Towing With OD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WATacoRider, Jul 5, 2010.
  1. Jul 5, 2010 at 11:49 PM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    so is it yay or nay?
    Lets say ~1500 lbs and you're on the highway and it's relatively flat. Tranny doesnt change gears at all.
    Obviously when there's hills or feeling the shifts, you go to 4. But OD with a load?
  2. Jul 6, 2010 at 12:16 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    If the truck keeps down shifting leave it in fourth. Its harder on the tranny if its constantly shifting. Sometimes I try to keep a constant speed in overdrive and than down shift into fourth manualy without moving the gas pedal. If the speed begins to increase in fourth I'll just leave it there.
  3. Jul 6, 2010 at 5:06 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I think as long as your on straight stretches your ok however when you hit the hills go to "4"
  4. Jul 6, 2010 at 6:50 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    The manual says towing in 4th gear only. I have a light utility trailer and sometimes I'll leave it in drive, but if it's loaded or I were towing anything larger, I would use 4th as recommended.
  5. Jul 6, 2010 at 6:57 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    When on a long stretch I use overdrive.
  6. Jul 6, 2010 at 10:44 AM
    kbaum08
    kbaum08 Well-Known Member
    US of A
    09 trd off road dbl cab 4x4 barcelona red
    Jason Topper, Bed Rug, Weather Tech floor liners, Garmin Nuvi 760, Scan Guage, Trd exhaust, AFE dry air filter, shrockworks rock sliders, heated seats Katzkin leather, 2+ inch OME lift shocks etc heavy duty, ARB front bumper, Warn winch, Pia lights, rocktek rear bumper, locking tailgate,
    Situation you described you are fine in overdrive, however, you should anticipate any changes and respond by manually shifting it down to possible stay in 4th.
  7. Jul 6, 2010 at 10:51 AM
    LoudDog
    LoudDog Active Member
    Washington
    2005 Tacoma 4x4 Double Cab
    K&N CAI, NWOR HD Rear Leaf Springs
    I use OD on long flat or down hill stretches. Towing 4,500 pounds it really doesn't downshift all that much on flat ground.
  8. Jul 6, 2010 at 11:07 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    At least for manual transmissions, I think it's also a matter of stopping/safety/control. If you're in 4th, the engine will begin compression braking immediately upon lifting your foot off the gas, whereas if you're in 5th it'll continue coasting. The same is true for going downhill, it's just control on tap.
  9. Jul 6, 2010 at 11:09 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I used "D" for almost the entire stretch from mt shasta down to bakersfield on hwy 99 towing probably about 3000 (between bed load, car dolly, and my loaded up 280z. As long as it's not searching for gears it should be perfectly fine. I also got about 16+ mpg.
  10. Jul 6, 2010 at 11:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
  11. Jul 6, 2010 at 2:58 PM
    cobrakenny
    cobrakenny Well-Known Member
    Ken
    Raleigh, NC
    09 TRD Crew Cab 4x4 LB
    x3
