Towing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joker2017, Nov 28, 2016.
  1. Nov 28, 2016 at 6:08 AM
    Joker2017
    Joker2017 [OP] New Member
    2017 silver Tacoma SR5
    Good morning, how do I provide power (12Volt) to the back of my truck for the winch on my trailer? Thanks in advance.
    2017 Toyota Tacoma SR5 V6
  2. Nov 28, 2016 at 7:17 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    I don´t have it set up anymore, but I had a marine deep cycle battery mounted on my trailer tongue in a marine grade battery box. Hook the winch up to that along with an on board charger. I would just charge the battery up the night before a big ride(ATV mud ride) and she was good to go. With the Taco having the bed outlet I suppose you could try to plug the charger in there, I am not sure how well it would work based on amp draw and output, but its a thought.
  3. Nov 28, 2016 at 7:42 AM
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    Depending on what you are winching (car onto the trailer?) I'd be tempted to run a separate, fused hot straight from the truck battery to a connector at the rear bumper.
    NOTE: I did not look to see if there was a 30A hot in the factory connector before saying this but even if there is - having a separate dedicated one independent of the ignition is nice for 12v trailer lighting and a bunch of other things.
  4. Nov 28, 2016 at 7:46 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    ‘25 MT6 Off-Road
    Find out the draw of the winch and calculate the cable size needed. Then purchase said cable, attach some high amp quick disconnects and make a short pig-tail off the battery. Then you can just run the cable when you are winching up and over the truck. I would NOT run a live cable all the way to the back.
  5. Dec 8, 2016 at 7:28 PM
    FlyFisher1
    FlyFisher1 Well-Known Member
    NJ
    That's what I did but I just kept the wire long and store it in the side compartment in the bed. I drilled a hole in the box and ran the wire right into it.
  6. Dec 8, 2016 at 7:49 PM
    dolooper
    dolooper Active Member
    2017 DCLB SR5 4x4, 2005 Pre-Runner AC, 1992 4Runner
    I used these to wire back to hitch mount winch on the rear receiver on both my 92 4runner and 17 Taco. The kit has quick connects and also has a switch to turn off current from under the hood so it's only running when you need it.
    I have an 8k winch that i can swap between the two or chuck in the bed/back. If you had to run longer than the 24 feet or had a winch with a substantially larger draw, this not may carry enough amperage for you. I think it's 4 gauge.
    https://www.amazon.com/Smittybilt-35210-Winch-Connector-Kit/dp/B004K23J6G
    It's an option...
  7. Dec 8, 2016 at 9:20 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
  8. Dec 8, 2016 at 9:23 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    What about a warn pullzall, but you probably already have a winch.
