Toyota 22 pin connector
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bytemyfoot, Dec 20, 2014.
  1. Dec 20, 2014 at 10:43 AM
    bytemyfoot
    bytemyfoot [OP] Member
    Just ordered an MVCI cable. I've seen listings for a 22 pin connector adapter for Toyotas. Is this something I'd need? Where would I find the 22 pin port on my truck?
  2. Dec 20, 2014 at 6:52 PM
    bytemyfoot
    Ok, from more research, it appears the 22 pin connector is only needed for older models. I don't think I'd have any use for it on my 2012. Can anyone confirm?
  3. Dec 20, 2014 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do you mean for the OBD2 Scanner? If you get an OBD2 scanner you do not need any type of adapter cable.
  4. Dec 21, 2014 at 4:55 PM
    bytemyfoot
  5. Dec 21, 2014 at 7:56 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Your Tacoma has a 16 pin connector for the OBD2. You do not need any adapter cable to connect an OBD2 Scanner.
    The 16 pin OBD2 Connector is under the dash on the left side of the steering wheel. It may / should have a dust cover that pulls off to expose the connector.
    http://www.carmd.com/70.6/Article/FIND-MY-CAR'S-CONNECTOR
  6. Dec 22, 2014 at 6:10 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The cable in the Amazon link has a 22 pin(OBD-1) on one end and a 16 pin(OBD-II) on the other end. Some scanners are setup to read OBD-1 and OBD-II codes. You connect the 22 pin in your older OBD-I vehicle; then connect the 16 pin end of the cable to your scanner.
    There were OBD-I cars that had ports similar in concept to todays OBD-II port. Others simply had a 2 port connection that you'd jumper with a wire; then count CHECK ENGINE blinks in the dash cluster.
