Towing
Discussion in 'Towing' started by Toddn935, Jul 11, 2020.
  1. Jul 11, 2020 at 9:22 PM
    Toddn935
    Toddn935 [OP] Member
    Todd
    09 Tacoma
    3in lift xd wheels 33in Toyo tires everything LED double din Kenwood touch
    I have a 2009 Trd sport 4x4 with a 3in pro comp lift and running 33’s i purchased a camper that weighs roughly 3200 lbs dry weight. currently use my wife’s 4Runner to pull it but was thinking about using my truck next time what is y’alls opinion?
  2. Jul 11, 2020 at 9:23 PM
    KevinC
    KevinC Well-Known Member
    Kevin
    2017 SR5 Quicksand Tacoma
    The 4.0 can handle that no problem
  3. Jul 11, 2020 at 9:24 PM
    Toddn935
    Todd
    09 Tacoma
    With the lift and tire size should it matter?
  4. Jul 11, 2020 at 9:28 PM
    Toddn935
    Todd
    09 Tacoma
  5. Jul 11, 2020 at 9:31 PM
    KevinC
    Kevin
    You’re fine. Don’t go into overdrive.
    1 Bored Clerk and Toddn935[OP] like this.
  6. Jul 12, 2020 at 5:19 PM
    1 Bored Clerk
    1 Bored Clerk Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    Brakes on Tacoma's are way more of a concern for towing than power or longevity, I think. With properly set and operating trailer brakes, you should be good.
  7. Nov 4, 2020 at 11:08 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Add transmission cooler with 33s and towing. Stock gears? Definitely. Something to monitor trans temp then take for a test run.
  8. Nov 4, 2020 at 3:19 PM
    Jimiller5
    Jimiller5 Well-Known Member
    Jim
    East TN
    '15 TRD Sport
    Tonneau cover running boards Lance 1475
    4th gear is your friend.
    1 Bored Clerk likes this.
