towing with new 09 4 banger???
Discussion in 'Towing' started by BLUVVV, Dec 10, 2008.
  1. Dec 10, 2008 at 8:47 AM
    BLUVVV
    BLUVVV [OP] LARGE Member
    Bryce
    Valley Center, CA
    11' A/C TRD O-R PreRunner
    flowmaster 40, blackout headlights, 10'' infinity subwoofer, custom rear enclosure, kicker mono amp. 5100's set at 2.5'', 32'' pro Comp Xtreme M/T tires, Pioneer dub din head unit, K&N CAI, MB Motorsports V-Drive rims
    So Ive been tellin my old man about how much i like my truck...so he went out and bought a new 09 acc. cab tacoma...its the low one with the 4 cyl. engine... he wants to tow a 10' trailer with 2 quads on it...so my question is this too much weight for that truck?
  2. Dec 10, 2008 at 8:49 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    nope i would do it with mine!!
  3. Dec 10, 2008 at 8:55 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I tow 2 sleds & 10' aluminum clamshell trailer, total weight is short of 2k. There is a great stickey with tow info Maverick has done here to help. Go for it, add a stiff hitch & harness if it doesn't have the tow pkg.
  4. Dec 13, 2008 at 5:42 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    My 09 2wd 4 banger pulls my Carolina Skiff with no problems. The Auto LSD even lets me put it in the water using a sand ramp on the side of a canal. Actually it lets me get it out of the water.
  5. Dec 13, 2008 at 1:16 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    My buddy tows 2 quads on a 10 or 12' trailer in a 4banger jeep... the taco will be fine.
  6. Dec 14, 2008 at 11:50 PM
    08BlackTacoma
    08BlackTacoma Well-Known Member
    South Florida
    09' Double Cab V6 SR5, Long Bed, TRD Sport
    i plan to tow a 5k trailer with my 08 taco 4 banger.
  7. Dec 16, 2008 at 5:34 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    This is not likely to go well for you. The 4 cyl is rated to tow 3500lbs. A 5000 lb. trailer is 1500 lbs over the limit. Your ability to stop that mass on the 4 cyl brakes will be greatly diminished even if you install a brake controller, and your ability to accelerate that mass out of trouble when you need to will also be hampered. To say nothing of the stress and strain that you'll put on your trucks drivetrain that it is not rated to handle.
    Save your truck and possible the lives of some other motorists by staying within your vehicle's tow ratings. Just cause you have a truck and a trailer hitch does not mean that you can just pull anything you want. Be safe.
  8. Jan 4, 2009 at 8:13 PM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    Im awaiting my 09 4cylinder 4x4 accesscab to arrive any day now and I will be towing a small trailer and full size ATV, and later this spring a tent trailer hopefully. But I agree with everyone else, do not exceed that tow rating of your vehicle. These 4cyl Tacomas are rated for 3500lbs max! most full size qauds wiegh about 600lbs empty, so X 2=1200lbs and then make sure your flatdeck utility trailer doesnt weaigh more than 2300lbs, wich is likely that is doesnt, 1000lbs is probably the most. so that should be fine.
  9. Jan 4, 2009 at 9:00 PM
    canadiankid
    canadiankid Well-Known Member
    Langley BC Canada
    09 DC LB TRD SPORT
    Hey soundwave if you need a tent trailer I have a beauty for you when I upgrade to my Travel trailer in the spring. Here is the floorplan http://www.jayco.com/php/products/floorplans.php?id=170&mod_id=868
  10. Jan 12, 2009 at 8:03 PM
    dunkhi
    dunkhi CSULB socal
    Craig Sirois
    Southern California. Fountain Valley
    09 Ivan Stewart
    Toytec Coilover kit. Bilstein's 5100. Alcoa Wheels. General Tires. Magnaflow Cat-back. BLHM. Yellow fogs. 13TW5 jl sub. Stewart Decals.
    don't do it
  11. Mar 13, 2012 at 7:37 PM
    HedgehogOutdoors
    HedgehogOutdoors Well-Known Member
    CT
    '98 4runner SR5
    Thanks for the info everybody!
