Town Fair Tire says 16x8 wont fit!?!?!
Discussion in 'Wheels & Tires' started by Squaretail, Feb 20, 2012.
  1. Feb 21, 2012 at 11:19 AM
    tundra2tacoma
    tundra2tacoma Well-Known Member
    Greg
    Pittsburgh
    '11 DCLB SR5
    ProComp 7089 16x8, Cooper Disco ST MAXX 255/85/16, Leer cap, ome 885 and nitros in front, Wheelers 3-leaf AAL and Bilstein 5100s in the rear, ImMrYo's rear-view mirror lift bracket, BAMF LCA Skids, 4-Low yellow wire mod
    16x8 procomps fit fine. 4wheelparts and Procomp both told me they wouldn't, but so many guys here have them and said no problems so I ordered them and they fit fine. Just be sure to test fit them before you mount your tires so you can return them if necessary.
  2. Feb 21, 2012 at 5:28 PM
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    I was at 4 wheel parts today to do some pricing, I've been planning on dropping down to 16s and was a bit hesitant as to what would fit from what I've heard and sure enough the guy told me what I wanted wouldn't fit, but they had some pro comp steelies designed especially for the large caliper toyotas. 16x8 with 3.75 backspacing, not the prettiest wheels but since I take mine off road so much that my wheels are usually covered in mud, I don't really care about pretty. Plus 3.75 BS is gnarley! So... With military discount I bought those at 70 bucks a piece. Now just waiting for my 285 KM2s to be in stock and I'll post pics and how well they fit.
  3. Feb 21, 2012 at 6:30 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    I hope they realize that it's not simply the BS that causes the 16s not to fit. It's the mounting to spoke depth. Can't remember exactly what it's called.
  4. Feb 21, 2012 at 7:37 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  5. Feb 22, 2012 at 7:33 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    3.75" BS is too little for the 2nd gen trucks. They will stick out too far and you will have trouble turning without some modifications to your fenders (the metal part, not the black plastic). It happened to Zombie Runner and especk.
    You can also ask PSU Taco 85, he has 4.0" BS wheels and had to cut a lot more than those with 4.5"
  6. Feb 23, 2012 at 1:12 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    So if you are using a 16x8 4.5 bs and the spokes clear the caliper how much clearance is needed. I picked up a used set of wheels from CL in our area, having read the forums and doing some cross checking I bought them. I did not try them before buying but they were cheap had bfg ko's 265/75/16 so I could run them to see if they rub.
    They fit minor rub on flap with new tires but only very little clearance between spoke to outward facing surface of caliper maybe .03 to .04 kinda worried me made some .06 aluminum spacers at work got some E/T lug nuts now I have about 1/8 inch clearance.
    Is there a spec on what this should be or if the wheel fits use it.
    Do I need the spacers?
  7. Feb 23, 2012 at 4:48 AM
    The_Hodge
    SC
    as long as there is space, you are fine. no need for the spacers. the outside of the calipers do not move, so no need for added clearance.
  8. Feb 23, 2012 at 3:59 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Thanks I was kinda worried . :cool:
  9. Feb 24, 2012 at 6:58 AM
    Squaretail
    Squaretail [OP] Well-Known Member
    New Hampshire
    08 V6 Black Blurr
    But our calipers are free floating, correct? So, when the time comes to put on new brake pads, won't the calipers move more to accommodate the new pads? Thus, they have a higher chance of rubbing the wheels!?
  10. Feb 24, 2012 at 7:05 AM
    The_Hodge
    SC
    no, the outside of the caliper will not move. i've already done a pad change on mine w/ wheels that were ~1/16" from the caliper body and nothing changed. the pads are pressed into the rotor from outside of the pad...if that makes any sense.
  11. Feb 25, 2012 at 2:16 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    Thanks guys. Im gonna order the 16x8 from 4wp and hope for the best. If they don't fit, I'm sure I can return them before I munt the tires on?
  12. Feb 25, 2012 at 2:41 PM
    TexasTacoma37
    Ask them if you can test fit them.
  13. May 23, 2012 at 5:44 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    So what did you buy, 16's 7089 should fit.
  14. May 23, 2012 at 9:32 PM
    06tacomakev
    06tacomakev Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    I just got tired of 16 that were ordered and didn't fit. I made the right choice in a new 17 " wheel.
    I was seriously ready to blow my head off
    Too much trial and error for 16's
