
  13. Jul 6, 2016 at 4:11 AM
    pngo121
    Phi
    Pittsburg, CA
    4.56 and 4.88 cost is the same. follow the expedition overland build. they have a video answering several questions regards to gearing for the 3rd gen.
  14. Jul 6, 2016 at 5:34 AM
    pngo121
    Phi
    Pittsburg, CA
    crispy77 likes this.
  15. Jul 6, 2016 at 8:06 AM
    tuftster
    tuftster Well-Known Member
    SF East Bay
    2016 MGM TRD OR
    For what it's worth, I've got 32" Cooper STT Pros (54lbs each) and I've towed a couple trailers recently about 6,000 lbs and the truck did really well. Wouldn't win any drag races but had no problems at all. I wouldn't make a habit of it and I wouldn't want to do it in the mountains without trailer brakes but 33's with a 3,000 lb trailer should likely be fine. Do you have the tow package? If not you might want to look into a trans cooler.
    I also know someone with a 3rd gen who recently towed a 12,000 lb trailer :spy:. Only about 30 miles but it did make it up a 20% grade dirt road...from what I hear. (Don't try this at home kids)
  16. Jul 6, 2016 at 8:50 AM
    digitaLbraVo
    You're assuming the diameter change is the loss of power in larger tires. Protip: it's not.
  17. Jul 6, 2016 at 8:57 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    dont forget trans temps. your transmission is working much harder trying to push 33s and stock gearing. now this is not apples to apples, but my 03 with stock gearing and 33s my trans temps would get in to the 220+ range just DDing, on long hills 260+ so not good. after regearing, always under 200 and 230ish on hills.
  18. Jul 6, 2016 at 11:47 AM
    Reh5108
    Idaho
    I'd disagree. You have less torque with a larger tire.
    I don't think you can limit it to solely one factor for power loss.
  19. Nov 22, 2020 at 5:04 AM
    nwflsr4x4
    nwflsr4x4 Well-Known Member
    Donny
    Pensacola Florida
    2019 White Tacoma SR
    I know this thread is old, but I just towed over 20hrs to get to my destination for the week and I need to advice. I’ve got a 2019 automatic v6 with a 3” lift and 33” Toyo at3s. With my current setup, my truck tows like garbage. I’m only towing a 4x8 trailer with maybe 600lbs. My tires weigh 55lbs each so I’m wondering if I go with tires that are still 285/70/17 size but weigh 42lbs, if it’ll make that much difference. I love my Toyos but I’ll be making this trip fairly often.
    LostHusker likes this.
  20. Nov 22, 2020 at 5:25 AM
    6300'asl
    6300'asl Member
    2020 dcsb sr5
    2-1 level 265/75/16 Rb20 running boards Weathertech vent visors Trifold cover
    Yes, 13 lbs per tire woild make a large difference towing on the hiway. Big change in accel/braking and gear hunting.
